Home » Modeling » UML2 » Re: Creating Stereotype extending AssociationEnd
Re: Creating Stereotype extending AssociationEnd [message #478459] |
Tue, 26 May 2009 16:55 |
Ed Merks Messages: 33140 Registered: July 2009 |
Gilbert,
I've added the UML2 newsgroup to the "to" list of the reply to redirect
this question to the appropriate group.
Gilbert Mirenque wrote:
> Hello NG,
> I don't exactly know if this is the right NG. Please point me to the
> correct one.
> I recently started to create a UML-profile which is aimed to put some
> special semantics to my use-cases and class-diagrams. I added a
> stereotype DataChannel extending the "Association"-metaclass. Now it
> would be fine if I could create a new stereotype "Event" extending
> AssociationEnd. But I couldn't select "AssociationEnd" as a metaclass in
> my profile. And if it is possible - how can I specify that the
> association-ends of my newly created stereotype DataChannel are of
> stereotype "Event"? Or isn't it possible at all?
> greets
> Gilbert
Ed Merks
Re: Creating Stereotype extending AssociationEnd [message #478466 is a reply to message #478464] |
Wed, 27 May 2009 15:24 |
--=-QG4LWcFXZb7t8qbC46WC
Content-Type: text/plain
It seems that my newsreader doesn't know how to reply to cross-posted
messages, so here is my reply from the EMF newsgroup.
-----8<-----
Hi, Gilbert,
There is no AssociationEnd metaclass: it was removed in UML 2.0.
Instead, association ends are represented by the Property metaclass.
So, your Event stereotype needs to extend Property.
To assert that the ends of a <<dataChannel>> association are <<events>>
you will need to use OCL. e.g.:
context DataChannel
inv ends_are_events: base_Assocation.end->forAll(e |
e.extension_Event->notEmpty())
HTH,
Christian
----->8-----
On Wed, 2009-05-27 at 10:23 +0200, Gilbert Mirenque wrote:
> no suggestions?
Content-Type: text/html; charset="utf-8"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.24.1.1">
</HEAD>
<BODY>
It seems that my newsreader doesn't know how to reply to cross-posted messages, so here is my reply from the EMF newsgroup.<BR>
<BR>
-----8<-----<BR>
<BR>
Hi, Gilbert,<BR>
<BR>
There is no AssociationEnd metaclass: it was removed in UML 2.0. Instead, association ends are represented by the Property metaclass. So, your Event stereotype needs to extend Property.<BR>
<BR>
To assert that the ends of a <<dataChannel>> association are <<events>> you will need to use OCL. e.g.:<BR>
<BR>
context DataChannel<BR>
inv ends_are_events: base_Assocation.end->forAll(e | e.extension_Event->notEmpty())<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
----->8-----<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
no suggestions?
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-QG4LWcFXZb7t8qbC46WC--
Re: Creating Stereotype extending AssociationEnd [message #478492 is a reply to message #478484] |
Thu, 04 June 2009 09:15 |
Originally posted by: formatzeh.gmx.de
--------------060105080205020100080001
Content-Type: text/plain; charset=ISO-8859-15
Hi Vlad,
> My article is available at:
> http://www.forum-omondo.com/documentation_eclipseuml_2008/As sociation_ends_stereotypes.html
thanks for your article. Nice possibility to apply stereotypes to
association ends. But I think that it is only possible in this way with
the Omondo Modeler because other UML-Tools, such as TOPCASED, don't
display the specified association-names as attributes in the class (see
the attached screenshots). That means one has first to open the
generated uml-file, select the association-end-property, and apply the
stereotype via the uml2tools from eclipse. Well, the stereotype is
applied but it isn't visible in the diagram. Another issue is that you
could apply the associationEnd-stereotype to any property of a class -
not only to associationEnds.
But a big thank you for your article. I could solve my problem in
another way. I found out that I can model my concerns better with a
StateMachine and not with a ClassDiagram. There I extended the
Pseudostate metaclass.
best regards,
Gilbert
Content-Type: image/jpeg;
name="appliedStereotype.jpg"
Content-Disposition: inline;
filename="appliedStereotype.jpg"
/9j/4AAQSkZJRgABAgEASABIAAD/4RQiRXhpZgAATU0AKgAAAAgABwESAAMA AAABAAEAAAEa
AAUAAAABAAAAYgEbAAUAAAABAAAAagEoAAMAAAABAAIAAAExAAIAAAAcAAAA cgEyAAIAAAAU
AAAAjodpAAQAAAABAAAApAAAANAACvyAAAAnEAAK/IAAACcQQWRvYmUgUGhv dG9zaG9wIENT
MyBXaW5kb3dzADIwMDk6MDY6MDQgMTE6MTQ6MzEAAAAAA6ABAAMAAAABAAEA AKACAAQAAAAB
AAABuaADAAQAAAABAAAA7gAAAAAAAAAGAQMAAwAAAAEABgAAARoABQAAAAEA AAEeARsABQAA
AAEAAAEmASgAAwAAAAEAAgAAAgEABAAAAAEAAAEuAgIABAAAAAEAABLsAAAA AAAAAEgAAAAB
AAAASAAAAAH/2P/gABBKRklGAAECAABIAEgAAP/tAAxBZG9iZV9DTQAB/+4A DkFkb2JlAGSA
AAAAAf/bAIQADAgICAkIDAkJDBELCgsRFQ8MDA8VGBMTFRMTGBEMDAwMDAwR DAwMDAwMDAwM
DAwMDAwMDAwMDAwMDAwMDAwMDAENCwsNDg0QDg4QFA4ODhQUDg4ODhQRDAwM DAwREQwMDAwM
DBEMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwM/8AAEQgAVgCgAwEiAAIR AQMRAf/dAAQA
Cv/EAT8AAAEFAQEBAQEBAAAAAAAAAAMAAQIEBQYHCAkKCwEAAQUBAQEBAQEA AAAAAAAAAQAC
AwQFBgcICQoLEAABBAEDAgQCBQcGCAUDDDMBAAIRAwQhEjEFQVFhEyJxgTIG FJGhsUIjJBVS
wWIzNHKC0UMHJZJT8OHxY3M1FqKygyZEk1RkRcKjdDYX0lXiZfKzhMPTdePz RieUpIW0lcTU
5PSltcXV5fVWZnaGlqa2xtbm9jdHV2d3h5ent8fX5/cRAAICAQIEBAMEBQYH BwYFNQEAAhED
ITESBEFRYXEiEwUygZEUobFCI8FS0fAzJGLhcoKSQ1MVY3M08SUGFqKygwcm NcLSRJNUoxdk
RVU2dGXi8rOEw9N14/NGlKSFtJXE1OT0pbXF1eX1VmZ2hpamtsbW5vYnN0dX Z3eHl6e3x//a
AAwDAQACEQMRAD8A9DpqzH0dPdRa1lQrr9VpmSAGu9m32/R/fVUs67V1bfU3 HdivuAdV6jt4
qP08mth9rbP9LV9C2z9L/Lu0sH+hYf8AxbP+oTnBrOYMze/e0RsDvZxs3Gv9 7+UjIA2D30VH
Sj+Dksr6/mBxp6hj+m4ubYaSHvbp7GV2em+pr2ue2x36L+b/AEP/AHbVwY/X hZP2mn0w8wzb
zXpG55G71Pp/8X+j/pH89YDHZ0vEybXV3Psu6fV+kqivcGhp26V1ss3Obu2e 79KgM6R0Z5fl
Pdk4dzGOfbda41PFQDa3+pkuHv2tprsdk+s/K9lN9uR6lVOwmPUahaJdDoW0 KfrBINWVQA4v
carGl5busY5rPUbt3MqZ61f+u+lxV9YnNdGTjghsMIBdLpsO632N/mv0Ff6P Z9p2Xv8A1L1q
/s9LFq+r2I9725t2+qxx9KxxY6aD611WNRsqfXUzd+mpw2MqfV+is/QexTyK fq8XbR1M4pNp
sIqvbWC/I32sa7TZ+m+1uurZ/wBqP5z9N6aaubLcfrhY+xmXX9odWRtd7qt4 FrKrWMDf0bbP
1e539tM3D+sDrg9+fWwB7nvYxktGlTKq2Nd7vT9P7Q+xr3P/AEnpf8Yq/wCz +hD0K6sm2kuB
qqfU5zI9LfjNxrrWM2sdTbm7KcTJ/wAP+irq/na0OjG+rbPbiZb3OeKzvocX hwe+qmr+jsNb
tjq27/8AQerZlW+n/SElNx2P9ZnOePtdNdZaWiGS8OP+FY8s2ez9yyn/AElX +EryKYjE+sLb
Te3NY0Pc79XtAexshm0te1ldlmz0t3p/ov5y/wDmf0X2Wh6H1XbTU23qLsqq WvbYbPWYOXy2
8Nt+zM9u/wDR20+n6fq/8IpO6X9WwasYdSsYWjZRUy8Ndt1r9GjY1tmzb+j9 Kn+d/VfU9T0c
P00puU4n1kBb62XVbU47Xhsh4rcfc9t2xjH31td9NlNH/F1fzSnbh/WIUtpp zKoLHNsseD6k
kVBr63tbt3t23v8Aof4T6CPj9a6Qaw2vIbDRtY1wLXO2sFm2qtzWvtd6fu2V MUz1zowbudm0
NbDHEusaABY0WU7iT7fWrdvq/wBIkpr2Yf1gaXGjMr987vUZuIMUMrNUANZ/ N5Fr2bf523/R
/wAywxPrDXW7bmMse6SA8CW/zugeK2td/wBp/wDB1e/fZ/wFuukkpy8ej6wN O7IyKbSK3N2t
bsYXkscyzbsst/R7bGfz+z9J/Nfo/wBITAo6w2/1M++uyssMV1AiHucHfSLW 72VsbsY76a0E
klKSSSSUpJJJJT//0PS8H+hYf/Fs/wCoVpVcH+hYf/Fs/wCoVpE7nzQNg5dl w35wbgy9lTyX
Gv226aV7mhz7fU/Obs/qesmxLdjLi7Erc9lRc77MHEvALopDb66fe/8AMZ6q 0wfe75Krnl/2
O0iCAR7XaTDmy2ZH0v3UQencoI69nLty8Zu1tvRXF7TeMXbUCyGzq9zq2Pxv tdm7/BfpP+vs
9Qbs3o7c+sN6Pd9p3QwClrSS703W5HpOextjcV7vTuytv6u+z9F7M39PoYjs p1N5xm1ss3sh
hmNsM9U7ZO2z093p/mfQQx/zmZYNvoWMd/OG06gy3d6DaRX+g+n6PrPtv/0v /CAijSQbFr35
jKq6COnFzdzxt2agCxrLDjsZXZv9T+k17/s/q0/pFXozcQVepidGsrDQ2x7H 0it21rXub6Xp
ttbZkM27K6nvqZ+l/n/51XXjrjqPca2PPpz6Mbx7P0/pm8Pp2/aNmzez+jer /h/TQQ760mt7
XsxQ7a8Mcwu3Tts9L6fs/nfQ3fo/ob/5tBLLp32HKttA6Z9lFTGNa66trS4O D63Vt27mbaqv
Z7LH/wA96X76unpvTzYbDj1l7uXFomSd5P8AWc/3Kykkpru6dgPDA7GqIq3G sFjfaXfT2ae3
f+chHo3Sjc277JUHtk6NABJ/Oewex7m/mPf/ADe+z0/5yxXUklKSSSSUpJJJ JSkkkklKSSSS
U//R9Lwf6Fh/8Wz/AKhWlVwf6Fh/8Wz/AKhWkTufNA2DEfTd8lVca8ymxlF2 18ghwkwQQ9vt
9v7itD6bvkqz8LCoxcgNpArsa51rRI3aaif6qQUWtjtbdiX2HMcGOsbGQPY2 K9ntZY4+/Hse
PTe9np7/ANJ6T/8ACqm3AxQ71aurGhrS4WBjms3mtxY+2+XbrL/1a37Rkf4T Zb/N/pVbt6hh
W4FbrKR6L7BWwP8AY1rmfpK7GlzWuq9N9f6J/wDg3/QXM9ay6cF+M7pWDiV1 2Uvvd6geHB1T
/Qa+j0baPd7/AFPU2+z+k2W1+n6qfHHPJICI+bb6BaZxiDZ21L0NmPhekMe7 qQtcXMZsvc17
HPqYarA+rc3fY/8An3+/+l11Xf4P9IJnSmXMdTX1h+QH7mhjnNsaQWuca3Vt c1rv0V7LPb/w
Xp7P0S5cZXVCA4dP6YWhrqW6WhuwAMfSxpyNv2b02+lX/wBp/s/6Ov8AV0an qvXWOBZi9Oaa
t1m8tuJBPqPfdJuNjsh7r7/o/rX6a7/CX7LJPuebtH/Git+8Y/H7C91Vl4r8 dl7LmuofAZYX
aEzs+k7+Umr6hg2gGvIrduO1vuGpn0/b/Wf9D99cKzqPWGVHHGN06uioF1eM 2uwsaSfRLqaa
rB6XrfaLGXWts9L0vW/wVn6SDMzqfqMyDi9O32OB9UtveSW/pqrHPOR7/Udu e61/83/2p/S+
pWl9zzdh/jRV7+PufsL6BTk497Q6mxtgLWv9pB9rxurd/bb9FD/aOBu2/aK5 A3fSERDnfS+j
9Fj3Lhx1jr7dobT08EVgAgv3OqrIY2iz17X2up/S/wBH+n/171EKzN6te4Md h9OsFe3aCLg1
pLa27WTkBtTa2vpY/wChT/NM/nfTrS+55uw/xoq+8Y+5+wvftzcR9npNuYX6 QJGsl7fZ+/7q
rPofuI683HX+q4we4Y2BtYfWLIuc0Ore5rXsqfk+nv8AW/SUf6f+dxvUsq9l 8fW76yljXD9n
7n/Rr22kkez3tLb3ep7rWN/R/wBT+d/Ro/cs/Yf40UfeMfc/YXuUlxDvrT9a 2a2M6fWAYJIt
JmJ+gy51jt35mxn6T/Bb6vehf88vrMHtYa8EOc4sjbYSC1vrO0Ze51ns/wBD 6v6T9D/OpDk8
x2A/xoq+8Y+5+wveJLiT9Z/rYHtaa8Da5wAdtsJhzm1NdsZe930rPooGN9df rHkRtZiNkAj9
Fa4+4vZ7gMj2M3V/pLf5uv8AR/6RL7nmIuhp/Wir7xj2s/YXvUlwuR9bfrZR VZY+rBHpse/R
tr/oMsu/Mv8Azm0PXb0vNlNb3RL2hxjiSJUWTDPHXFXquqIl8v8AdXwyRnfD 08Kf/9L0vB/o
WH/xbP8AqFaVXB/oWH/xbP8AqFaRO580DYMG/Td8lNRH03fJO5waC5xAaBJJ 4ACCWE/oZn82
Z+SzOr9NZmX02W4VGWGMImxjXuaS5jva+xvtZsa//ri0DfQykG2xrG/QJcdu sfR935yqdQor
yaW3jIYylgduuLmgQQ6s+/b7du7fv3ey1idDQgnREtRTQf8AV/BrZjbOjYWT Ib9pf9npa8mW
tf8AoXmutnsc9+/17v8AR+j+eqg6Na3Ge531a6bZkMqaWNa2pofafT9Vga9j vSrZuu2Oda/+
a/4X9HtnFyH1Yv2fMDRU1h2gSyyC12/9G+l/vrbY36foe/f6KqDpvVGY1uOz rbvUZUysPfXW
41uiub7Nx9V77vTt/nbf8P8A8HUkZG9yoRHZp5fQm1l4xegdPuDANrnVUs3n ePofS9v2f6fq
en+l/m0zein1Du+rfTjXLRo2oEiLHXW79j/+Arrp9P8A0tnrrSv6dmuve2nq jqHPmyqoDcWt
FQxd8Wvfv2Wv9b6P2f1PT/Q+r+lUMfE6p9qey/qoftBIxWtYSWOa6uu+1zBT kV77f0u2h9df
6P0qnocUu5VwjsHNd0S9rWgfV/ptrnsYd/o0s2PLahf6tfqWep6dr8h7K6n/ AKStno+v/h7j
P6Mxxayv6u4TKzc1hLm0GKg1j7cj0/ov3276qqt/qf4az0v5tbOF/P2H7aMs 11VU2tkS22s3
erbYyp3o12Xb/cxlFX8z/wBt2mXVWOeyt7XurO2xrSCWmN218fR9qXEe5VQ7 BxsX6v8ATnWs
GT0XBqYaQ52ympwbbJD6/Uhr3fo9n+A/69YrX/Nr6u/+VeHrz+gr/wDILSSS 4j3KqHYOafq1
9XSZPS8Mnx9Cv/yCR+rf1eJJPTMQk8k0V6/9BaSSXEe5VQ7BzP8Amz9XP/Kv D/7Yr/8AIJz9
W/q6eel4Z/6xX/5BaSSXEe5VQ7BzP+bP1cIj9lYcf8RX/wCQWkAGgNaIAEAD gBOkkSTumgNn
/9P0vB/oWH/xbP8AqFaVXB/oWH/xbP8AqFaRO580DYMW/Td8knsa9jmO1a4E HtodOyYfTd8l
NBLS/ZeFXjNprY5jKnGxgY9zCHEOGj2Oa785VM+rp9dVOFZQ59QD3Mc51jY3 n0LB6wa5/vZk
2b/f/NLXcJaQO4IWf1L7RNZqqFjocI2hwHtdslzqn+31djH+7+b/ADE6Opo7 dlshWo37uff0
36vuON9qxzj2ZAcTjA7RFrttwtcw7P5/IZ/Nv3/9a9RApzPqfVjevXuoqpo9 V7QyxsMua0bn
vDfpurzPzbf8Jv8A8D+i1rLr66MVhwzZU4M9b2g7DLG7W0Mbu9u57/5vZ+jV X9pdX+y2Ps6N
Nra2PLG2NdvtJr31NG3/AAT32+//AIH/AEdnrIHcrhs1epH6q1gtzGPaKwwm sbtrQ1zMRu/Y
702+n6VXss+mz+j+p6lvqFxuofVnGsdXVbY1pdX7Xi5zQ97rMprWtsDnU2Od S627+b9T9H6q
tX5vVKbL/T6c3IaHauadheRT6nDm2b/0+yht3/pL3tT1TPvvcw9Lcytm4Oue 7hzWFzmBnpb7
fftp30epS/8AwNtyCnNtyPqq51T8plzbK2Vuxqnl8hr21201UVMd+b9qZT/w Vv6P/uOtDD6l
0LADcbEte/1La8eus73Q9zK3Mprfd7WMrosrs9L1NlP83/O/olexnWWWCu7F FDG0VPa0w7a9
3qttx9zP0X6BtdX83++rPo1cbG8k8Dl30nf2pSUgxuo4uU9raHF4fUL2OiAW OJZ+dD/zf3Va
TbW7t8DdEbu8eEp0lKSSSSUpJJJJSkkkklP/1PS8H+hYf/Fs/wCoVpfKqSJ3 PmgbB+lbqrWu
z7M24WYDqzFDmvaGtH85vtAduY9R6e0F+VXiOpbaaWeneNz3BpN32Z1mO5tX 6uyz1/RY3I/6
4vmxJP8A0Dv/ANytPzjb/un6POH1r0b9uc4b3O3SwksH6Td9nd6Qfa5tbqdn pM9P1f5v/hG+
yfWEY9oZnMk3Ndjl9TyWta97/RtjZY5lr/Qqss+h9m9VfOKSjXv0hVjfWMZN Trsuva2d1YG4
ObFP0rW0U1ssZZu/wX6wz1fQ+x+r+qPRh/WUNaLs+su5e4VjmXHaxpZ9H+bZ /wBvf9yKPsXz
ckkp+lsnH6o5jAzK9PJLrTS4Mcaw1w/RsyNo9N/pf4Oy1tf/ABVv+FgzD639 p3WZ8H3FjG1T
XEsG13t9vs93856r3v8A0PpV1Xev82JJKfpHExettzWPtzQ+oEnJqdWYM+ps ZRZtqr2sY7H9
7G/pLWWW/ov5hbK+VUklP1UkvlVJJT9VJL5VSSU/VSS+VUklP1UkvlVJJT// 2f/tGVRQaG90
b3Nob3AgMy4wADhCSU0EJQAAAAAAEAAAAAAAAAAAAAAAAAAAAAA4QklNBC8A AAAAAErAjQEA
SAAAAEgAAAAAAAAAAAAAANACAABAAgAAAAAAAAAAAAAYAwAAZAIAAAABwAMA ALAEAAABAA8n
AQBsbHVuAAAAAAAAAAAAADhCSU0D7QAAAAAAEABIAAAAAQACAEgAAAABAAI4 QklNBCYAAAAA
AA4AAAAAAAAAAAAAP4AAADhCSU0EDQAAAAAABAAAAHg4QklNBBkAAAAAAAQA AAAeOEJJTQPz
AAAAAAAJAAAAAAAAAAABADhCSU0ECgAAAAAAAQAAOEJJTScQAAAAAAAKAAEA AAAAAAAAAjhC
SU0D9QAAAAAASAAvZmYAAQBsZmYABgAAAAAAAQAvZmYAAQChmZoABgAAAAAA AQAyAAAAAQBa
AAAABgAAAAAAAQA1AAAAAQAtAAAABgAAAAAAAThCSU0D+AAAAAAAcAAA//// ////////////
/////////////wPoAAAAAP////////////////////////////8D6AAAAAD/ ////////////
////////////////A+gAAAAA/////////////////////////////wPoAAA4 QklNBAAAAAAA
AAIAADhCSU0EAgAAAAAAAgAAOEJJTQQwAAAAAAABAQA4QklNBC0AAAAAAAYA AQAAAAI4QklN
BAgAAAAAABAAAAABAAACQAAAAkAAAAAAOEJJTQQeAAAAAAAEAAAAADhCSU0E GgAAAAADSwAA
AAYAAAAAAAAAAAAAAO4AAAG5AAAACwBVAG4AYgBlAG4AYQBuAG4AdAAtADEA AAABAAAAAAAA
AAAAAAAAAAAAAAAAAAEAAAAAAAAAAAAAAbkAAADuAAAAAAAAAAAAAAAAAAAA AAEAAAAAAAAA
AAAAAAAAAAAAAAAAEAAAAAEAAAAAAABudWxsAAAAAgAAAAZib3VuZHNPYmpj AAAAAQAAAAAA
AFJjdDEAAAAEAAAAAFRvcCBsb25nAAAAAAAAAABMZWZ0bG9uZwAAAAAAAAAA QnRvbWxvbmcA
AADuAAAAAFJnaHRsb25nAAABuQAAAAZzbGljZXNWbExzAAAAAU9iamMAAAAB AAAAAAAFc2xp
Y2UAAAASAAAAB3NsaWNlSURsb25nAAAAAAAAAAdncm91cElEbG9uZwAAAAAA AAAGb3JpZ2lu
ZW51bQAAAAxFU2xpY2VPcmlnaW4AAAANYXV0b0dlbmVyYXRlZAAAAABUeXBl ZW51bQAAAApF
U2xpY2VUeXBlAAAAAEltZyAAAAAGYm91bmRzT2JqYwAAAAEAAAAAAABSY3Qx AAAABAAAAABU
b3AgbG9uZwAAAAAAAAAATGVmdGxvbmcAAAAAAAAAAEJ0b21sb25nAAAA7gAA AABSZ2h0bG9u
ZwAAAbkAAAADdXJsVEVYVAAAAAEAAAAAAABudWxsVEVYVAAAAAEAAAAAAABN c2dlVEVYVAAA
AAEAAAAAAAZhbHRUYWdURVhUAAAAAQAAAAAADmNlbGxUZXh0SXNIVE1MYm9v bAEAAAAIY2Vs
bFRleHRURVhUAAAAAQAAAAAACWhvcnpBbGlnbmVudW0AAAAPRVNsaWNlSG9y ekFsaWduAAAA
B2RlZmF1bHQAAAAJdmVydEFsaWduZW51bQAAAA9FU2xpY2VWZXJ0QWxpZ24A AAAHZGVmYXVs
dAAAAAtiZ0NvbG9yVHlwZWVudW0AAAARRVNsaWNlQkdDb2xvclR5cGUAAAAA Tm9uZQAAAAl0
b3BPdXRzZXRsb25nAAAAAAAAAApsZWZ0T3V0c2V0bG9uZwAAAAAAAAAMYm90 dG9tT3V0c2V0
bG9uZwAAAAAAAAALcmlnaHRPdXRzZXRsb25nAAAAAAA4QklNBCgAAAAAAAwA AAABP/AAAAAA
AAA4QklNBBQAAAAAAAQAAAADOEJJTQQMAAAAABMIAAAAAQAAAKAAAABWAAAB 4AAAoUAAABLs
ABgAAf/Y/+AAEEpGSUYAAQIAAEgASAAA/+0ADEFkb2JlX0NNAAH/7gAOQWRv YmUAZIAAAAAB
/9sAhAAMCAgICQgMCQkMEQsKCxEVDwwMDxUYExMVExMYEQwMDAwMDBEMDAwM DAwMDAwMDAwM
DAwMDAwMDAwMDAwMDAwMAQ0LCw0ODRAODhAUDg4OFBQODg4OFBEMDAwMDBER DAwMDAwMEQwM
DAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAz/wAARCABWAKADASIAAhEBAxEB /90ABAAK/8QB
PwAAAQUBAQEBAQEAAAAAAAAAAwABAgQFBgcICQoLAQABBQEBAQEBAQAAAAAA AAABAAIDBAUG
BwgJCgsQAAEEAQMCBAIFBwYIBQMMMwEAAhEDBCESMQVBUWETInGBMgYUkaGx QiMkFVLBYjM0
coLRQwclklPw4fFjczUWorKDJkSTVGRFwqN0NhfSVeJl8rOEw9N14/NGJ5Sk hbSVxNTk9KW1
xdXl9VZmdoaWprbG1ub2N0dXZ3eHl6e3x9fn9xEAAgIBAgQEAwQFBgcHBgU1 AQACEQMhMRIE
QVFhcSITBTKBkRShsUIjwVLR8DMkYuFygpJDUxVjczTxJQYWorKDByY1wtJE k1SjF2RFVTZ0
ZeLys4TD03Xj80aUpIW0lcTU5PSltcXV5fVWZnaGlqa2xtbm9ic3R1dnd4eX p7fH/9oADAMB
AAIRAxEAPwD0OmrMfR091FrWVCuv1WmZIAa72bfb9H99VSzrtXVt9Tcd2K+4 B1XqO3io/Tya
2H2ts/0tX0LbP0v8u7Swf6Fh/wDFs/6hOcGs5gzN797RGwO9nGzca/3v5SMg DYPfRUdKP4OS
yvr+YHGnqGP6bi5thpIe9unsZXZ6b6mva57bHfov5v8AQ/8AdtXBj9eFk/aa fTDzDNvNekbn
kbvU+n/xf6P+kfz1gMdnS8TJtdXc+y7p9X6SqK9waGnbpXWyzc5u7Z7v0qAz pHRnl+U92Th3
MY59t1rjU8VANrf6mS4e/a2mux2T6z8r2U325HqVU7CY9RqFol0OhbQp+sEg 1ZVADi9xqsaX
lu6xjms9Ru3cypnrV/676XFX1ic10ZOOCGwwgF0umw7rfY3+a/QV/o9n2nZe /wDUvWr+z0sW
r6vYj3vbm3b6rHH0rHFjpoPrXVY1Gyp9dTN36anDYyp9X6Kz9B7FPIp+rxdt HUzik2mwiq9t
YL8jfaxrtNn6b7W66tn/AGo/nP03ppq5stx+uFj7GZdf2h1ZG13uq3gWsqtY wN/Rts/V7nf2
0zcP6wOuD359bAHue9jGS0aVMqrY13u9P0/tD7Gvc/8ASel/xir/ALP6EPQr qybaS4Gqp9Tn
Mj0t+M3GutYzax1NubspxMn/AA/6Kur+drQ6Mb6ts9uJlvc54rO+hxeHB76q av6Ow1u2Orbv
/wBB6tmVb6f9ISU3HY/1mc54+1011lpaIZLw4/4VjyzZ7P3LKf8ASVf4SvIp iMT6wttN7c1j
Q9zv1e0B7GyGbS17WV2WbPS3en+i/nL/AOZ/RfZaHofVdtNTbeouyqpa9ths 9Zg5fLbw237M
z27/ANHbT6fp+r/wik7pf1bBqxh1KxhaNlFTLw123Wv0aNjW2bNv6P0qf539 V9T1PRw/TSm5
TifWQFvrZdVtTjteGyHitx9z23bGMffW1302U0f8XV/NKduH9YhS2mnMqgsc 2yx4PqSRUGvr
e1u3e3be/wCh/hPoI+P1rpBrDa8hsNG1jXAtc7awWbaq3Na+13p+7ZUxTPXO jBu52bQ1sMcS
6xoAFjRZTuJPt9at2+r/AEiSmvZh/WBpcaMyv3zu9Rm4gxQys1QA1n83kWvZ t/nbf9H/ADLD
E+sNdbtuYyx7pIDwJb/O6B4ra13/AGn/AMHV799n/AW66SSnLx6PrA07sjIp tIrc3a1uxheS
xzLNuyy39HtsZ/P7P0n81+j/AEhMCjrDb/Uz767KywxXUCIe5wd9ItbvZWxu xjvprQSSUpJJ
JJSkkkklP//Q9Lwf6Fh/8Wz/AKhWlVwf6Fh/8Wz/AKhWkTufNA2Dl2XDfnBu DL2VPJca/bbp
pXuaHPt9T85uz+p6ybEt2MuLsStz2VFzvswcS8AuikNvrp97/wAxnqrTB97v kqueX/Y7SIIB
HtdpMObLZkfS/dRB6dygjr2cu3Lxm7W29FcXtN4xdtQLIbOr3OrY/G+12bv8 F+k/6+z1Buze
jtz6w3o932ndDAKWtJLvTdbkek57G2NxXu9O7K2/q77P0Xszf0+hiOynU3nG bWyzeyGGY2wz
1Ttk7bPT3en+Z9BDH/OZlg2+hYx384bTqDLd3oNpFf6D6fo+s+2//S/8ICKN JBsWvfmMqroI
6cXN3PG3ZqALGssOOxldm/1P6TXv+z+rT+kVejNxBV6mJ0aysNDbHsfSK3bW te5vpem21tmQ
zbsrqe+pn6X+f/nVdeOuOo9xrY8+nPoxvHs/T+mbw+nb9o2bN7P6N6v+H9NB DvrSa3tezFDt
rwxzC7dO2z0vp+z+d9Dd+j+hv/m0EsunfYcq20Dpn2UVMY1rrq2tLg4PrdW3 buZtqq9nssf/
AD3pfvq6em9PNhsOPWXu5cWiZJ3k/wBZz/crKSSmu7p2A8MDsaoircawWN9p d9PZp7d/5yEe
jdKNzbvslQe2To0AEn857B7Hub+Y9/8AN77PT/nLFdSSUpJJJJSkkkklKSSS SUpJJJJT/9H0
vB/oWH/xbP8AqFaVXB/oWH/xbP8AqFaRO580DYMR9N3yVVxrzKbGUXbXyCHC TBBD2+32/uK0
Ppu+SrPwsKjFyA2kCuxrnWtEjdpqJ/qpBRa2O1t2JfYcxwY6xsZA9jYr2e1l jj78ex49N72e
nv8A0npP/wAKqbcDFDvVq6saGtLhYGOazea3Fj7b5dusv/VrftGR/hNlv83+ lVu3qGFbgVus
pHovsFbA/wBjWuZ+krsaXNa6r031/on/AODf9Bcz1rLpwX4zulYOJXXZS+93 qB4cHVP9Br6P
Rto93v8AU9Tb7P6TZbX6fqp8cc8kgIj5tvoFpnGINnbUvQ2Y+F6Qx7upC1xc xmy9zXsc+phq
sD6tzd9j/wCff7/6XXVd/g/0gmdKZcx1NfWH5AfuaGOc2xpBa5xrdW1zWu/R Xss9v/Bens/R
LlxldUIDh0/phaGupbpaG7AAx9LGnI2/ZvTb6Vf/AGn+z/o6/wBXRqeq9dY4 FmL05pq3Wby2
4kE+o990m42OyHuvv+j+tfprv8Jfssk+55u0f8aK37xj8fsL3VWXivx2Xsua 6h8BlhdoTOz6
Tv5SavqGDaAa8it247W+4amfT9v9Z/0P31wrOo9YZUccY3Tq6KgXV4za7Cxp J9EuppqsHpet
9osZda2z0vS9b/BWfpIMzOp+ozIOL07fY4H1S295Jb+mqsc85Hv9R257rX/z f/an9L6laX3P
N2H+NFXv4+5+wvoFOTj3tDqbG2Ata/2kH2vG6t39tv0UP9o4G7b9orkDd9IR EOd9L6P0WPcu
HHWOvt2htPTwRWACC/c6qshjaLPXtfa6n9L/AEf6f/XvUQrM3q17gx2H06wV 7doIuDWktrbt
ZOQG1Nra+lj/AKFP80z+d9OtL7nm7D/Gir7xj7n7C9+3NxH2ek25hfpAkayX t9n7/uqs+h+4
jrzcdf6rjB7hjYG1h9Ysi5zQ6t7mteyp+T6e/wBb9JR/p/53G9Syr2Xx9bvr KWNcP2fuf9Gv
baSR7Pe0tvd6nutY39H/AFP539Gj9yz9h/jRR94x9z9he5SXEO+tP1rZrYzp 9YBgki0mYn6D
LnWO3fmbGfpP8Fvq96F/zy+swe1hrwQ5ziyNthILW+s7Rl7nWez/AEPq/pP0 P86kOTzHYD/G
ir7xj7n7C94kuJP1n+tge1prwNrnAB22wmHObU12xl73fSs+igY311+seRG1 mI2QCP0Vrj7i
9nuAyPYzdX+kt/m6/wBH/pEvueYi6Gn9aKvvGPaz9he9SXC5H1t+tlFVlj6s Eemx79G2v+gy
y78y/wDObQ9dvS82U1vdEvaHGOJIlRZMM8dcVeq6oiXy/wB1fDJGd8PTwp// 0vS8H+hYf/Fs
/wCoVpVcH+hYf/Fs/wCoVpE7nzQNgwb9N3yU1EfTd8k7nBoLnEBoEkngAIJY T+hmfzZn5LM6
v01mZfTZbhUZYYwibGNe5pLmO9r7G+1mxr/+uLQN9DKQbbGsb9Alx26x9H3f nKp1CivJpbeM
hjKWB264uaBBDqz79vt27t+/d7LWJ0NCCdES1FNB/wBX8GtmNs6NhZMhv2l/ 2elryZa1/wCh
ea62exz37/Xu/wBH6P56qDo1rcZ7nfVrptmQyppY1ramh9p9P1WBr2O9Ktm6 7Y51r/5r/hf0
e2cXIfVi/Z8wNFTWHaBLLILXb/0b6X++ttjfp+h79/oqoOm9UZjW47Otu9Rl TKw99dbjW6K5
vs3H1Xvu9O3+dt/w/wDwdSRkb3KhEdmnl9CbWXjF6B0+4MA2udVSzed4+h9L 2/Z/p+p6f6X+
bTN6KfUO76t9ONctGjagSIsddbv2P/4Cuun0/wDS2eutK/p2a697aeqOoc+b KqgNxa0VDF3x
a9+/Za/1vo/Z/U9P9D6v6VQx8Tqn2p7L+qh+0EjFa1hJY5rq677XMFORXvt/ S7aH11/o/Sqe
hxS7lXCOwc13RL2taB9X+m2uexh3+jSzY8tqF/q1+pZ6np2vyHsrqf8ApK2e j6/+HuM/ozHF
rK/q7hMrNzWEubQYqDWPtyPT+i/fbvqqq3+p/hrPS/m1s4X8/YftoyzXVVTa 2RLbazd6ttjK
nejXZdv9zGUVfzP/AG3aZdVY57K3te6s7bGtIJaY3bXx9H2pcR7lVDsHGxfq /wBOdawZPRcG
phpDnbKanBtskPr9SGvd+j2f4D/r1itf82vq7/5V4evP6Cv/AMgtJJLiPcqo dg5p+rX1dJk9
LwyfH0K//IJH6t/V4kk9MxCTyTRXr/0FpJJcR7lVDsHM/wCbP1c/8q8P/tiv /wAgnP1b+rp5
6Xhn/rFf/kFpJJcR7lVDsHM/5s/VwiP2Vhx/xFf/AJBaQAaA1ogAQAOAE6SR JO6aA2f/0/S8
H+hYf/Fs/wCoVpVcH+hYf/Fs/wCoVpE7nzQNgxb9N3ySexr2OY7VrgQe2h07 Jh9N3yU0EtL9
l4VeM2mtjmMqcbGBj3MIcQ4aPY5rvzlUz6un11U4VlDn1APcxznWNjefQsHr Brn+9mTZv9/8
0tdwlpA7ghZ/UvtE1mqoWOhwjaHAe12yXOqf7fV2Mf7v5v8AMTo6mjt2WyFa jfu59/Tfq+44
32rHOPZkBxOMDtEWu23C1zDs/n8hn82/f/1r1ECnM+p9WN69e6iqmj1XtDLG wy5rRue8N+m6
vM/Nt/wm/wDwP6LWsuvroxWHDNlTgz1vaDsMsbtbQxu727nv/m9n6NVf2l1f 7LY+zo02trY8
sbY12+0mvfU0bf8ABPfb7/8Agf8AR2esgdyuGzV6kfqrWC3MY9orDCaxu2tD XMxG79jvTb6f
pVeyz6bP6P6nqW+oXG6h9Wcax1dVtjWl1fteLnND3usymta2wOdTY51Lrbv5 v1P0fqq1fm9U
psv9Ppzchodq5p2F5FPqcObZv/T7KG3f+kve1PVM++9zD0tzK2bg657uHNYX OYGelvt9+2nf
R6lL/wDA23IKc23I+qrnVPymXNsrZW7GqeXyGvbXbTVRUx35v2plP/BW/o/+ 460MPqXQsANx
sS17/Utrx66zvdD3Mrcymt93tYyuiyuz0vU2U/zf87+iV7GdZZYK7sUUMbRU 9rTDtr3eq23H
3M/RfoG11fzf76s+jVxsbyTwOXfSd/alJSDG6ji5T2tocXh9QvY6IBY4ln50 P/N/dVpNtbu3
wN0Ru7x4SnSUpJJJJSkkkklKSSSSU//U9Lwf6Fh/8Wz/AKhWl8qpInc+aBsH 6Vuqta7Pszbh
ZgOrMUOa9oa0fzm+0B25j1Hp7QX5VeI6ltppZ6d43PcGk3fZnWY7m1fq7LPX 9Fjcj/ri+bEk
/wDQO/8A3K0/ONv+6fo84fWvRv25zhvc7dLCSwfpN32d3pB9rm1up2ekz0/V /m/+Eb7J9YRj
2hmcyTc12OX1PJa1r3v9G2NljmWv9Cqyz6H2b1V84pKNe/SFWN9Yxk1Ouy69 rZ3Vgbg5sU/S
tbRTWyxlm7/BfrDPV9D7H6v6o9GH9ZQ1ouz6y7l7hWOZcdrGln0f5tn/AG9/ 3Io+xfNySSn6
WycfqjmMDMr08kutNLgxxrDXD9GzI2j03+l/g7LW1/8AFW/4WDMPrf2ndZnw fcWMbVNcSwbX
e32+z3fznqve/wDQ+lXVd6/zYkkp+kcTF623NY+3ND6gScmp1Zgz6mxlFm2q vaxjsf3sb+kt
ZZb+i/mFsr5VSSU/VSS+VUklP1UkvlVJJT9VJL5VSSU/VSS+VUklP//ZOEJJ TQQhAAAAAABV
AAAAAQEAAAAPAEEAZABvAGIAZQAgAFAAaABvAHQAbwBzAGgAbwBwAAAAEwBB AGQAbwBiAGUA
IABQAGgAbwB0AG8AcwBoAG8AcAAgAEMAUwAzAAAAAQA4QklNBAYAAAAAAAcA CAAAAAEBAP/h
D85odHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvADw/eHBhY2tldCBiZWdp bj0i77u/IiBp
ZD0iVzVNME1wQ2VoaUh6cmVTek5UY3prYzlkIj8+IDx4OnhtcG1ldGEgeG1s bnM6eD0iYWRv
YmU6bnM6bWV0YS8iIHg6eG1wdGs9IkFkb2JlIFhNUCBDb3JlIDQuMS1jMDM2 IDQ2LjI3Njcy
MCwgTW9uIEZlYiAxOSAyMDA3IDIyOjQwOjA4ICAgICAgICAiPiA8cmRmOlJE RiB4bWxuczpy
ZGY9Imh0dHA6Ly93d3cudzMub3JnLzE5OTkvMDIvMjItcmRmLXN5bnRheC1u cyMiPiA8cmRm
OkRlc2NyaXB0aW9uIHJkZjphYm91dD0iIiB4bWxuczpkYz0iaHR0cDovL3B1 cmwub3JnL2Rj
L2VsZW1lbnRzLzEuMS8iIHhtbG5zOnhhcD0iaHR0cDovL25zLmFkb2JlLmNv bS94YXAvMS4w
LyIgeG1sbnM6eGFwTU09Imh0dHA6Ly9ucy5hZG9iZS5jb20veGFwLzEuMC9t bS8iIHhtbG5z
OnN0UmVmPSJodHRwOi8vbnMuYWRvYmUuY29tL3hhcC8xLjAvc1R5cGUvUmVz b3VyY2VSZWYj
IiB4bWxuczpwaG90b3Nob3A9Imh0dHA6Ly9ucy5hZG9iZS5jb20vcGhvdG9z aG9wLzEuMC8i
IHhtbG5zOnRpZmY9Imh0dHA6Ly9ucy5hZG9iZS5jb20vdGlmZi8xLjAvIiB4 bWxuczpleGlm
PSJodHRwOi8vbnMuYWRvYmUuY29tL2V4aWYvMS4wLyIgZGM6Zm9ybWF0PSJp bWFnZS9qcGVn
IiB4YXA6Q3JlYXRvclRvb2w9IkFkb2JlIFBob3Rvc2hvcCBDUzMgV2luZG93 cyIgeGFwOkNy
ZWF0ZURhdGU9IjIwMDktMDYtMDRUMTE6MTQ6MzErMDI6MDAiIHhhcDpNb2Rp ZnlEYXRlPSIy
MDA5LTA2LTA0VDExOjE0OjMxKzAyOjAwIiB4YXA6TWV0YWRhdGFEYXRlPSIy MDA5LTA2LTA0
VDExOjE0OjMxKzAyOjAwIiB4YXBNTTpEb2N1bWVudElEPSJ1dWlkOkU5QTky QjAwRTg1MERF
MTFBQjlBQzJENzM1MUU1RTc0IiB4YXBNTTpJbnN0YW5jZUlEPSJ1dWlkOkVB QTkyQjAwRTg1
MERFMTFBQjlBQzJENzM1MUU1RTc0IiBwaG90b3Nob3A6Q29sb3JNb2RlPSIz IiBwaG90b3No
b3A6SUNDUHJvZmlsZT0ic1JHQiBJRUM2MTk2Ni0yLjEiIHBob3Rvc2hvcDpI aXN0b3J5PSIi
IHRpZmY6T3JpZW50YXRpb249IjEiIHRpZmY6WFJlc29sdXRpb249IjcyMDAw MC8xMDAwMCIg
dGlmZjpZUmVzb2x1dGlvbj0iNzIwMDAwLzEwMDAwIiB0aWZmOlJlc29sdXRp b25Vbml0PSIy
IiB0aWZmOk5hdGl2ZURpZ2VzdD0iMjU2LDI1NywyNTgsMjU5LDI2MiwyNzQs Mjc3LDI4NCw1
MzAsNTMxLDI4MiwyODMsMjk2LDMwMSwzMTgsMzE5LDUyOSw1MzIsMzA2LDI3 MCwyNzEsMjcy
LDMwNSwzMTUsMzM0MzI7MDI3MjA4MkNGM0FCRjQ1REQyRTIyMDQ2NUVGNDk2 NDMiIGV4aWY6
UGl4ZWxYRGltZW5zaW9uPSI0NDEiIGV4aWY6UGl4ZWxZRGltZW5zaW9uPSIy MzgiIGV4aWY6
Q29sb3JTcGFjZT0iMSIgZXhpZjpOYXRpdmVEaWdlc3Q9IjM2ODY0LDQwOTYw LDQwOTYxLDM3
MTIxLDM3MTIyLDQwOTYyLDQwOTYzLDM3NTEwLDQwOTY0LDM2ODY3LDM2ODY4 LDMzNDM0LDMz
NDM3LDM0ODUwLDM0ODUyLDM0ODU1LDM0ODU2LDM3Mzc3LDM3Mzc4LDM3Mzc5 LDM3MzgwLDM3
MzgxLDM3MzgyLDM3MzgzLDM3Mzg0LDM3Mzg1LDM3Mzg2LDM3Mzk2LDQxNDgz LDQxNDg0LDQx
NDg2LDQxNDg3LDQxNDg4LDQxNDkyLDQxNDkzLDQxNDk1LDQxNzI4LDQxNzI5 LDQxNzMwLDQx
OTg1LDQxOTg2LDQxOTg3LDQxOTg4LDQxOTg5LDQxOTkwLDQxOTkxLDQxOTky LDQxOTkzLDQx
OTk0LDQxOTk1LDQxOTk2LDQyMDE2LDAsMiw0LDUsNiw3LDgsOSwxMCwxMSwx MiwxMywxNCwx
NSwxNiwxNywxOCwyMCwyMiwyMywyNCwyNSwyNiwyNywyOCwzMDtERDhERkJD NjU2QkY3OTM3
NDk2OTlBQUUxM0VFNjJDQiI+IDx4YXBNTTpEZXJpdmVkRnJvbSBzdFJlZjpp bnN0YW5jZUlE
PSJ1dWlkOkU4QTkyQjAwRTg1MERFMTFBQjlBQzJENzM1MUU1RTc0IiBzdFJl Zjpkb2N1bWVu
dElEPSJ1dWlkOkU4QTkyQjAwRTg1MERFMTFBQjlBQzJENzM1MUU1RTc0Ii8+ IDwvcmRmOkRl
c2NyaXB0aW9uPiA8L3JkZjpSREY+IDwveDp4bXBtZXRhPiAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgICAg ICAgICAgICAg
ICAgICAgICAgICAgICAgICAgICAgICAgICAgICAgIDw/eHBhY2tldCBlbmQ9 InciPz7/4gxY
SUNDX1BST0ZJTEUAAQEAAAxITGlubwIQAABtbnRyUkdCIFhZWiAHzgACAAkA BgAxAABhY3Nw
TVNGVAAAAABJRUMgc1JHQgAAAAAAAAAAAAAAAQAA9tYAAQAAAADTLUhQICAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFjcHJ0AAAB UAAAADNkZXNj
AAABhAAAAGx3dHB0AAAB8AAAABRia3B0AAACBAAAABRyWFlaAAACGAAAABRn WFlaAAACLAAA
ABRiWFlaAAACQAAAABRkbW5kAAACVAAAAHBkbWRkAAACxAAAAIh2dWVkAAAD TAAAAIZ2aWV3
AAAD1AAAACRsdW1pAAAD+AAAABRtZWFzAAAEDAAAACR0ZWNoAAAEMAAAAAxy VFJDAAAEPAAA
CAxnVFJDAAAEPAAACAxiVFJDAAAEPAAACAx0ZXh0AAAAAENvcHlyaWdodCAo YykgMTk5OCBI
ZXdsZXR0LVBhY2thcmQgQ29tcGFueQAAZGVzYwAAAAAAAAASc1JHQiBJRUM2 MTk2Ni0yLjEA
AAAAAAAAAAAAABJzUkdCIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAWFlaIAAAAAAAAPNRAAEAAAABFsxY WVogAAAAAAAA
AAAAAAAAAAAAAFhZWiAAAAAAAABvogAAOPUAAAOQWFlaIAAAAAAAAGKZAAC3 hQAAGNpYWVog
AAAAAAAAJKAAAA+EAAC2z2Rlc2MAAAAAAAAAFklFQyBodHRwOi8vd3d3Lmll Yy5jaAAAAAAA
AAAAAAAAFklFQyBodHRwOi8vd3d3LmllYy5jaAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAABkZXNjAAAAAAAAAC5JRUMgNjE5NjYtMi4x IERlZmF1bHQg
UkdCIGNvbG91ciBzcGFjZSAtIHNSR0IAAAAAAAAAAAAAAC5JRUMgNjE5NjYt Mi4xIERlZmF1
bHQgUkdCIGNvbG91ciBzcGFjZSAtIHNSR0IAAAAAAAAAAAAAAAAAAAAAAAAA AAAAZGVzYwAA
AAAAAAAsUmVmZXJlbmNlIFZpZXdpbmcgQ29uZGl0aW9uIGluIElFQzYxOTY2 LTIuMQAAAAAA
AAAAAAAALFJlZmVyZW5jZSBWaWV3aW5nIENvbmRpdGlvbiBpbiBJRUM2MTk2 Ni0yLjEAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAHZpZXcAAAAAABOk/gAUXy4AEM8UAAPt zAAEEwsAA1ye
AAAAAVhZWiAAAAAAAEwJVgBQAAAAVx/nbWVhcwAAAAAAAAABAAAAAAAAAAAA AAAAAAAAAAAA
Ao8AAAACc2lnIAAAAABDUlQgY3VydgAAAAAAAAQAAAAABQAKAA8AFAAZAB4A IwAoAC0AMgA3
ADsAQABFAEoATwBUAFkAXgBjAGgAbQByAHcAfACBAIYAiwCQAJUAmgCfAKQA qQCuALIAtwC8
AMEAxgDLANAA1QDbAOAA5QDrAPAA9gD7AQEBBwENARMBGQEfASUBKwEyATgB PgFFAUwBUgFZ
AWABZwFuAXUBfAGDAYsBkgGaAaEBqQGxAbkBwQHJAdEB2QHhAekB8gH6AgMC DAIUAh0CJgIv
AjgCQQJLAlQCXQJnAnECegKEAo4CmAKiAqwCtgLBAssC1QLgAusC9QMAAwsD FgMhAy0DOAND
A08DWgNmA3IDfgOKA5YDogOuA7oDxwPTA+AD7AP5BAYEEwQgBC0EOwRIBFUE YwRxBH4EjASa
BKgEtgTEBNME4QTwBP4FDQUcBSsFOgVJBVgFZwV3BYYFlgWmBbUFxQXVBeUF 9gYGBhYGJwY3
BkgGWQZqBnsGjAadBq8GwAbRBuMG9QcHBxkHKwc9B08HYQd0B4YHmQesB78H 0gflB/gICwgf
CDIIRghaCG4IggiWCKoIvgjSCOcI+wkQCSUJOglPCWQJeQmPCaQJugnPCeUJ +woRCicKPQpU
CmoKgQqYCq4KxQrcCvMLCwsiCzkLUQtpC4ALmAuwC8gL4Qv5DBIMKgxDDFwM dQyODKcMwAzZ
DPMNDQ0mDUANWg10DY4NqQ3DDd4N+A4TDi4OSQ5kDn8Omw62DtIO7g8JDyUP QQ9eD3oPlg+z
D88P7BAJECYQQxBhEH4QmxC5ENcQ9RETETERTxFtEYwRqhHJEegSBxImEkUS ZBKEEqMSwxLj
EwMTIxNDE2MTgxOkE8UT5RQGFCcUSRRqFIsUrRTOFPAVEhU0FVYVeBWbFb0V 4BYDFiYWSRZs
Fo8WshbWFvoXHRdBF2UXiReuF9IX9xgbGEAYZRiKGK8Y1Rj6GSAZRRlrGZEZ txndGgQaKhpR
GncanhrFGuwbFBs7G2MbihuyG9ocAhwqHFIcexyjHMwc9R0eHUcdcB2ZHcMd 7B4WHkAeah6U
Hr4e6R8THz4faR+UH78f6iAVIEEgbCCYIMQg8CEcIUghdSGhIc4h+yInIlUi giKvIt0jCiM4
I2YjlCPCI/AkHyRNJHwkqyTaJQklOCVoJZclxyX3JicmVyaHJrcm6CcYJ0kn eierJ9woDSg/
KHEooijUKQYpOClrKZ0p0CoCKjUqaCqbKs8rAis2K2krnSvRLAUsOSxuLKIs 1y0MLUEtdi2r
LeEuFi5MLoIuty7uLyQvWi+RL8cv/jA1MGwwpDDbMRIxSjGCMbox8jIqMmMy mzLUMw0zRjN/
M7gz8TQrNGU0njTYNRM1TTWHNcI1/TY3NnI2rjbpNyQ3YDecN9c4FDhQOIw4 yDkFOUI5fzm8
Ofk6Njp0OrI67zstO2s7qjvoPCc8ZTykPOM9Ij1hPaE94D4gPmA+oD7gPyE/ YT+iP+JAI0Bk
QKZA50EpQWpBrEHuQjBCckK1QvdDOkN9Q8BEA0RHRIpEzkUSRVVFmkXeRiJG Z0arRvBHNUd7
R8BIBUhLSJFI10kdSWNJqUnwSjdKfUrESwxLU0uaS+JMKkxyTLpNAk1KTZNN 3E4lTm5Ot08A
T0lPk0/dUCdQcVC7UQZRUFGbUeZSMVJ8UsdTE1NfU6pT9lRCVI9U21UoVXVV wlYPVlxWqVb3
V0RXklfgWC9YfVjLWRpZaVm4WgdaVlqmWvVbRVuVW+VcNVyGXNZdJ114Xcle Gl5sXr1fD19h
X7NgBWBXYKpg/GFPYaJh9WJJYpxi8GNDY5dj62RAZJRk6WU9ZZJl52Y9ZpJm 6Gc9Z5Nn6Wg/
aJZo7GlDaZpp8WpIap9q92tPa6dr/2xXbK9tCG1gbbluEm5rbsRvHm94b9Fw K3CGcOBxOnGV
cfByS3KmcwFzXXO4dBR0cHTMdSh1hXXhdj52m3b4d1Z3s3gReG54zHkqeYl5 53pGeqV7BHtj
e8J8IXyBfOF9QX2hfgF+Yn7CfyN/hH/lgEeAqIEKgWuBzYIwgpKC9INXg7qE HYSAhOOFR4Wr
hg6GcobXhzuHn4gEiGmIzokziZmJ/opkisqLMIuWi/yMY4zKjTGNmI3/jmaO zo82j56QBpBu
kNaRP5GokhGSepLjk02TtpQglIqU9JVflcmWNJaflwqXdZfgmEyYuJkkmZCZ /JpomtWbQpuv
nByciZz3nWSd0p5Anq6fHZ+Ln/qgaaDYoUehtqImopajBqN2o+akVqTHpTil qaYapoum/adu
p+CoUqjEqTepqaocqo+rAqt1q+msXKzQrUStuK4trqGvFq+LsACwdbDqsWCx 1rJLssKzOLOu
tCW0nLUTtYq2AbZ5tvC3aLfguFm40blKucK6O7q1uy67p7whvJu9Fb2Pvgq+ hL7/v3q/9cBw
wOzBZ8Hjwl/C28NYw9TEUcTOxUvFyMZGxsPHQce/yD3IvMk6ybnKOMq3yzbL tsw1zLXNNc21
zjbOts83z7jQOdC60TzRvtI/0sHTRNPG1EnUy9VO1dHWVdbY11zX4Nhk2OjZ bNnx2nba+9uA
3AXcit0Q3ZbeHN6i3ynfr+A24L3hROHM4lPi2+Nj4+vkc+T85YTmDeaW5x/n qegy6LzpRunQ
6lvq5etw6/vshu0R7ZzuKO6070DvzPBY8OXxcvH/8ozzGfOn9DT0wvVQ9d72 bfb794r4Gfio
+Tj5x/pX+uf7d/wH/Jj9Kf26/kv+3P9t////7gAOQWRvYmUAZEAAAAAB/9sA hAABAQEBAQEB
AQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAQEBAgICAgICAgIC AgIDAwMDAwMD
AwMDAQEBAQEBAQEBAQECAgECAgMDAwMDAwMDAwMDAwMDAwMDAwMDAwMDAwMD AwMDAwMDAwMD
AwMDAwMDAwMDAwMDAwP/wAARCADuAbkDAREAAhEBAxEB/90ABAA4/8QBogAA AAYCAwEAAAAA
AAAAAAAABwgGBQQJAwoCAQALAQAABgMBAQEAAAAAAAAAAAAGBQQDBwIIAQkA CgsQAAIBAwQB
AwMCAwMDAgYJdQECAwQRBRIGIQcTIgAIMRRBMiMVCVFCFmEkMxdScYEYYpEl Q6Gx8CY0cgoZ
wdE1J+FTNoLxkqJEVHNFRjdHYyhVVlcassLS4vJkg3SThGWjs8PT4yk4ZvN1 Kjk6SElKWFla
Z2hpanZ3eHl6hYaHiImKlJWWl5iZmqSlpqeoqaq0tba3uLm6xMXGx8jJytTV 1tfY2drk5ebn
6Onq9PX29/j5+hEAAgEDAgQEAwUEBAQGBgVtAQIDEQQhEgUxBgAiE0FRBzJh FHEIQoEjkRVS
oWIWMwmxJMHRQ3LwF+GCNCWSUxhjRPGisiY1GVQ2RWQnCnODk0Z0wtLi8lVl dVY3hIWjs8PT
4/MpGpSktMTU5PSVpbXF1eX1KEdXZjh2hpamtsbW5vZnd4eXp7fH1+f3SFho eIiYqLjI2Oj4
OUlZaXmJmam5ydnp+So6SlpqeoqaqrrK2ur6/9oADAMBAAIRAxEAPwDcQ/l8 f8yNyP8A4fNZ
/wC8hsv2POd/9xPb3/xWbD/BJ0GOWv7Tmf8A6W9z/hXobKzszsrJ7u37t7Ye wuvctjev9xY3
auSym9e19w7MyFbl6/Y+0N+O9Bh8J09v6nOLgxm9KWFZpK1JXqI5QYVRUdwv 9Jt8NvaS3t7M
kkyFwEiVwFDvHktNHmqE000pTPGhobu+knuorS0iZInCkvKyEkoj4CxPijgV rWtceqp6t7By
m+497UmeweFwOe2FvT+5mZp9t7nq94bfqqqTZ2z96wVeKztftfZtdURDG7yg hmSXHQNFVQyq
pkQLIzF5bQwC1ltp2kt5oy6llCNh3jIKhnHxRmlGOKcDjp+zuZZzcxzwqk8U mhgrFlyiSAgl
UPwuOKjNeIz0WL5Hx/IDorIbw716WqN59qdd7tk2y3e3Svk3BvrffWmNxKYD bmZ+QfxH2/8A
w/dmTyefwHX2Lb+8vU1FQ1VDumWkh3BtahG7483gezQLz22+pylvbctTpHvX hDw2Y6QoLqJD
q0sEbw9eh30xo1HkkijVpFNrLwTdQ/UKTDXI/LH25pUDJGACcF9+LvZVN2NW U+a6z3VQdjdK
Z/Zrboi3zh+3cn3jtefOZebbeQ2a+z+xcrVZN8jBuTa2Tr6iuoqavraKhSko ZIo6UVheuhL2
Q3zm/cOY9+2/c5r2XZobciT6mZ53iu1kRfD1yVaNipm8WHUPDdCuhdIVTfeI bVLeGSNUEpbG
kAArQ5oOIrSh8wePRk+0u2OrOjtiZ3tLuvsvr/p/rLa/8M/vL2L2lvLbnX+x Nu/xvMY/buG/
ju7t2ZLEbfxH8X3Bl6ShpfuKiP7isqooU1SSIpya6D3RYF+fHQWU7C6kpNnd kdP73+PnZ/xg
+YXygq/lXtrubZeW6a2rtX4ddmfGfrffSVO7MW+R2TXbfjqe/chPls02dpab b0m1KiCoilM0
r0Xuvden/mOfC9OwvjFsWh+Q3T+bxHzF2/3Bkvjp21g+2uqcl012purpjszp fqPOdS7G35Dv
gU2+O4Ny727spaXCYHBQ5SprJMHmIpDBUUaQz+690D/xo/ms/Fjuj4sYn5i9 pd9fEDoTpLff
YFBtTrrO5r5fddZj+Ff3n66wPaW0esfkBk9xYjrnaXS/y/odpZWom3X1fQ5T dn93Ps2eHOZS
Fmli917o4HYPyx+LHUn98P8ASt8lvj/1l/o9+6/v/wD6Qe5Outmf3H+y/wBD v3n98P7x7jxv
92ftP9mI6/8AL974PH/frb2q38axv3Puvde278sfixu/D9i7i2n8lvj/ALo2 /wBP9f7R7Y7a
zu3e5Ous3h+rurOwNiT9pbD7L7FyeN3HU0Wyev8Ae3WVNJuPEZnJvS47JYKN q+nmkpFMo917
pP73+UG1difJXYnQGaTb9HiNw9P5/sfe3ZOU3pjsRjur91Z3u/o7of4x9Y7p xNXQmmpNwfLz
e3ZG6aHYZq8jQVOfyvX2Vx+JpMpUR1f8P917pQYz5Y/FjN776t6tw3yW+P8A l+ze8ev8f2x0
p11jO5Ouq/ffcHVmXw+d3Fiuy+rdo0u45dwdgdf5Pb+18nXU+ZxNPV46ajx1 VMkxjp5WT3Xu
k/VfN34X0OO7rzFd8u/jBR4j417gxW0/kXlKrv3qmnx3QO6s7urIbFwe2u66 6bdiU3Ve4Mzv
bE1WHpKLOtQVNRlaaWkjRqiN4x7r3S/pvkL0FWbVzO+qTvDp+q2Ttzp/bXyF 3DvGm7L2XPtX
BdBb0x27Mxs7vDM7hizTYjF9P7sxGws7VYzc08yYWvpsLXywVLpR1DR+690w bj+WPxY2dt3f
+8N3fJb4/wC1dpdUfZ/6Ut07j7k66we3etf4j2nvXovH/wB/83k9x0uM2d9/ 3b1ruPZ0P8Rl
pvLurAZLErevoaqni917r2M+WPxYze++rercN8lvj/l+ze8ev8f2x0p11jO5 Ouq/ffcHVmXw
+d3Fiuy+rdo0u45dwdgdf5Pb+18nXU+ZxNPV46ajx1VMkxjp5WT3Xuif9nfz KarrD/SnnqX4
hfIDu3rLY3y/2p8OtrdnfH/dfxxy23d5b73l/sr/AFxhKyVu9O7/AI+RR+T5 dfIPMdQ1se3p
91Ue3d1dfZ1dw1uGkpqikpfde6OBj/k90nHh8nU787E6/wCod27O6/zvYvb3 WPZHanUVLvvo
jD7I2J1b2P2pB28u1OwN2bS27/od2l3ZtKt3PkabLV2CxtHuXFVgr5aDKY6r qvde6T+Z+bvw
v2501tP5F7h+XfxgwXx837uCp2nsXvbM9+9U4vprem6qOfctLV7a2n2fXbsg 2TuPcFLU7LzE
clFR101SkmJrFZAaWcJ7r3RX9q/zY/ixl+ovmBv/ADO+Ov37N+En+z57j7r+ L/XXbnXXYXyO
xHVnwX7s7Z6syu/5+sarM7N3Bgf9J+3+u8ZmsdDloaDHUku6KCjfJTRyRV9R 7r3QwbI+evUt
Vkd97X+QmC3B8IexOvNv4DfOd68+WG+fjxgcjP1nunaveO88B2Tid8dQd5dz dOZDb9Rtv4vd
m19ZQjcy7hwuK2DlsplMbQ4gUdfWe690MGT+WPxYwm++0urcz8lvj/iOzeju v8h2x3X11k+5
OuqDffT/AFZiMPgtxZXsvtLaNVuOLcHX/X+M2/ujGV1RmctT0mOho8jSzPMI 6iJn917pP7A+
ZXxq37keiNnDurp/bHcfyP6f2t3j1T0Bme7ekM33Luzr3dW1cpu+nz+09udd 9k75xHZe38fi
NvZVpM7tDIbh2zVR4isqKHJVdHAak+690D/a380j4C9O7iwu3d3fKz4//wDZ QEvxo7SztB3n
0v8A3d+Nnaf+iz5AdpY/E/JfJ5PsHF/6Hf47/stm49uUEGRT+I1W6vBQLS/8 CpaX3Xug/wDk
f/NJ6s+Lfe0/VnYvW/YGe6/j7A+MPTuQ7u63m25uPZ3XHafe+zvlN3L2lS97 PncntLC9S9f/
ABL+Mvx4xHaHYeYfLZLI4PYm+8XmqvE0uKMNfWe690IG3/5l3xYyPafzJ673 duz/AEO7S+EH
+hb/AEpfIrufO9ddffGfdX+mzcfYXXeP/wBGfbuT34+Mzn9we7eqNx9dbo/i MGJ/hXYWFrcA
vnr6Sqjh917r3zM/mSfFj4c/FjcXyX3H3b8f8x/GPj/2b3p8aNlZvv8A662J /s3H9xOuot/4
Ha3Re46+szH9+/79/wAYwlJSV2AoM7p/jtDLHT1H3EEc3uvdKD5MfPjoLoHr 35hVe3uyOn+1
vkH8OvjB238oN9fFTDdzbLxvcse1esOs17IpE3ZtOhfc+9uvNv7qpsph4I81 WYKemgjzlHOs
U4ngSb3Xuhgyfyx+LGE332l1bmfkt8f8R2b0d1/kO2O6+usn3J11Qb76f6sx GHwW4sr2X2lt
Gq3HFuDr/r/Gbf3RjK6ozOWp6THQ0eRpZnmEdREz+690T/rH+Yt2Lu/ffxU6 i3t/Lx+X/X/Z
vyb+P+0/kBP5838WF2J1dt2LD/HP/T9Fu7/SF8i+q++qX/ZY99fJnB7d3HRV 3XWL3Vkqynq5
MPgq+OFre690aDcvzd+F+y+vabtzePy7+MG0+qazcG09p0nZ25e/eqcF17Vb q371nhu6ti7a
pt6ZTdlLtufcG9OnNx4/duJolqTU5HbNfT5SnSShninb3Xug/wDmV8+Ogvh5 173VV7h7I6fz
fyD60+MHdvyg2L8VMz3NsvY3cvcm1emOs+yeyKtNp7TrnzO9n2/lqbqvMQSZ qjwWUpqGPH1k
7RSijnQe690n+2P5kPx72d8WOy/mL0XU/wCz1dJdLf3yrO4s78Ku0vjP2j/o 1271z11ku0uw
dx5/J7w76622lX/3O2lS0k1VhMXlMjuqX+L0L02KnhleWL3Xuhgpflv1LtzH dKUnyJzG3/h1
2t8g9wZXafVPx8+TPbvx4293LvTdWN3Vj9qU+2tnY/rvuXszZPYu4MxU5/DT 01FtfO5ypSPP
Y+CpSnrpzSJ7r3Qf/IT+Y58L/jPPvfD9lfIbp+Pe3Ve4Oi8b2/1jje2uqU7M 6b2r393L0v0r
trtrtrZef3xgcv150/tbL9+bczGez2UWnpqHb1WKuIVDy0sFR7r3Qf4z+Zp1 LnezNw7c251b
3BunonbHcHx86IyHzU2nlvjxur4wVnZnyr69+PO/vj5i9tf3e7+yfyD3nt/s 2T5Wdf4ei3Bh
9gV23ochuFKmproMPS12Vpfde6MBuX5u/C/ZfXtN25vH5d/GDafVNZuDae06 Ts7cvfvVOC69
qt1b96zw3dWxdtU29Mpuyl23PuDenTm48fu3E0S1Jqcjtmvp8pTpJQzxTt7r 3Xtz/Mr41bE3
V33t7sPurp/rvEfGPb/TGZ7y31vnu3pDbm1er8j3xkdx0PX20+yaSu7JTe3V e4MzTYnG1lDJ
uvD4PFZ+m3JjVwdZlahclBj/AHXulBm/lj8WNs/6C/7x/Jb4/wC3/wDZoP4R /stH8b7k66xX
+zEf3g/ut/Af9Bf3+44P9Lf8b/vxhPtP4B/EPuf4xQ+PV93B5Pde6T/w8+Yf QXzr6C2J8i/j
pvvb+9Nk702/tfJZTF43dGy9x7q6u3VuPZe2N9V3UvbVDsXc+78RsnuDZOI3 fQx57AyV0tTj
amUKxZGjkf3XulBu75Y/Fjr/AGJt3tLfnyW+P+yest39fwdsbT7F3d3J11tv Ym6OrKnMddbd
puy9u7uzO46Lb+b6/qNwdwbSoUzNNUS456zdOIhExkyVEs3uvdA/2R8+OgsH stNz9M9kdP8A
yLy9H3B8B+uN1bV6x7m2Xncjs7av8wPv3pnqLqLs7cB2q+8anHbfzmye3hvP bYqaanpt34qg
AoquOnqPvofde6O/7917r3v3Xuve/de697917r3v3Xuve/de697917r3v3Xu ve/de697917r
3v3Xuve/de697917r//Q3EP5fH/Mjcj/AOHzWf8AvIbL9jznf/cT29/8Vmw/ wSdBjlr+05n/
AOlvc/4V6Av5bfBCh+QG/M5uTfvQHw5+Qe1qveFFntmJ8kOsqTtHcGxMpujZ PU/WW46Tb2Ny
3S3Z0eAxmbqOtsbVZGtpZ6eFqeCOStCQ0XmUH3X0t5b7esm4z28kMRjISBZQ 1ZZJA1TPER/a
UI0kCmrVQ4N4lvLW4vnis4Zo5pA4LTNGRSONCKCGQH4Kg6hWtKYyaD4r/G2L pTYFVtfdW0up
qGSn3LjqvZ22+usJTrsrr3aW3No9VbW2rtPZ9NU7Y2xFhMVhX6lxdVTUlHQU lLRPR0iwreki
cN3P05h262jkaUW8RXW6BGYtNJNXSHk00LgfGalQ2OAdtUnWS+nmREaaUNpV i4UCKOKmoqhN
dBPwimqmaVNN3z66K7tr/lBvaql6D3h21sbIYbr/ABfxaq9j9Xb033R9Y4DD bA25hsntLr/c
myGhwfxm3zS9n0WUyLbhr59uRPSV2Odcm0VAUoZn5E3LlO15cW3u7pILtC/j KWRBIKtpqrVM
y+H2BFBoaroq9Xhjn3bOcrrmRZ9stzLYsE8M6GfQQF1UZaCI6+7Uc/irQdpM Pk18Xvl78c+z
sd2LvjobfnylwG7Nq9W7qqdq9MdN9n9y5bqDuSfqLaL/ACT7p+M9V1bSVFN0 X3V2D8lk3ZvT
fTIu3V3ymdizeEq6jd8eWxW7MVedbKfceZN0bb7F/oWkJtGCsQsZNRE1KiJt WVkZgQTpdjGQ
8XTn2E5s5U5V9tdiO48xW8V8ocbvbSTQxyvLVwt3CstHvYxblIprONZBIE8W 1jW7R4Nwut+T
FJ3n2T/LL+MmT2C+z/lT3vN2h/KL7N/vBsPcORm6o7g3Bs75rfDrszeXZ1Lv 7rraHaFRhOj8
nQ4Cv3HkN043B5ymw+1FnyopamnpyjDGxW4Sys0umrdCJA5rWrhRqNfPNc9Y q80T7TdczcxX
OwReHsUl/cNbLp06YGlcwrpOVpGVGk8OHQIZn+Xp80N09y9ofKKn330/1B2t 3bt/5C12+ut+
tu3u1q3HYOfsCD+T51xSdIbJ+TFD051x2Tgtv969E/yzNzY3Odp4jae395dV ZXsamrNtYjN1
234MnVKuiLr3xA/l8/K744fIeq+TldhOn6jL7u7g7twu4epNy/N75VfJfI7R 6C+QvUv8sDZG
6+y6b5a/IPoKv7j7k7g2FuT+XZVS4nY+dwmJwtdit3U9JHuzD0+Ehp6v3Xuh g6w+Hfyn+NvV
n8tDL9W4z4/9vd2/Cv4AV3wY7F6+3/3B2L0v1Zub+++3PhvVbu7R2V3Ft34+ d4btqf7p7t+H
dPQ43CV2xaH+NY7c8ldNX4ybFrj8l7r3QP8AQn8ordXx86C3p1Fg9xdP7o3t kfk//Js3tQ9z
SYDI7O3VvzoL+V/sv+WftjKYPfiUmD3Nl8PuCuy/xL7Gyu0ttplc7hcdU7vh 15OmfIZOan91
7oQKT+X737txM/mMXD8YOwsuvT/8+TaeD2F3RHvTdnTW9N1fzNPnn118rfjp truDa1PsyCp3
H0/S7J2XPh+zqKFvuUkqmpMYmUp5Gq0917r3fPw83V80+2vnEm6tibfx+ya7 uD+UX0G+zO69
r5HI9Z9+9BfBr5D7L/mH9zdhY+fI7YyWI3nt/s3EfKzd/VsW3zja/CncOwJ0 rssEyVbS4P3X
uvb+/lt743N82t/d0Gj2/vHqnt/5P/Gn5Y53N7l+ZHza6/x3V+6vjVsf407Y wGyqb4BdQZrb
Pxc+SW4KvOfFLFZvE9gbv3RiqnB5XcFO1dt3cFDtCjxu4Pde6D/qL4C/NDqb b/S2V2xU9P4T
a3w67g2Bvb4f/Afcvyp7W7u6a2FtXDfGD5V/Fzf+Dpvnvvn4iYP5R4Db+6cH 8q6fNYnbe49l
dmU21JOu6fC4bJ0OC3DBR7O917oP9/8A8tD5oYTpD5n7M6ij+MG+97fzGPjB 8gelO5qTsfur
tbqnavxn3V3n8lf5jHycTIdY7i2x8Z+5Mv8AJjb+2Mv/ADJMrt4y5XEdX1NZ TbBpMn4IH3HN
jdve690aDAfAbtPqPYmw929S4D4/5XvrrL+Z/wDOT+YVU7Xye4dx9W7E7+/2 a3MfN3rPaeM7
S7n211Bv/ee2OwNi/HL5WYE1GVbZu7fJWbFpdtQsuMkp83Q+690H+S/lydxb y+WOZ7033trr
+u2/3V8gPih8uuzooPnb87KPYnSXafxw62+MG3W6x2j8M+uMb058cvl99tvP 4qUGU252lvmr
2hkaKsztJU5LZ2UpNp0mFznuvdCB1B8aO0+2f5c/Q2EqcT/ow7N7W+X/AER/ Mm351v2lQbj2
tmOnP9In80PZn80ntr4852GTA1G4K3sDp/b+by2xaWprcXhv43ncVFUVlJgo 6qaCg917pf53
4Vdp4+q/mX786tz/AF/sbuD5n/IDofsTbW+du5Xcexd97u6J6V+OPxP6ozPx 07F7t2ntX/Sb
0v8A6Ra3qzsnBYjd21Dnsx1lR9gtuzb8b7gjehHuvdEA2d/LD+a+zqrfO/8A rk9f9D/I3fny
A7W3b118jcf/ADJvl38qN9/E7qztX44/Aro7dyZPG/Kn4k7s2/8AzF/77bg+ JM+brtkdpw7e
x2Bo8fhKPbW4sNkY6TO7f917oYPk/wDyv+/e6vhfVfHTau7+n6De0/yf/nDd 1plNwZ/elLtU
bV/mC9U/zZdi9M49q7Hdf5XLjcG2cv8AO/aEm54hQmmoqbHZhqGfIvT0UeQ9 17oz+7/5ZfUS
9i/ELdeytvf3zoulPl/hPkh2vuD5Qdu92fKLtPcmH63+LHy56x6Ow+1Ox/kb uTuzfU3+hjvr
v/G7v2rhJszjMFtbIy5rOYoU+aq5jkPde6QGA+LHdnUu+9h5XfKdf1Hxl+I3 y/8AnJ/MV212
J11Xdu9ofI7trMfKXD/N3LZnoyf4n7T6Pqf4D/o8/wBnjzcWOzG29676zu7Z dlUEVNtmlqdy
PT4H3XuiP/DT+UT3n1pt/wCLidp7W2/U0w2//LT7g7ipdy/Nv5hbax3Rvcvw p+MHw06syHVt
N8G/j9uqg+Hnyo3BR78+HdFk8T2TuDedJHi8rnKeafBbkxu0aGg3F7r3RwOv fiJ80Ot+jPhH
1XQ7T+MG4cv/ACudwdU03x0yNV8he1sFjvl5tXZXw9+QXwezmZ7r8PxQzlT8 PNwSbJ7kpd7U
mMwSd0U02Vo5dvSV8NOybh9+6917anw83V8it/ZTuXsrYm38Xsndv81/5Td1 9v8AQvde18jU
QZ/oLrz+Xp3z/Jo21j8fiM/tiqxHaO3/AJI4jZO3OzYospQYrCvs3ec9FFPl UoqWtzXuvdJ+
s/lkdp9N97dTd4/G/Ldf9hf7Lb1/8TqXYm1+/Oxdx7L3j8i+0+s9nfzaus/k J2D8ie59h9J7
+/gHYHa3/DmS9j5PeNHtPc2R3pvvGZiHJY/G/wAWGbh917oH9/8A8tD5oYTp D5n7M6ij+MG+
97fzGPjB8gelO5qTsfurtbqnavxn3V3n8lf5jHycTIdY7i2x8Z+5Mv8AJjb+ 2Mv/ADJMrt4y
5XEdX1NZTbBpMn4IH3HNjdve690n+4P5OHcW/cP8stgYaTr/ACFF2R/w5v2P 0p2/2L80vnZu
DD0faf8AMF2J8tsBitswfAallh+Ivxw/0by/MHJ4XI9i4mbsHI53BYavrE2t R5rdstXtz3Xu
hA7/APh38p8J1187uuNm4z+5Pxl+ZX+lP48Y3oLrTuDsX5d+fsX+Zh8p9r9c dsfzFclhuy/j
5152B8ZP9l+6/wC19y7/AN2dRbT3ruLqzOfdZGohqdp1NDkdx573XurX92dK bqzvzQ6C+RdJ
kNvx7J6r+MHy76U3Di6mqyKbqrN1d/drfCLfWzshhqGLFTYio2/jcR8a87Hk 5Z66nqYamroF
ggqElqJKX3Xuq4MJ/Lw+QnUHwe/l9/GLqYdf1tF8Zfj/AITrvvfo/q35cfJj +XXsTsvvao2l
18+d+ReC+U/xE6uy/fWX/hG+sRveaq2jkdvUWH39WdjS7kzkkOa2/jYqj3Xu iv4b+Ul80Nu/
Fvdnxd663j0/0riOwP5cFN8Z/kLnMN8je1u3+vfmN37hv5Y+2vgxsHJbs6E7 L+LdLTfEfb/W
e9sFislHvzrDdgzW7ds7Po6Pc+1srUZCiO1Pde6sf+WPwq7T73/4c5/ujn+v 8d/s6P8ALA2D
8Kurf7x5XcdH/Ae09q/8OE/xDP7/AP4ZtXMfwvr+b/ZsdueGqx38VyLfZZLV Qp4aX7z3Xugg
+eH8tvfHye793z2NgKPb+9dk9/8Axg64+J3aG2t2fMj5tfFravXm1dgb0+Rm drN67l6g+IOa
25iPnnt/emI+TtfT1vX+8Ny9d01JTbbeio9xQpunIVWI917pP7g/l+/KfKbn 71pdibi6/wCm
OhZPkBtr5YdY/Gyf5B9i/IPYnevyY2V/ME6k+eK9u7u3Z2P8cNs9m/BD/SvW 9Q1+3tx7R2Nm
O0evcdWdhVe4cbt8ZPB1Y3n7r3Q/9KfAClqvkB8g/lJ8mcV9/wBgdvfIDpfv rafU2xvk38jt
7/HHZ2Y61+IHxH6qppt1dI5k9UdAdqdgdc9/9G5jO7U3hmevpc7BFQ7bzMMm LyuPo6PD+690
EHRXwP79+HPTX8tkfHzY3xg3l2t8N/hBvv4ido9U5nsfenx66a3hurvSf4od h90d77T7U2T8
c+5tyZDcFR3H8XqirkoMjsOiqd1yb1rMxXZKgrqJqPK+690T+p/lZdtVe9Ot NkbDq9wbzxH8
v34wfyruiNp7rzPanyH+AGO+TPZnxd6C/mbdO9n4vafyB6CG8O9untv4brb5 77S3dJuDaNFv
Hb2XytPWbDmrpKiPc0uD917o8Hxa+F/yE+HPZOF3r1fsn4/7o2/3R1/19sD5 D7U3F8lfkx/G
OkP7vfLH5l/KDdG9euu0+3Ou/kt2b81uwN1Vvzoz8OXyW8sl1Z/HM7tZcrHH iKTcv8F2p7r3
Q/8AxC6d+U/xw+PfxG+NGQpfj/PtL40/3Q+PW7t60e8Oxdybi7Z+LHTXxnze wOuu29ubcn6+
2RjOofkBvzu3B7Wq83syqr95bcwG1TlYqXcuWr2pJI/de6rgx38tD5oVyfA7 q7cMfxgxPVP8
vDp/479B7F7Kw3dXa2f7C792r0d88/5UPyCq+wt2dR13xn23tvo7cG4unP5d 2YePb9HvTfFN
T7m3HR41stJQwT5k+690IG7P5X/fud3J0FmKTd/T8dN1X8n/AJd917hSpz+9 EnrNq9/fz9/h
F/NR2dj8MsXX80dRuDG/Hz4153D5OKdqemh3lV0FJBPUY2Woy1L7r3V73v3X uve/de697917
r3v3Xuve/de697917r3v3Xuve/de697917r3v3Xuve/de697917r3v3Xuv/R 3EP5fH/Mjcj/
AOHzWf8AvIbL9jznf/cT29/8Vmw/wSdBjlr+05n/AOlvc/4V6N5vOo+2w9HJ 9z9pq3ZsKn8v
338P1/d7527S/bfcf3o2h5PvfN4fB93L915PD9lkvJ/DqqP5TRRmncvy/EPm P8OeFG+EileP
5H/B+f8Aq9OPSs9udV6QHYHYEGwoNtKNt7j3fmN37jO1tubc2u224cpksrFt zcW7aoCr3duP
am3qOnpNv7Urqh3qK6HV4hHGHldEZXaWhuzOTOkcUaa2Z9VANSoMIrsas6jC njU0AJ6S3V0L
UQ/ovJJI+lVXTUnSznLsqiiqxyw4UFSQOg+2n2nlaHN7a2hvLrDsrZtRvndW 7aLbmc3Pkeuc
riqjJTUu8OxIMDIu2+6+0Nx0klJtXCVapIYosYrUgjgSihemo43TtqLb3EsG 5wT+GNTBBMCF
Zwtf1I1BozqKBvPCgCgZXcHM8EM+3zQ+IdKljEQWCM1P05HIqqMakUxQmpyk vlr8kct8atsd
a5nB7Cp+wcp2R2nH1pS42qr+yKWDFX627K7HnzT0fUXTHfnYea0U/XL0opsf tup0GrFRPLBT
QTSqdcp8uRcyXW5QzXxt47a18YkCElv1oYdNZ7i1iXM2qrzD4dKhmYDok5u5 lk5ZtdtnisRP
JcXXggEzAL+jNNqpBb3Urf2OmiQn4tTFVUnoAerv5ilLmc3uvFdy9Mdk9eUG LxW1chtTcvXX
TPzZ7awm66vMVe7KbcmCqoNw/Cvp7ce3MrtCHCY6od3x9TRV0OaiEFQZaeqj jP8Ac/buSGG1
l2fd7e4kZnDpNcbdAyBQhRgU3G4R1k1OBRwymM6loykhza/cq3mnuot52ue3 jVEMbwwbjOsh
YyB1Ifbrd0aPShNUKsJBpaqsAdHqDvDrnvXEbjzXXGQ3FV020N0vsrc1Huvr /sLrPP4Tcybc
23u8Yyv2t2ZtbaG5ofNtnd+NrYpvtPt5oatDHIx1BQZu+ybjsU1vBuUcavNF 4iFJYplZNbx1
DwvInxxupGqoKmo6G+zb7tm/wXFxtksjRxS+G4eKWFlfQkmkpMkb/BIjA6aE MKHj0ut2bs2r
sLau5d9b63Lt/Zeydl7fzO7N47x3Zmcdtzau09q7cx1TmNw7l3LuHMVNHiMF t/BYijmqq2tq
poqalponlldUVmBT0b9Eg3N/NH+CezuiflH8l9x95/w7pL4XfIDcHxc+S+9f 9GXcVZ/o1722
rvHY2wM9sb+7lB19Vbt3j9hu3srCUn8TwFBlcPL975Y6t4YZ5Ivde6P/AO/d e6B/C917Vzvf
vZfx0pMfuCPe3VfT/R/de4cpU0uOTatZtXv7enyF2Ls7H4auiys2XqNwY3L/ ABrzsmTinoae
mhpqugaCeoeWojpfde6YKv5L9WYjuzsLovcuW/ufuDrfr/4xb/yu6d3V+3Nv 7Ey/+zd9u92d
F9KbK27m8hno62v7A3F2b0dW4tMbJSQfd1mZxFNQSVlXVvTwe690P/v3Xuig fHv50fH/AOUG
+9+dbdSw/ID+9vV+qDsKm7S+Hfy/+P8Ah9n5j+D7E3LDtHO7s7+6K6y2lRdg Vu0uzcDm6Xbj
V38dq8Fk4snDSSUGqoX3Xujf+/de6B/svuvavVe9Pj1sXcOP3BWZf5KdwZrp TYtRhqXHVGOx
O6sF0F3h8i6vIbsmrsrjqmh2/JsnoLMUsctHDX1JytTRxNAtPJPU0/uvdBB8 hPnR8f8A4v77
2H1t21D8gP729oaYOvabq34d/L/5AYfeGY/g++9yzbRwW7OgeiuzdpVvYFFt LrLPZuq24td/
HaTBYyXJzUkdBpqG917o3/v3Xug/yXaWxMR2ns3pTIZ37fs3sDr/ALL7S2jt r+GZiX+L7E6f
3H1PtPsXO/xmDHybfoP7u7g7x2tT/a1VXDWVf8U10sU0dNVvT+690AHxo+d3 xn+XP8J/0Jbo
7Aqv7z9f0HbGw/8ASh0B8hPj3/pV6sr/AOA6uy+mP9mE6s6u/wBNPX+J/vdg /wCKZnan8Zx2
H/vFhvvpqf8AjOL+7917o3/v3Xuk/trcuO3ZjqnKYum3BS01LuDdm2pYty7T 3VsvItkdl7qz
OzsxU02H3jhsFl6zb9Zl8FPNictDA+Kz+KenyeMqKzG1lJVz+690n+y+0tid P7dxu7Oxc7/d
3b+X7A6n6tx+Q/hmYy/3G++8e09m9KdW4L7XBY/J1sX96OzewMRjPunjWjov u/uKuWnpIpp4
/de6ADK/PX4nYTcXzV2nk+1vttwfy7ev9q9pfMXH/wBxuyZv9D+xN7dWZ/uv bGd+6p9nS0XY
H8T6y2vXZP7Xa0mbrIfB9vLFHVvHA/uvdD/1P2lsTvHqzrTuvq3O/wB6Osu4 Ov8AZvaXXW5f
4ZmMJ/eLYnYG3MbuzaOd/g24sfiNwYj+L7fy9PUfa11JS1lP5NE0Ucisg917 pP5ruvauC796
0+OlXj9wSb27U6f7w7r29lKalxz7Vo9q9A70+PWxd44/M10uVhy9PuDJZf5K YKTGRQUNRTTU
1JXtPPTvFTx1XuvdezXde1cF371p8dKvH7gk3t2p0/3h3Xt7KU1Ljn2rR7V6 B3p8eti7xx+Z
rpcrDl6fcGSy/wAlMFJjIoKGoppqakr2nnp3ip46r3Xuhg9+691737r3Xvfu vde9+691737r
3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9 +691737r3Xvf
uvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691 /9LcQ/l8f8yN
yP8A4fNZ/wC8hsv2POd/9xPb3/xWbD/BJ0GOWv7Tmf8A6W9z/hXo3m86j7bD 0cn3P2mrdmwq
fy/ffw/X93vnbtL9t9x/ejaHk+983h8H3cv3Xk8P2WS8n8Oqo/lNFGady/L8 Q+Y/w54Ub4SK
V4/kf8H5/wCr049Kz251XorPyy2FvDf+ydrUezdubh3VPjN15985iNndgVfV e8m25uvp7tXr
PIVu0ewsXu7YWf2fuLHT78hnpsli8zjctj2Q1NFPHUxRH2vs3TwNztzOkUk0 AVWcPoDCaKTu
0I7UKowFFOaA0GQgvUkMu3TpA8ixTFmVSoYgxSpjWyLguK1YYrSpwSRfG/4o dl7G7X2rWZHY
vyM27sxcrlstuvM91fOTuz5M1lJEnVvamx8XT7Eqe1vkx3Vufr/KVdb2NqqJ 9v8A8KapWGKS
pmeSjo/G3bW5s4d0+o3O1l8a3EarCJw1fGhkJJeGIABY2yG1VIoMkjU0j3U+ 3eHt9xEsU5dm
kMNKeDKlAI5ZCSWcfhpStTwBNd8p+vt7SZL46b262673321P1x8iH35vLae3 98bZjzabUrul
vkltOTI4GDuPsrZGzY3pd3dtUkTwQV9POMeYoY0aloKeGAScnXO3WjcxwX+5 Ja/Vbf4aPIJn
TxBd201CIo5nFVjehCUwFJAp0HOc7PcbteW59v22S6NruIlkSNoUfw/pbmIk GaSJDRpExrrk
kA56Kx2vhvlJ2Nu9dyYz4497bdpMDSUTdZ01ZjfjBlMx1nueMxzZLf2FyWC/ mW7Mwea3jlWQ
0Dy5TE1lH/duWswbUz4zM7igzQ22+/5csrYQvzPZMzE+LT6wLMnARsG2iRhG K6gEdT4oSYMJ
IbdoQXuVjzNfXTTx8tXqIqjwaiyZoX4mVWXeI1aRvhJeNl8IvCVMU1wsxvPi Ltzs3Fj5B7r7
S6+zfW2W7O7twO8cTgtxVWwZcpW4zD/Gn479X5TPNj+uezO3sBgKDK7166y7 UdBJn6+sgo1i
8zsWDsDOcbzbrl9hg23cI7mO2smjZkEoUM13dzKtZoYGYrHLHqYRqpatB5Aa 8nWe5Wyb/cbn
t720tzerIquYixVbO0hZqQzTqoaSKTSplZgtKk8SAHyQ+Lnadf8AI7D/ACnp djdf/NvZmyf7
kZzafxV7q3NuPaeY6O3j17VR5+m7o+IYzO4cv8Rcv8gMRLiKgbTfeux9r77b O7syUU/dW3to
Q0e3KQG9DLogHbX8pbffYnxn+Xu7DtHV8jd19f8A87HbvWnUv8ew4/0n77+S HyE/mLZL4C9i
/wB/B2RQ7F2V/dLoX589q4z+EV8cdHX/AOmT7jcbUuR2liBjvde692b8Cvlj u/cXcOK6Z6p/
0FfLrP8AYH8yfdec/mj/AN+ettn/AOm7pP5KdWfNLbPws+PH+mLq7eO4/nPl P9ln3R3r0nL/
AAXdGysZtDaP+hTy7drq1tvbO/inuvdAB2f/AC3d79mb77b3F0d/LX7A+Dnx Yzf+yO/6WPix
1btP+UfRb7+VX+hzD/zRKHeX8C6PzfZHyF+AvYP90+xfkv03uOq/0uvjb0ez 5a/C69xYDb4b
3Xujv/FP4g939AYT5BUW4/jduDvDZPZnwg+L3x62F0z8he2PjVnYNwQTfLj+ ZnufPdH94P1l
19tLo7rLp/o3o75W7MptzbZ2LsfcOzdn7NiqdrbApt+pgqKHK+690f8A+EPx m7C+Nm1d8UO9
d47fp8RvfcGO3Bsn46dX5HszOdBfFrb8OOaGDqnpvOd0bw3pvaq2/tymngwU MW3qXrXq+PC7
exUm2es9k1E2bTK+690UDvf4bdy9qbV+fWzjs7cAxHyH/mv/AMtrv7aVXtPt ODrrdWW+PHSu
O/lI4vu/sLbW+tn762tvbrbcGyKb4078aiekyGH3aKnBJUYdWqKjFy1HuvdF /wDlR8Ke+cj8
0Ogd+9LfHLcG3sR0H3B8EtmfGzsr4xbH/ludedS9Q/BbrTtbp6v+QnVfdHY3 bdLtz+YhsvcE
G0KrtfFx7Q6Wr6frbMdd5Tb+Floaqoye8aKp917oIOjP5Xe7dz7t6M213L8H ev8AcHxl2/8A
L/Z/ZHauR+ZHUnwe3B84e+6Xb/we/mLbP3J298/N4/HLs/tn4/8AzK+w7/7+ 2JHsjc7UWP7H
bLZDN1+5cVV1NJLvPO+690f/AKu+Lne21sP/AC/Nu12xv4Zt/wCMn8z/AOfP ZcuCg3Ns5sP1
T8Nt0bE/mq9W/EPG7RxlFuGSioOv9u9Zd49X7c25tPCo8+1MFUUlAcdQUmKq oqH3XuiP47+X
D3zQ/J/5KdrbkxHzfHYm8NwfPzceY+R/x67N/ludPT9hdGd77f7/AMZ8cOke j+9JuuaP+Yh2
V3B07tDsfr/G7Z2l3LuraPT2yN5bCpstj85JiNl7MoMp7r3Sg+NH8vrduwe0 /iN212f/AC6P
j/UdZdOdgfJTa/WHV+w+gfg91N3t03mO4Nx/y+63qH52fJrYPX/bmQ+Ip+QH XMvxI3ku6N4d
J56bO1OHy21ptu7NxslTmNvba917r2zf5TPbp/l4/CvYfbe9/kB2z8jesuv/ AOWD1Dkdg5vs
vpPq3/ZSOotk/LX4CdyfNTr/AKL7Q+Lm2Oh9wVn93tv/ABax9TSbkyW7d472 p/7i0J2xmlyN
fWyZf3Xuhg3x8HN6Yn5P5B+uPidt+ny9N8n/AISb++KHzR2mnQW29q/Cf4Lf Hrb/AMR8H3j8
HttZOp3pgflH1Jt/tHB9H9tYyi2P1zszLdbZam7fSHKV9HT5vdhxfuvdVgbY /ltb+7o21tzd
vVXXXcGQ+PmQ3B8v8H8Do/izUfy9OvuvfjHPuH+aN/MK7W2L8nNqdifLfpft Tsn4r9P9v9E9
udQZzYXZ/wAVsLnd5VW2dpQZaHHVxw2xEqvde6P/ANmfAnN9gba+Tex+wP5f u3+3e8dy/J+j
+Qe8/l5uXGfEfc+O+Y/xR2X/ADRurfmdtL4L02998dowfInce4KX4k7LwnWe J2x2TtvbPVVF
ldmU+HbPU22aTE5ab3Xuhg6f/lq4fe3c+4u5N6dOf7LVszany/6c7g6k6U8W xD9z8cdo/AX+
WbS7f6F/hXRXamY666l/0PfPn4IdeZ/y4mbJxS/6G/4JQtVbQ3NWS5L3Xuig fFr+Xv8AJjrX
Z3xT2j2J8V/J8mtlf8NTZjY3zc/vT8e81/smPx7+LnRPwb2d8wPhP/pMHZ0v ya2x/pYzXQnd
GO/u71rtzcnWe5/9MGrJZeKmz+65cb7r3QP5D+WX8kc5hOvNq7U+GW4Oj+49 j/CDJ9KfOv5g
7TyHwWO6v5lXZkPy4/lkdn96ZDbWdy3YvYu6fkRuD5W9U/GvuIUUvyT2ht7b 25aneyUO/IKO
jzuegh917o//APL0+D/a3x6796X3svWfcHXvR2C6f/mAYPG7Q7r3V8L6PdXU GR7s3p/K2qNl
bGx/SHwS2L1x8XOktv8AYGc+MvYe6IsJ14m6sVNUzT7jz+YpdzbqrcNRe691 e97917r3v3Xu
ve/de697917r3v3Xuve/de697917r3v3Xuve/de697917r3v3Xuve/de6979 17r3v3Xuve/d
e697917r3v3Xuve/de697917r3v3Xuve/de697917r3v3Xuve/de697917r3 v3Xuve/de697
917r/9PcQ/l8f8yNyP8A4fNZ/wC8hsv2POd/9xPb3/xWbD/BJ0GOWv7Tmf8A 6W9z/hXo3m84
aifD0aUs+Wp5V3ZsKZpMLVZSjrGp6ffO3Z6yCaXD4PcNW+JqaSN46+J6eOln oXmjqamipnlr
II/lBKihPxLwr/EPQHHr5UrUgZApXj+R/wAHSs9udV697917r3v3Xuve/de6 LpF8h9k5PJYT
L4WHtrL7RqsDk51rsJ0J3xl8NmpchPt6q25mMRV43pXJ0+dxk2MjrHp66jzE NGYp1YQVomin
ozN9lv0l0u9upWoZWuLdWDVGCpk1AjIINCDggngWLvFk6BkW4ZTQgrbzsCPU MIyCDggioIyD
TiOuBzmJ3Pg8LuXAV0OTwW4cTjs5hclT6xBkMTlqOGvx1dAJEjkENXR1CSLq VW0sLgH2glik
gllgmQrKjFWHoQaEfkel8Usc8Uc0TaonUMD6gioP5jqrbb384f4v5yk2TmK3 G5Xa23N7ZXYW
PTN7h7w+D7Ve1aTsLN4PCY/O722Ht/5b57tXbmK24+ejqs+kmAatwVFBUzVl PEtLP45QuPaH
maB72FJFluIFlOlLbcqOYlZiscr2CwOz6SsVJdMrFVRjqWsW2/vByxOllM8b xW07xDU9zttU
ErKoaSJL9p0VNQaWsWqJQzOo0tQ8eyvlZ8XeydzYzZXXXyS6D39vLNfefwfa Wyu4evN1bmy3
8Ox9Xlsh/DMDgtxV+Vr/ALDFUE9TN4on8VPDJI1kRiATe8rcz7bbSXu48uX8 FmlNUklvKiLU
hRVmQKKsQBU5JAGT0OLLmrlfcrmKy27mSwuLx66Y47iJ3agLHSquWNFBY0GA CTgdD57Iej7o
AO9Plj8WPi//AHW/2Zf5LfH/AOO/9+P43/cr/Tp3J111J/fD+7P8I/vH/db+ /wDuPb/94P7v
/wB4KD777TzfaffU/l0+aPV7r3Q/+/de6D/eXaWxOv8AcXU+093Z3+Ebg7x7 AyXVvVuP/hmY
r/70b7xHVnZfdeQwX3WMx9bRYT7frLp/ceT+6yMlJRv/AA77dZTV1FLBN7r3 Qge/de697917
r3v3Xuk/uzdm1dhbV3LvrfW5dv7L2Tsvb+Z3ZvHeO7MzjtubV2ntXbmOqcxu Hcu5dw5ipo8R
gtv4LEUc1VW1tVNFTUtNE8srqisw917oIOi/lj8WPlB/en/ZaPkt8f8A5Ef3 H/gn99f9Bfcn
XXbf9z/7zfxf+7n96f7gbj3B/d/+8H936/7H7vw/d/Y1Hi1eGTT7r3Q/+/de 6D/JdpbExHae
zelMhnft+zewOv8AsvtLaO2v4ZmJf4vsTp/cfU+0+xc7/GYMfJt+g/u7uDvH a1P9rVVcNZV/
xTXSxTR01W9P7r3QQbl+bvwv2X3LTfHTePy7+MG0/kHWbg2ntOk6J3L371Tg u5ardW/YMNVb
F21TdYZTdlLvafcG9KbcePkxNEtCanIx19O1OkgniLe690Z/37r3Qf7j7Y6s 2d/f/wDvd2X1
/tX/AEUdf0fbHaX9495bcwf+jXqzI/31/h/Ze/8A+J5Kl/ud1/X/AOjXcfhz OR+2x0v8AyWm
Y/Y1Xi917pP9KfIXoL5KbVyG+vjp3h0/39snE7gqtp5TePSnZey+1Nq43dVD jsVmK7bWQ3Ds
XNZ3EUe4KPEZ2hqpaKSZamOmrIJWQJNGze690MHv3Xuk/tPdm1d+7V21vrYu 5dv702TvTb+G
3Zs7eO08zjtx7V3ZtXceOpsxt7cu2tw4eprMRndv53EVkNVRVtLNLTVVNKks TsjKx917r2Z3
ZtXbmR2nh9w7l2/gsvv3cFTtPYuLzOZx2LyO9N1Ue1dy76q9tbToa6pgqdx7 gpdk7LzGYkoq
NZqlMViayrZBT0s8ie690EGwPlj8WO1+0969F9W/Jb4/9ld29a/3j/0i9O7A 7k663j2nsH+5
246PZ+7v769fbd3Hkd27V/uru3I0+LyX31JB9jkZ46abRM6ofde6H/37r3Qf 7N7S2J2BuLtj
ae0c7/F9wdHdgY3q3tLH/wAMzFB/dffeX6s607rx+C+6yePoqLN/cdZdwbcy f3WOkq6NP4j9
u0oq6eqgh917oQPfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+6917 37r3Xvfuvde9
+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3 Xvfuvde9+691
737r3Xvfuvdf/9TcQ/l8f8yNyP8A4fNZ/wC8hsv2POd/9xPb3/xWbD/BJ0GO Wv7Tmf8A6W9z
/hXo3m86f7nD0cf233endmwqjxfY/wAQ0fab527Vfc/b/wB193+P7Lw+bz/a Rfa+Pzfe43x/
xGlj+UVUYr3L8/xD5H/BjjVfiApXj+R/wfl/q9eHSs9udV697917r3v3Xuve /de61p8h1L8q
4vlH8Xe7cV2F83Nq7O6L+MW8ulNw9T4Dorrqv29j8nuDKfDOty3XmzspkPhz und+U6i7Sn+O
WUrN5ZGp3hUbopsimMG1crisfNWxFfvVnuV3uO7T2cVu8EtxIyN9VarVWdiG o06spoRhlBGQ
wBFOinabuztdv22C6Nws0cCKy/TXDUZVUEVWIqRUHIJB8iRnq93onZm58D0x 0ziczn904HKY
TrDrPHZfbElHtRY8TX4famwqbJ4Gb7rbNTk1SOo23W082qpadRl63TKrx49q Gu7ss+77pPDO
TC9zIykUoQXqKYrQj/jx+VFG1I8O17bDLHSVLeNSDWoIQAg54g/4PtqQH4qd pbL6/wDjL8fd
idgdWfJvEb42X011vtTdmKl+Efy6yz4zP7e2jicTk6Bsniuh8ljK/wC0q6Ro xLT1E0Lhbo7L
Y+5d5ks5r3mHfbyy3La3s5ryZ0b942A1K8jMpo1yGFQeBAI8x1EHK9zaWXLm xWe47VuaX0Vp
Ejr+7b5qMqBSNS2rA0pxBI9D0JdRvTbnZne/xGh2B193nTNs/vHeW7d15jd/ xb+RPVO28Dth
/in8ldopkMnu/svqbZm2KdandW7MXQwwNWeeeorI1jjbkgqmhkseX+a/rL6w rLZxoix3lpM7
P9baPQRwzyOaIjsTpoApJI6OIZbe95g5TNht98PCvZHkaSyu4EVPobxKtJNB Ggq7ooGqpLCg
PRj/AJebW+T+8emq3DfEff8At/rrtZtwYGply2Zym39p5HI7VgnlOYw20+yd 49EfK/ZPWO4J
alqapkyeX6o7Dpq7FUtZh4aDF12UpN0YCKupV6qg2l0z3ZJ8p/i/m/h11h2B 8NtwbW+P/wDM
RwXyH3T/ADBemu3fmtuKv33vfsX+VplNl4/sPvfanzXo6LursDfvWWxsX/dT dMPc2+6PHbV2
XV7RSGCr2xXYrbPuvdA/2hsH5F/GDv34bdI/Hit+T+1dk/FHcH8uD4idRYXG 9N/P35CbV+Sf
w9xe9Ojevu+e9+2u0+je0Nr/AMrXovcGF603l2Bt/PUHZnU2T3zQU2xhubGZ LEpltlz4P3Xu
mDG9dfJzsTYHwSXrKf5f4T+YptL5Aba3L8399/JvbvzTzHRPXfyArf5YH8xv ZHbW4Ohs/wB7
7R7E+GfWHX+e7y3lkdt4fd3TO2N4dQbdzGd2rVttjdeDTb+2cv7r3T/2v2N8 pMh8lfjLuLp3
aHzf6Epute4PhL8fdsdPb/6Z/mcfIvI9s/Hhu7+r9g/LLszvfvPa3yK3f/Li 2TuDZOB3f2bt
bK53tDa3ZG7dwYrYcHYO3d71mN3NsHcND7r3RYMzuP5a/fdR9dda7/8An/tL 5tbt+AG+Nx/z
GMf21R/zDt29Wf6U9pfMn+U5gvmPv/4rdW7g3r1/1L2B/o/6l7A7sTBQ/EHL 4jI/w7L01J15
kqCsr9oze/de6sf6U2LuCo+F+QwHfm1fm/8ANOSb5P1WQ+JVPsbrP5P/AAw+ T+08cnVOKj3D
letu1vl384K75odA7fx2Rj7Opa7evdncGwcruDH5rJbNwaVe085srEbi917q z/4h7W+T+zum
qLDfLjf+3+xe1l3BnqmLLYbKbf3ZkcdtWeeI4fDbs7J2d0R8UNk9nbgiqVqa mPJ4jqjrymoc
VVUeHmoMpXYur3Rn/de6rAwPSnfud6z+KHVNFkPk/wBJ7b3j/Oe/mr7g+QNf 1DVb06v3VWfG
DfHYX84Dsbajbz3Pj8UMvs/p/urL5nY64rc9NJjMhDU5/B5fa2Yxe4f7vZml 917ov/dm8fm+
vzk3Vn9g76+T/wAdKnee4Plr1n2Bt7afw2/mP/LnrPpzpDYHw5+S8vxz+Um2 t47g7T7I/ln9
qbg312f1b1Xvui6+6u6y232XJuHc6bEyOTrskN30+f8Ade698Z/i/u75C9+/ G+TuHrf5v7C6
p2F0/wDzG8VhO8Kb5jfzaesd1dv5HKb0/lP47aHYGZre/wDtXYvzQ+Ju3+1c js3fMeM6K3lu
LLYqGp2ZX53FVm6KE0e6a33XujwfF+D5Hdgdp/ylO6/kBtHsBezan+UB8iYP kvuXcfXVVsn+
6/yO7R3H/Ke3Znto7/w1Bt3b+3+t+wNy7g2Zuuoh249JjZU/gmSSmpEjx86Q +691WB0Rtf8A
mEU3UXb9b3H8uvl/sbs3NfH/AGZR/Lj+Gfy6f5mPauH2T8mMt3Z0N/fjbnVv 8Q+Ze79wdo/3
k2+3aO0afN/BXbvX3XuEwWZqt3Jldtx4brbR7r3Sf7P6G7Q3f018vN9b2+M/ zf2D2T8gP5MP
cnR3xS6ywPfX8xX5jY7e3YWzp/5tWe3FgPkFujdONxG6dxbg351T8g+vc913 gvkntfA7mwmV
3bHtbbeNpNz4TKYvH+691Y/3H8O/lPl/kB8bewewvkh2BmN59+/IDrvpH5M7 w+DPXnYvxR2J
iPht8f8A4gfzQOwdn7S3lS5HuP5Mb62n/pB76+Qr4fM7yj3jiZ6SsrtrPtUb a3fjMfuGf3Xu
k/sfbXee9Pk/j9nbrqfm/R9rbs+T/wA29tfMerm3Z8wthfGCl/lwZ3b/AMuM X8P6noHfVJmd
ufC/ZfcEGOqvj00eW6SyFB3fjsgMtUZiogro9+yr7r3RAPhDU/zAez838Cu0 d7/Ir5PvU7l6
f/lhbs6sx+N6C+Zndm1e1vjdmfiP8Udw/KncvbXyDx/y660/ln7e3Bvns/Id ypnq3unZe6u9
KSmtktrvk8lP1rQxe690MEPVsnYHTvw13Z8gMF/M/wAv3P0d8gOpe0v5qGQx WT/mr0G4tr9u
5f4J/N3pTeud+FVL1nkKKLN9f1Hy67gpcZlaX4jR1eyU2rkaWoqIhsenp54f de6M/wBB/HD5
cYnZe8O6tw4/b++6b4ufN/8Am8/LD4d/Dmi6uzfx87l7P7l3937/ADDOvurs T2h8oO0e4N5d
d5Pp/u3rv5G5jJ4Cso+uNrxwR57b2VbLVmNx9Wmd917okHTVX8q8ZuLemw94 dhfP/tH4DYbs
D4wbu7w3Zs/4xfznPjr3tFh939WfzE8Nv/bvTtT8oO7Pkb/NB3r/AA35BbF+ N1TuFOot2jBY
vD1zmfEUGIrN91uV917oz/WFL8leje4Pl38gOrulPk/3V8fKnuDZmc+MHRuR yvd/UfbXZvcu
Z/lQ/wAv7qTpXfPyZ3D37j8l3H290/vHcmDyPW2Yze6QY+nOxDkN09g4fcJx 9RujqP3Xuiwd
NVfyrxm4t6bD3h2F8/8AtH4DYbsD4wbu7w3Zs/4xfznPjr3tFh939WfzE8Nv /bvTtT8oO7Pk
b/NB3r/DfkFsX43VO4U6i3aMFi8PXOZ8RQYis33W5X3Xugf2xU/N/tTbW3Mx 1P8AIr5v7Q6p
xG4Pl/tP4TZSq6C/mP8Ayl7ly3d+yf5o38wrYsG2u666k+XXxp23sjcHW3Tm 1ukcPSUXzkbN
9aCOGWkqkx1Dj+wY6j3Xutx337r3Xvfuvde9+691737r3Xvfuvde9+691737 r3Xvfuvde9+6
91737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xv fuvde9+69173
7r3Xvfuvdf/V3EP5fH/Mjcj/AOHzWf8AvIbL9jznf/cT29/8Vmw/wSdBjlr+ 05n/AOlvc/4V
6Nj2AiyYGgV6mkpQN79ZuJa2i25Xws0fY+1JEpkg3TX43GR1dY6iGnmikbI0 07pNj4p69KaC
SPpvgGR8a+n8Q9aD/KOIqaDoUrxP2H/Af9X+HHS39u9V697917r3v3Xuve/d e6LvkfkN8faf
eWMap7m6MjbHYTdeOrcjV7/65GWxFbLldpkYVclUb2psvi4skaCV6mkjx1TD UyUMTzVFK9ND
FVmA2TeWeN12e5KFTnwXPHTShpwPHAINBkUFS87xtC6lbdbcMDw8VPKvlXy6 MBSVdJX0lNX0
FTT1tDW08NXR1lJNHU0lXSVMazU9TTVELPDPTzwuHR0JVlIIJB9oGVkZkdSG BoQcEEeR6Xqy
sqsrAqRUEcCPUdFN2984/j3uik2TlcVU9zptzsbK7Cw+y96Zj4r/ACn2319n avtHN4PbnXk0
PYe4+mcVselxW8M3uXH09DXVGQiopmrIiJdLgkWXHJHMFq97FKtn9RbrK0ka 3tk8qiBWeX9J
LhpC0ao5ZQhYaTjHQSt+eOX7pLKWJr36a5eJY5Gsb5ImM7KkP6z26xBZGdAr Fwp1DOejdewl
0Luve/de697917r3v3Xuk/md2bV25kdp4fcO5dv4LL793BU7T2Li8zmcdi8j vTdVHtXcu+qv
bW06GuqYKnce4KXZOy8xmJKKjWapTFYmsq2QU9LPInuvdKD37r3QP9cfHroL pzdXZ2+uouj+
n+q97d2bgXdnc28euOtNl7H3V25upMjuDMJuXs7cO2MLi8vv3cC5fdmVqhW5 WarqRU5Orl16
6iZn917oYPfuvde9+690n9y7s2rsvHU2Y3juXb+08RWbg2ntOkym5czjsFjq rdW/d1YbYuxd
tU1dlKmlpp9wb03tuPH4fE0SsanI5Wvp6SnSSonijb3XulB7917r3v3Xuve/ de697917r3v3
Xuve/de6T+7Np7V37tXcuxd9ba2/vTZO9Nv5nae8dnbsw2O3HtXdm1dx46pw +4dtbl29mKas
xGd2/ncRWTUtbRVUMtNVU0rxSoyMyn3XulB7917r3v3Xuve/de697917r3v3 Xug/7S6n6s7x
2Jnere6+tOv+4Ost0fwz+8vXXaWzdudgbE3F/BMxj9xYb+O7R3Zjcvt/L/wj cGIpK6l+4p5P
t6ylimTTJGjD3XulBtPae1dhbV21sXYu2tv7L2Tsvb+G2ns7Z208NjtubV2n tXbmOpsPt7bW
2tvYemo8Rgtv4LEUcNLRUVLDFTUtNEkUSKiqo917pQe/de697917r3v3Xuve /de697917r3v
3Xuve/de697917r3v3Xuve/de697917r3v3Xuve/de697917r3v3Xuve/de6 97917r3v3Xuv
e/de697917r3v3Xuve/de697917r/9bcQ/l8f8yNyP8A4fNZ/wC8hsv2POd/ 9xPb3/xWbD/B
J0GOWv7Tmf8A6W9z/hXo3m86j7bD0cn3P2mrdmwqfy/ffw/X93vnbtL9t9x/ ejaHk+983h8H
3cv3Xk8P2WS8n8Oqo/lNFGady/L8Q+Y/w54Ub4SKV4/kf8H5/wCr049Kz251 Xr3v3Xuve/de
697917qhDbfyr722bTdU4Dbnym+LW1Oq9qbK6bwWc6m3X8V+w9xdz4+k25sz aeJ7F2zJ3ZSf
NfZ2z8duivy9BkhQVs3XTxYPzQRVNBknpZXqjDfrXeZN33h7bY76SNrmUq6Q SsjAuxVlYIQy
kUIINCMg9FGzXu1R7Xtcdxu9okiwRhlaaNWUhFBVlLAgg4IOQePVs/x2x28q bobomE5PCUFN
T9RdURSYuv2plWy1JBT7N6+StoKqr/vZRxjIiOjzMfkNIgikraNmhYUE6ZH2 9l23rd2SRTGb
qUjFceIfPV9ufmPQ6n9nGnaNqVlIYW0dft0Dyp/qz+VNPxUw38qKq+Mvx9qO zq34ARdjSdNd
b/36j3vlPj9T7yXdi7RxKZ/+9UOarYcwm4jk1kNZ92oqTUFzL6yx95BcyTe5 Scw76thFvpsf
rJvDMYuvD0eI2jRpGnRppp04pSmOseeV7X2xk5c2J9yn2IbgbSLxBI1sJNeg atYYhtVa6tWa
8c9DptLF/AGh+T3wzl+KtX8R5+wm7x3/AB5lOhMh1HV7wGzD8Q/lA2RbJR7B q58wu2hnExwm
aQCmFUacMdZj9h/c5edZOVucBzHHuq2P0cWn6kXHh+J9fZ0p4o069OqlO7Tq 8q9CLbLfkaLm
rk5uWZdqa/8ArZQ30zQGTw/oL2tfDJbRq0VrjVp86dWF/LzdPyf2d01W5n4j 7A2/2L2su4MD
TS4nM4vb+7MjjtqzzyjMZnafW28e9/ihsns7cEVStNTSYzL9r9eU1DiqqszE NflK7F0m18/B
vU6dUQ9jdabE+Tnyn+G+E2j1z1//ADUNwUHx/wD5lmd7S2t/N5OY6E3FsDfe O7F/lO4vH5DN
dEZP4C7sovjr2Bgussztz+A7Wx3TPX1HnNq7nfdzTVVXuGqyu5Pde6f+0Plt 8h/h1378NvjF
F8s9v7oy/TO4P5cHwq7U2P8AJ3vHqXYXbXzwyPc29Ojepe1vmX0v8YNyfGbt b5R97bfqsH3T
WPJvHH/IrbOKxfYmw9wQZDDZqn2zlo91e690gJ/kj3f3DtH+XN2n1z8lNv8A yl+eFV8n8HvP
uT4Ubly3xqx2O+BHfu8v5S380HK9l/H6m6q65230n3JtrcGx9yHcGGxOxO7e xKPNZjK7Ip8B
lt8bYlkz26af3Xul/wBr/wAzbemC+Svxlw/SHyu2/mdk4/uD4S/FLd/Ufyk7 X6C6Z7z+WeR7
q7v6v6Y7v772L8K6f4Ibd+Qe9NwdZydu5fb25qvD9n9Q4rYvcPV+68JlNiIm zszh8/7r3QAZ
D+ZJ8qosJ15lOsvnBt/tX5B9l/CDJ9tfM/4r7srPijtfav8AK+7lyfy4/lkd Udwyblqdh/Gn
dne3xW2/8Q+tvkz2/NW1PeEHaMez6bYz5PdmL3ENv5inrfde6P8A9Kd+7q7A +F+Q3n8jvm9u
CrzmC+T9VtP4w/Jb+Xjmsj8uOzO34B1Tis3mNtbVo+vf5fPW3x8+fu4MHHnO xaTMUWyOgNyb
N2ft7bMlXWom9tgZvc2K917o39Hun+YrvH+Xp8iczlNgbf66+eDdP/IKm+OG Jw2L6v2nkcj2
ZBsHPDovM7s62yfe/wAr+iesdwS9ktBTR4ybtfsPb1diqWjzGTr8XLlK/a+A 917quDtb/ho/
+5G2P9ks/wBlA/2a3/Zv/wCVl/pi/u1/cj/Z+v7u/wDDuHwM/wBIP+za/wB8 P+cx/wDSB/pI
/hX9/P8ASd/v6v76af7x/wC5vX7917oAKL+aL8mM72T3xt3aPzE+IHX23+xP j/2V37jcF8t/
mF8e8D2T/Ly/u58sfh/1bH0r8i8ZsP4DbCovgj8gKPrL5Sbi25Sbc7VT5K/a 9sbYxdBV1GRp
MPnot2e690P+xfnZ2fn+yfgVi2+THyAyPX/cv9zk210u26P5ZU/8ybu/Mbq+ WPa2yMz3h8hP
j3tPp7OdS9r/AMsBOpdg0OVwXanxn3Bis7S7Cjym6JotxYqZ9z7X917pPnqn r34O7f8A5yXd
Hwa+Nvxg6P7j2R83/jN0JtzsrbXVvWfT2O6M+NXbfxg/lNV/f+46nsbCdP8A YGI6g6f6gxHY
G6e1ctlMrtbdOyNs5XGVG6c9t3N0dLkKKr917pAZr57/ACq210F1pn98fOPp /emzq/uDvDB7
V3P8Hu+/ij2t88/mBjtu7L+PT9dbG+GGR+TvwE6A+Dn8wfcG2u3O094YTeWE 6s2FtDK0ppNs
bexGYzW+8Nufbu6Pde6s+/lawwbfT5kbEy/f24N19iYL5v8AzZ3Zur4qbln6 ao8j8WNq9s/P
P5e9kdRblptp7V692t3tg9v/ACr62z9DvjE1u/sxuCmzuKmp6/bb0uIl0Se6 91a/7917r3v3
Xuve/de697917r3v3Xuve/de697917r3v3Xuve/de697917r3v3Xuve/de69 7917r3v3Xuve
/de697917r3v3Xuve/de697917r3v3Xuve/de697917r3v3Xuve/de697917 r3v3Xuve/de6
97917r3v3Xuve/de697917r3v3Xuv//X3EP5fH/Mjcj/AOHzWf8AvIbL9jzn f/cT29/8Vmw/
wSdBjlr+05n/AOlvc/4V6N5vP+I/wej/AIX/AMCf72bC8v8Ax9H/ABbv787d /i//AB5/+5b/
AItPn/z3+4v/AJ2f+437v3H8urSNPHUvrw1CvDPD8v4u2vQpWlc+h/wfP/V6 Z6VntzqvXvfu
vde9+691737r3SeqXYbrwsYpqtkbb253arSt3HHQwNHktoqlNU46loJNpVVX VCRmhmrqqHI0
6QyrQxTQzZB4KH+0XB+E+vqPLh+019Kgmm/wn7f8/wCf+r7OlD7v1rppz2Qq MTgs1laOj/iF
XjMTkchS0GnKP99UUdHNUwUejB4fcOaf7mWMJajx9dVHV+1TzSaY2q5KozAV IB9f8gJ/YCfk
etgVIHTt7t1rovPcHb+9tj712FsDr7r7be+dwb12v2HvCZ919hZPr7E4nDde ZbrbC1iR1mI6
57Iq8jkchW9mUpjjNNTxpFBKxlLaVIj2bZrLcLLcL/cNxkgt4JYY/wBOFZmZ plmYYaaEAAQt
U6iakY4noh3bdryyvLGxsbCOaaaKWQ65WiCrE0KnKxSkkmYeQAAOekV/pe+T 3/Pg+lf/AEpX
fH/3LPsw/cnK/wD00F7/ANkUX/bd0i/e3Mf/AEZLP/srk/7Yuh76n35F2n1Z 1p2dBjZMNB2P
1/s3fkOHlqlrpcTFu/buN3DHjZK1IKVayShTIiIyiKMSFNWlb2Ac3awO1bru e1tLra2uJIi1
KavDcpqpU0rStKmnr0e7Xe/vLbNu3ERaPqII5NNa6daBtNaCtK0rQV9B0IHs v6Xde9+690AG
wPjF1F1v2nvXuvCUnYGe7N3z/eOCq3L2h3Z3Z3V/czD7y3HR7s3htHpjDdxd hb62/wDH/r/d
u4MPi6jKbc2LSbdwWQ/gOGSopJI8LiUo/de6H/37r3Xvfuvde9+691737r3X vfuvde9+6917
37r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuv de9+691737r3
Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3Xvfuvde9+ 691737r3Xvfu
vde9+691737r3Xvfuvde9+691737r3Xvfuvde9+691737r3X/9DcQ/l8f8yN yP8A4fNZ/wC8
hsv2POd/9xPb3/xWbD/BJ0GOWv7Tmf8A6W9z/hXo3m86f7nD0cf233endmwq jxfY/wAQ0fab
527Vfc/b/wB193+P7Lw+bz/aRfa+Pzfe43x/xGlj+UVUYr3L8/xD5H/BjjVf iApXj+R/wfl/
q9eHSs9udV697917r3v3Xuve/de6SdZT6t87dqvttfh2nvOn+8+x8ng+5zGw pPtv4l/der+0
+7+01+D+NY/7jw6/ssh4fPjWyP1UNPwt/hXzp/z8K+hpVbfhP2j/AC/6uH7P NWe3Oq9JPftP
93sbedL9t979ztPcVP8AZ/Y/xP7vzYesj+2/hv8Adfe/8Q8+rR4P4Ll/LfR9 lVX8EjcwrFKK
V7T8/L0o1f8AeT9h4dWX4l+3/V6f4R16orN8r9z9rt3ac2j777P7jeeYpvP4 /wC9H8N+58ew
qv7T7v7TC+fR5vt/4hW6PN/D4P4l4mXNEX/ej86fh/0v2VPGg1e7fU/s/wBn 7f8AUcEf+T/a
9V1L3x0HuXLP0piJa3qn5R4GP/S93bN1HtCSjk7C+MtXipaLeM/XG7XrN11u LxcU74kY9UjD
VWirlSkV6iQ+Utrfd9g5gttF2St5Zt/i0H1L0Ed8ASniQ0Xuy2o0ai0NagDc zbiu173slwWt
QDaXS/4xP9OmZLM4fw5atjC6RUVNRShRP+zvUf8Azv8A4Af+nAf/ANWr2Zf1 Jk/3zv3/AHKv
+3zpB/W+P/fmyf8Acy/7dOjc/EE3+JnxeJ+p+O3ShP8Asetds+whzf8A8rZz R/0sbn/q8/Qp
5W/5Vnl3/ngt/wDq0nVZW4fnF8p99Yf5Xbj2NJ1/1N318Y/j/wDJvtvqH+WL k+texd7/AC/+
QG4utdibnw/Ve8+0m3Xi+t63efx/3B2buWhwFRQdCYTd21ct2BgKWPbPd+5M ZPkcLUB3o969
8lfj51FtD469R999d96/ID5B1vavy/8A5R+T/wBKm/8A5g92d29Wdo4ffP8A NN+DO8/9KWyu
of8ASRU/EXZP99paaDI42o662ZtnBY3HVslFgKXHYWf7E+690H+3/wCZR87N 77x3NhemvjD/
AKdNpfIn4/75+Uf8vXev9wunejv76dE7b72+LmwIN8/3c3V/MZ37k+8/s+kv l7iewP4Zvd/i
vmMn/dj+BGkxtfuOaTZ3uvdCBtn5+/ITLV3xc3HX706/j+Mu/OwNv9P7/wDl 1/w358mMHt3t
H5Mbj+ZO+fi1WfDv/ZbNx/Kmi+TX8vPsDZma2bSYD/SD2XhN99e5fdWb8dVN gKmlxuF3H7r3
Q/8A+zR9p9c/Mn/ZaMLvnr/5nYXcvYH+/wBdldd7Z3HhPkx8Fdu72of7/wC3 P9mL3HsDb26v
jLkev8jhd1PV7R/0gV/Qu6qjr3aUkWC/0vbzlkjq/de6UHbOAn+RPzQ3H8Y+ 1979wdedObL+
MHVXe/UWF6U7x7l+Lu6u7uzNz9rd3dfd85TIdp9G77627W39t/4x7W2511FL t/CZul29iKnt
qCr3TQ5Osrtlz4b3XuiAUXbvcvx+7g+dfx5+GWL3B2J8g85839rZzbOzN2bC g+Ue6sx8eOh/
5UP8pzY/Ze+dy7t+Qvz++CtNl9wbe3t25sCkrc3nO0M5u3MVObeYY
Re: Creating Stereotype extending AssociationEnd [message #478495 is a reply to message #478492] |
Thu, 04 June 2009 13:12 |
--=-YpAQoeXb2vYf8Nr9ZORN
Hi, Gilbert,
If you need to constrain a stereotype to be applied only to association
ends, then you can do that with another OCL constraint:
context MyProfile::Event
inv is_association_end: base_Property.association.oclIsUndefined()
HTH,
Christian
On Thu, 2009-06-04 at 11:15 +0200, Gilbert Mirenque wrote:
> Hi Vlad,
> best regards,
> Gilbert
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
If you need to constrain a stereotype to be applied only to association ends, then you can do that with another OCL constraint:<BR>
<BR>
context MyProfile::Event<BR>
inv is_association_end: base_Property.association.oclIsUndefined()<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<PRE>
Hi Vlad,
> <A HREF=" http://www.forum-omondo.com/documentation_eclipseuml_2008/As sociation_ends_stereotypes.html"> http://www.forum-omondo.com/documentation_eclipseuml_2008/As sociation_ends_stereotypes.html</A>
best regards,
Gilbert
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-YpAQoeXb2vYf8Nr9ZORN--
Re: Creating Stereotype extending AssociationEnd [message #627641 is a reply to message #478464] |
-----8<-----
Hi, Gilbert,
context DataChannel
HTH,
Christian
----->8-----
> no suggestions?
<HTML>
<HEAD>
</HEAD>
<BODY>
<BR>
-----8<-----<BR>
<BR>
Hi, Gilbert,<BR>
<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
----->8-----<BR>
<BR>
<PRE>
no suggestions?
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Re: Creating Stereotype extending AssociationEnd [message #627670 is a reply to message #478484] |
Hi Vlad,
best regards,
Gilbert
Re: Creating Stereotype extending AssociationEnd [message #627672 is a reply to message #478492] |
Hi, Gilbert,
HTH,
Christian
> Hi Vlad,
> best regards,
> Gilbert
<HTML>
<HEAD>
</HEAD>
<BODY>
Hi, Gilbert,<BR>
<BR>
<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<PRE>
Hi Vlad,
best regards,
Gilbert
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
Current Time: Thu Apr 25 13:30:46 GMT 2024
Powered by FUDForum. Page generated in 0.05604 seconds
