Home » Modeling » UML2 » How to set & get data from a stereotype's properties
How to set & get data from a stereotype's properties [message #478190] Thu, 12 February 2009 14:44 Go to next message
maniel  is currently offline maniel Friend
I created a stereotype properties which is using another "Type" I defined
within same profile. How can I use set and get value from this properties
using api?
I use RSM's properties editor, I can input single or multiple instances of
data to this properties. It seems the value is held within a list.
Now the questions are:
1. Should I use a custom type in stereotype properties? Or I should define
another stereotype and use it in properties?
2. I know RSM is using ClassImpl to represent a Profile's type, but how can
I use uml2 setValue() or getValue() to add & retrieve data from it?
Maniel
Re: How to set & get data from a stereotype's properties [message #478214 is a reply to message #478190] Fri, 27 February 2009 20:05 Go to previous message
james bruck is currently offline james bruckFriend
Hi Maniel
If I'm not mistaken, RSMs property editor will obtain the structural feature
from the DynamicEObject representation of the Stereotype application and
then set the types using EMF.
However, the setValue() should be sufficient. For simple use of
setValue(), the wiki has this article:
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
For setting multi-valued properties, the final Object parameter would have
to be some instance of java.util.List. The elements in the list would need
to conform to the property type . Internally the setValue() method creates
a new list and calls eSet using the new list.
- James.
"maniel " <maniel_leong@shaw.ca> wrote in message
news:a0f274129ecf8461f608c27e125de659$1@www.eclipse.org...
> using api?
> can
> Thanks
> Maniel
Re: How to set & get data from a stereotype's properties [message #627409 is a reply to message #478190] Fri, 27 February 2009 20:05 Go to previous message
Hi Maniel
- James.
> using api?
> can
> Thanks
> Maniel
Previous Topic:Subsetted/Redefined Property -> DanglingHREF
Next Topic:uml.ecore and ecore.ecore
Current Time: Sun Apr 22 10:57:17 GMT 2018
Powered by FUDForum. Page generated in 0.05155 seconds
