Home » Eclipse Projects » Mylyn » Task repository link provider failed: "null"
Task repository link provider failed: "null" [message #478743] Thu, 06 August 2009 11:35 Go to next message
Yves Schumann is currently offline Yves Schumann
Member
I've got a lot of error messages from org.eclipse.mylyn.tasks.ui on the
Error Log. You can see some details on the bottom.
The error occours if I hover over a method with pressed Ctrl-Key. The
strange thing is, if the editor window is _not_ activated, no error
occours. So if I clear the error log the error log window has the focus
because of the click on the red "x" (Delete log). If I now press Ctrl
and move mouse pointer over a method/member/whatever, everything is
fine. The click works too and opens the desired method/member/whatever.
If clicking after that into another open Eclipse window linke the
Outline and then do again Ctrl-hover a method everything works nice too,
no error on the error log.
But if the main editor window is active (has focus) and a
method/member/whatever is Ctrl-hovered, the error log is flooded with
the errors you see on the bottom of this posting. That's always two of
these entries, one says
'Task repository link provider failed: "null"'
and the other says
'Problems occurred when invoking code from plug-in:
"org.eclipse.mylyn.tasks.ui".'
Any ideas on how to solve this? The functionality is not affected, the
ctrl-click works as it should. Just wondering about the flooded error log...
It's Eclipse Galileo 20090621-0832 with Mylyn 3.2.1v20090722-0200-e3x
(and some other plugins). Here are two examples out of my error log:
------------------->8 Snip 8<------------------
null
Error
Thu Aug 06 17:13:54 CEST 2009
java.lang.AbstractMethodError
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin$11.run(Tas ksUiPlugin.java:1165)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
org.eclipse.mylyn.internal.tasks.ui.TasksUiPlugin.getReposit oryForResource(TasksUiPlugin.java:1157)
org.eclipse.mylyn.tasks.ui.AbstractTaskHyperlinkDetector.get TaskRepository(AbstractTaskHyperlinkDetector.java:166)
org.eclipse.mylyn.tasks.ui.AbstractTaskHyperlinkDetector.get TaskRepositories(AbstractTaskHyperlinkDetector.java:130)
org.eclipse.mylyn.internal.tasks.ui.editors.TaskHyperlinkDet ector.detectHyperlinks(TaskHyperlinkDetector.java:38)
org.eclipse.mylyn.tasks.ui.AbstractTaskHyperlinkDetector.det ectHyperlinks(AbstractTaskHyperlinkDetector.java:93)
org.eclipse.ui.texteditor.HyperlinkDetectorRegistry$Hyperlin kDetectorDelegate.detectHyperlinks(HyperlinkDetectorRegistry .java:80)
org.eclipse.jface.text.hyperlink.HyperlinkManager.findHyperl inks(HyperlinkManager.java:263)
org.eclipse.jface.text.hyperlink.HyperlinkManager.mouseMove( HyperlinkManager.java:439)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:199)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
------------------->8 Snap 8<------------------
null
Error
Yves
[eisfair-team]
"Das Wichtigste in der Kunst ist der Rahmen." -- Frank Zappa
Re: Task repository link provider failed: "null" [message #478768 is a reply to message #478743] Thu, 06 August 2009 14:43 Go to previous messageGo to next message
Steffen Pingel is currently offline Steffen Pingel
Please take a look at this bug report:
242666: [update] AbstractMethodError when alt-click-ing for task repository
links with Subclipse Mylyn integration
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242666
Steffen
Yves Schumann wrote:
> and the other says
> log...
> null
> Error
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84) at
> org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003) at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3880) at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3473) at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405) at
> org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369) at
> org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21) at
> org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500) at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> null
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Yves
> [eisfair-team]
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Task repository link provider failed: "null" [message #478770 is a reply to message #478768] Thu, 06 August 2009 15:00 Go to previous messageGo to next message
Member
Hi Steffen
Thx a lot for the link. I will take a look at the installed subversive
plugin version and update it.
Yves
[eisfair-team]
"Ich bin nicht sicher, mit welchen Waffen der dritte Weltkrieg
ausgetragen wird, aber im vierten Weltkrieg werden sie mit Stöcken und
Steinen kämpfen." -- Albert Einstein
Re: Task repository link provider failed: "null" [message #479200 is a reply to message #478768] Mon, 10 August 2009 05:13 Go to previous messageGo to next message
Member
Hi Steffen
Unfortunately there is no change in behaviour because I've already use
the latest versions of the subversive components and mylyn. Any other
suggestions?
Please let me know if you need more details about my Eclipse
installation so I can send you as PM (It's quite a lot of output... ;-)
Yves
[eisfair-team]
"Jede hinreichend fortschrittliche Technologie ist von Magie nicht zu
unterscheiden." -- Arthur C. Clarke
Re: Task repository link provider failed: "null" [message #480826 is a reply to message #479200] Tue, 18 August 2009 11:32 Go to previous messageGo to next message
Member
Hi there
> suggestions?
No more ideas on this issue?
MfG
Yves
[eisfair-team]
"Hätten wir das Wort, hätten wir die Sprache, wir bräuchten die Waffen
nicht." -- Ingeborg Bachmann
Re: Task repository link provider failed: "null" [message #480876 is a reply to message #479200] Tue, 18 August 2009 14:08 Go to previous messageGo to next message
Can you file a new bug and attach your configuration, i.e. a list of all
installed features and plug-ins, to the bug?
Steffen
> Hi Steffen
>> repository links with Subclipse Mylyn integration
> suggestions?
> Yves
> [eisfair-team]
Steffen Pingel
Re: Task repository link provider failed: "null" [message #481458 is a reply to message #480876] Fri, 21 August 2009 02:49 Go to previous message
Member
Hi Steffen
[x] Done with [1].
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=287267
Yves
[eisfair-team]
"Wer eine Not erblickt und wartet, bis er um Hilfe gebeten wird, ist
ebenso schlecht, als ob er sie verweigert hätte." -- Dante Alighieri
Re: Task repository link provider failed: "null" [message #598580 is a reply to message #478743] Thu, 06 August 2009 14:43 Go to previous message
Steffen
> and the other says
> log...
> null
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> null
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Yves
> [eisfair-team]
Steffen Pingel
Re: Task repository link provider failed: "null" [message #598594 is a reply to message #478768] Thu, 06 August 2009 15:00 Go to previous message
Member
Hi Steffen
Yves
[eisfair-team]
Re: Task repository link provider failed: "null" [message #598641 is a reply to message #478768] Mon, 10 August 2009 05:13 Go to previous message
Member
Hi Steffen
suggestions?
Yves
[eisfair-team]
Re: Task repository link provider failed: "null" [message #598727 is a reply to message #479200] Tue, 18 August 2009 11:32 Go to previous message
Member
Hi there
> suggestions?
MfG
Yves
[eisfair-team]
Re: Task repository link provider failed: "null" [message #598730 is a reply to message #479200] Tue, 18 August 2009 14:08 Go to previous message
Steffen
> Hi Steffen
> suggestions?
> Yves
> [eisfair-team]
Steffen Pingel
Re: Task repository link provider failed: "null" [message #598818 is a reply to message #480876] Fri, 21 August 2009 02:49 Go to previous message
Member
Hi Steffen
[x] Done with [1].
Yves
[eisfair-team]
Previous Topic:Use WikiText to create PDF from Trac Wiki
Next Topic:Specify per-category filtering options
Current Time: Tue Oct 08 07:48:08 EDT 2013
Powered by FUDForum. Page generated in 0.02161 seconds
