Home » Newcomers » Newcomers » What do these plug-in instructions mean?
What do these plug-in instructions mean? [message #478789] Thu, 06 August 2009 18:07 Go to next message
D. Alvarado is currently offline D. Alvarado
Member
I'm using Eclipse 3.4 (Ganymede) on Win XP. I am trying to install a
plug-in called Fortify with Eclipse. The Fortify instructions state
Select Help - Software Updates - Manage Configuration
but when I select Help and Software Updates, I don't see anything labeled
"Manage Configuration" on the next page. Any ideas what they might mean?
The next instruction is
Click "Add an Extension Location"
Thanks, - Dave
Re: What do these plug-in instructions mean? [message #478810 is a reply to message #478789] Thu, 06 August 2009 22:25 Go to previous messageGo to next message
Eric Rizzo is currently offline Eric Rizzo
D. Alvarado wrote:
> labeled "Manage Configuration" on the next page. Any ideas what they
> might mean?
Those instructions are written for Eclipse 3.3 and earlier; the Software
Update UI changed dramatically in 3.4 (and again in 3.5). You should ask
the Fortify developers for instructions to install into 3.4 or 3.5 (or
if it is even compatible with those versions of Eclipse).
If you post the URL of the instructions you are trying to follow, we can
probably offer some guidance in translating the instructions.
Eric
Re: What do these plug-in instructions mean? [message #478950 is a reply to message #478810] Fri, 07 August 2009 11:57 Go to previous messageGo to next message
Member
Thanks for your reply Eric. They don't have a public URL but here are the
instructions included ...
If you have not configured the Secure Coding Plug-ins for Eclipse:
1. Open Eclipse.
2. Select Help - Software Updates - Manage Configuration.
3. Click Add an Extension Location.
4. Select <Fortify_install_directory>/plugins/eclipse.
5. Click OK.
6. Restart Eclipse, if prompted to do so.
The Fortify Software menu displays.
Thanks for any additional insight, - Dave
Re: What do these plug-in instructions mean? [message #478957 is a reply to message #478950] Fri, 07 August 2009 12:18 Go to previous messageGo to next message
D. Alvarado wrote on Fri, 07 August 2009 11:57
1. Open Eclipse.
5. Click OK.
OK, that's pretty easy. You just need to copy what is in the <Fortify_install_directory>/plugins/eclipse directory into the dropins/ directory under your Ganymede installation and restart Eclipse. It might be required to use the -clean command-line argument the first time you restart, but probably not.
Note that there is no garauntee that these plug-ins are compatible or will function correctily with Eclipse 3.4 - you'll have to try and/or ask the vendor about that.
Re: What do these plug-in instructions mean? [message #543810 is a reply to message #478957] Wed, 30 June 2010 11:59 Go to previous message
Sanjay Singh is currently offline Sanjay Singh
For eclipse 3.5 and above follow below below steps:
1. open command prompt and change directory to <Fortify Home>\plugins\eclipse\features\com.fortify.plugin.analysis\bin
2. Run eclipsepostinstall.bat
3. Select option 1 to set eclipse dir
4. Select option 2 to install
5. Install eclipse with clean option
Previous Topic:need write right on live system
Next Topic:problem with packaging
Current Time: Tue Jun 18 01:45:18 EDT 2013
Powered by FUDForum. Page generated in 0.01664 seconds
