Home » Newcomers » Newcomers » Using Eclipse's CVS client with an already checked out project
Using Eclipse's CVS client with an already checked out project [message #48586] Thu, 07 April 2005 15:56 Go to next message
Originally posted by: david.aldrich.t-modus.nec.co.uk
I have created a new C++ project in Eclipse from an existing source root.
This source root is managed by CVS. I usually use SmartCVS or TortoiseCVS
clients to interface with CVS.
I would like to experiment with the Team capabilities of Eclipse. I assume
that one would normally check-out a project with Eclipse and then start
working on it. However, in my case, the project was already checked out,
that is why I created it from 'an existing source root'.
Can I configure Eclipse's CVS client to use the already checked out CVS
project?
Can I use Eclipse's CVS client / SmartCVS / TortoiseCVS interchangeably on
the same project? (i.e. are the local project CVS files compatible?)
David
Re: Using Eclipse's CVS client with an already checked out project [message #49100 is a reply to message #48586] Fri, 08 April 2005 08:47 Go to previous message
It seems that Team->Share Project... does what I want.
David
Previous Topic:main.java
Next Topic:cvs view empty!
Current Time: Thu Apr 19 10:13:02 GMT 2018
Powered by FUDForum. Page generated in 0.02723 seconds
