Home » Modeling » UML2 » How to use Name Expressions
How to use Name Expressions [message #477248] Mon, 14 April 2008 12:43 Go to next message
Felix Dorner is currently offline Felix Dorner
Hey,
I am trying to figure out how to work with name expressions. As a simple example, that I already fail to construct, look at the template
Collection<T> { add(T) }. In bound templates, I'd like "add" to change to addA, where A is the name of the actual Parameter in the binding.
So in Collection<Car> I want the add operation to be called addCar().
Is that a correct use case of the name expression mechanism?
Felix
Re: How to use Name Expressions [message #477254 is a reply to message #477248] Tue, 15 April 2008 11:31 Go to previous messageGo to next message
james bruck is currently offline james bruck
Hi Felix,
There is a notion of substituting string expressions in the UML spec. but
the UML2 opensource component doesn't support this currently.
To get this to work we would need some facility in the UMLUtil that performs
the "merge" step and substitution of bound parameters to create a new
entity. Right now, we only support exporting UML constructs to an .ecore
representation that can then be used for generically specified code during
code generation.
The last time I looked at this in the spec., the actually string
substitution rules seemed fuzzy (to me at least).
- James.
"Felix Dorner" <felix_do@web.de> wrote in message
news:fu01k8$ufm$1@build.eclipse.org...
> Hey,
> Felix
Re: How to use Name Expressions [message #477256 is a reply to message #477254] Tue, 15 April 2008 13:57 Go to previous message
James Bruck wrote:
> Hi Felix,
That's great, then I have an excuse :-p
I couldn't really understand either...
Have a nice Day,
I just enjoy a beautiful Spring Day Sunset.
Felix
Re: How to use Name Expressions [message #626411 is a reply to message #477248] Tue, 15 April 2008 11:31 Go to previous message
Hi Felix,
code generation.
- James.
> Hey,
> Felix
Re: How to use Name Expressions [message #626413 is a reply to message #477254] Tue, 15 April 2008 13:57 Go to previous message
James Bruck wrote:
> Hi Felix,
Have a nice Day,
Felix
Previous Topic:uml2 v2.2.x to v2.1.x backwards-compatible export?
Next Topic:Re: Primitive types
Current Time: Thu Jun 20 04:25:18 EDT 2013
Powered by FUDForum. Page generated in 0.01894 seconds
