Home » Modeling » UML2 » Primitive Types - UML to EMF Generation
Primitive Types - UML to EMF Generation [message #477104] Tue, 18 March 2008 22:35 Go to next message
No real name is currently offline No real nameFriend
I need to add custom Primitive Types and map those to concrete Java classes
when I generate an ecore. How do I go about doing so? Everything I've tried
so far hasn't worked.
With Rose I would stereotype my primitive type as a <<datatype>> and add the
java class as an attribute. I've tried doing the same here, but that didn't
work. Only the predefined primitive types generate correctly for me.
Suzette Samoojh
Re: Primitive Types - UML to EMF Generation [message #477106 is a reply to message #477104] Wed, 19 March 2008 09:00 Go to previous message
Suzette,
There's an Ecore profile you can apply and then use that to specify
things specific to Ecore (like instance class names).
> Suzette Samoojh
Re: Primitive Types - UML to EMF Generation [message #626242 is a reply to message #477104] Wed, 19 March 2008 09:00 Go to previous message
Suzette,
> Suzette Samoojh
Previous Topic:[Announce] MDT UML2 2.2.0 I200803111920 is available
Next Topic:Multiple return parameters
Current Time: Wed Jan 17 07:38:44 GMT 2018
Powered by FUDForum. Page generated in 0.01779 seconds
