Home » Modeling » UML2 » EAnnotation and Cross document reference
EAnnotation and Cross document reference [message #477575] |
Tue, 08 July 2008 05:59 |
Sushant Sirsikar Messages: 5 Registered: July 2009 |
Junior Member |
Hi All,
I am working on project which uses cross document reference
functionality of EMF. I have two models
1) UML2.0 model. (Which is uml model created by emfs tool project)
2) Description model (This model is create using emf to store
description of Uml model).
Both the models are in different resource and using EMF version
2.2. There is one constraint, that I can not change the UML2.0 model
because of dependency with other code.
Now problem is, I need to attach this new Description model to
UML2.0 model. I am trying to add this model inside the EMF model using
EAnnotation. EAnnotation has details field which returns ECoreEMap,
which delegates to EStringTOStringMap as
public class EAnnotationImpl extends EModelElementImpl implements
EAnnotation
public EMap getDetails()
if (details == null)
details = new
EcoreEMap(EcorePackage.eINSTANCE.getEStringToStringMapEntry( ),
EStringToStringMapEntryImpl.class, this,
EcorePackage.EANNOTATION__DETAILS);
return details;
Above is default implementation provided in
org.eclipse.emf.ecore.impl.EAnnotationImpl. Now I want my details contains
map which can take object as key and value instead of String which is
provided by EStringTOStringMap. To achieve this I override details()
method as
EAnnotaion annotation = new EAnnotationImpl(){
public EMap getDetails() {
if(this.details==null){
this.details = new
EcoreEMap(Uml2docPackage.eINSTANCE.getObjectMap(), ObjectMapImpl.class,
this, EcorePackage.EANNOTATION__DETAILS);
return this.details;
annotation.setSource(IAnnotationConstants.DOCUMENTATION_SOUR CE);
umlelement.getEAnnotations().add(annotation);
This details method delegates to ObjectMap which is inside Description
model. So when I save my resources, my .uml file looks like bellow :
<uml:Model xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:com.zensar.sbp.modelTransformation.model="http://zensar.com"
xmlns:uml="http://www.eclipse.org/uml2/1.0.0/UML"
xmi:id="_x2a-IEvrEd2X0eL_8jpS4A">
<eAnnotations xmi:id="_0UEsUEvrEd2X0eL_8jpS4A"
source="http://www.zensar.com/uuid">
<details xmi:id="_0UEsUUvrEd2X0eL_8jpS4A" key="uuid"
value="12154112091090"/>
</eAnnotations>
-----------Some serialized model-----------------------
<ownedMember xmi:type="uml:UseCase" xmi:id="_yy6bkEvrEd2X0eL_8jpS4A"
name="UseCase1">
<eAnnotations xmi:id="_zlSTsEvrEd2X0eL_8jpS4A"
source="http://www.zensar.com/documentation">
<eAnnotations xmi:id="_0UEsWEvrEd2X0eL_8jpS4A"
<details xmi:id="_0UEsWUvrEd2X0eL_8jpS4A" key="uuid"
value="12154112091095"/>
</eAnnotations>
<details
xmi:type="com.zensar.sbp.modelTransformation.model:ObjectMap "
xmi:id="_zlSTsUvrEd2X0eL_8jpS4A" key="documentation">
<value
xmi:type="com.zensar.sbp.modelTransformation.model:Documentation "
href="file:/c:/docTest.uml2doc#/"/>
</details>
</eAnnotations>
<eAnnotations xmi:id="_0UEsVkvrEd2X0eL_8jpS4A"
<details xmi:id="_0UEsV0vrEd2X0eL_8jpS4A" key="uuid"
value="12154112091094"/>
</eAnnotations>
</ownedMember>
</ownedMember>
</uml:Model>
So my problem is :
1) When I load the uml and description model in resource set, it loads
object map with key but it doesnt load value, which is cross document
reference to description model.
2) What is the way to register my new annotationimpl inside EcoreFactory
and package.? Because when I load uml model, it again creates
EStringToString map and could not store my ObjectMap which in terns gives
ArrayStoreExcption.
Thanks in advance for any suggestion.
Re: EAnnotation and Cross document reference [message #477577 is a reply to message #477575] |
Tue, 08 July 2008 12:13 |
Ed Merks Messages: 33140 Registered: July 2009 |
Sushant,
You posted this same question to the EMF newsgroup. Please don't cross
post the same question as separate posts to multiple newsgroups. If you
must cross post, use a simple posting addressed to all the groups so
that an answer on any one group will appear on all groups.
Sushant Sirsikar wrote:
> Hi All,
> 1) UML2.0 model. (Which is uml model created by emf�s tool project)
> Both the models are in different resource and using EMF version 2.2.
> because of dependency with other code. Now problem is, I need to
> attach this new �Description� model to UML2.0 model. I am trying to
> add this model inside the EMF model using EAnnotation. EAnnotation has
> �details� field which returns ECoreEMap, which delegates to
> EStringTOStringMap as �
> EAnnotation
> details = new
> return details;
> contains map which can take �object� as key and value instead of
> String which is provided by EStringTOStringMap. To achieve this I
> override details() method as
> @Override
> this.details = new EcoreEMap(Uml2docPackage.eINSTANCE.getObjectMap(),
> ObjectMapImpl.class, this, EcorePackage.EANNOTATION__DETAILS);
> �Description� model. So when I save my resources, my .uml file looks
> like bellow :
> </eAnnotations>
> name="UseCase1">
> </eAnnotations>
> <details xmi:type="com.zensar.sbp.modelTransformation.model:ObjectMap "
> <value
> </details>
> </eAnnotations>
> </eAnnotations>
> </ownedMember>
> </ownedMember>
> </uml:Model>
> So my problem is :
> object map with key but it doesn�t load value, which is cross document
> reference to �description� model.
> EcoreFactory and package.? Because when I load uml model, it again
> creates EStringToString map and could not store my ObjectMap which in
> terns gives ArrayStoreExcption.
Ed Merks
Re: EAnnotation and Cross document reference [message #626770 is a reply to message #477575] |
Sushant,
> Hi All,
> EAnnotation
> details = new
> return details;
> @Override
> like bellow :
> </eAnnotations>
> name="UseCase1">
> </eAnnotations>
> <value
> </details>
> </eAnnotations>
> </eAnnotations>
> </ownedMember>
> </ownedMember>
> </uml:Model>
> So my problem is :
Ed Merks
Current Time: Thu Apr 25 09:46:22 GMT 2024
Powered by FUDForum. Page generated in 0.02544 seconds
