Home » Modeling » UML2 » Resource from non UML2 uml model
Resource from non UML2 uml model [message #477066] Wed, 12 March 2008 00:31 Go to next message
Originally posted by: pfuriani.uci.edu
Resource resource = RESOURCE_SET.getResource(uri, true);
This is the line I use to create a resouce for a .uml file. This works
properly when the .uml file was created with the UML2 editor. However, when
the .uml file is created with a different UML program, Altova to be
specific, I notice that the "contents" array of the Resource object is
empty. So next when i call,
Package thePackage =
(Package)EcoreUtil.getObjectByType(resource.getContents(),
UMLPackage.Literals.PACKAGE);
,then "thePackage" is "null" because the contents of the Resource are
empty. I don't understand why the Resource contents only get filled in with
..uml files created with the UML2 editor and not by .uml files created by a
different editor. Its important that I can create a Resource from uml models
made by other programs besides UML2.
Re: Resource from non UML2 uml model [message #477071 is a reply to message #477066] Wed, 12 March 2008 03:08 Go to previous messageGo to next message
Kenn Hussey is currently offline Kenn HusseyFriend
Load UML resources from other tools will only work if the structure of those
files corresponds to the structure (schema) used by UML2. Can you provide a
sample of one of the resources you're trying to load?
Kenn
"PFuriani" <pfuriani@uci.edu> wrote in message
news:fr782p$5g6$1@build.eclipse.org...
> when the .uml file is created with a different UML program, Altova to be
> with .uml files created with the UML2 editor and not by .uml files created
> by a different editor. Its important that I can create a Resource from uml
> models made by other programs besides UML2.
Re: Resource from non UML2 uml model [message #477097 is a reply to message #477071] Thu, 13 March 2008 22:02 Go to previous messageGo to next message
Here is the file that I am trying. I created this in Altova and used their
export as .xmi feature.
"Kenn Hussey" <Kenn.Hussey@embarcadero.com> wrote in message
news:fr7hfr$8ml$1@build.eclipse.org...
> those
> a
> Kenn
>> created
>> uml
Re: Resource from non UML2 uml model [message #477145 is a reply to message #477097] Thu, 27 March 2008 15:17 Go to previous messageGo to next message
Sorry for the delayed response. I've taken a look at your model, and as it
turns out, I think this is a problem with the way content type recognition
is being done by EMF - there's nothing wrong with your model, but I think
what's happening is that the document isn't being recognized as a UML
document because the first "real" element in the document is an
xmi:Documentation element (instead of an element from the UML namespace).
Please open a Bugzilla request against EMF and attach your sample model as a
test case; in the meantime, you can work around the problem by removing the
documentation element (or moving it to later in the file).
Kenn
news:frc848$sav$1@build.eclipse.org...
> their export as .xmi feature.
>> those
>> a
>> Kenn
>>> created
>>> uml
Re: Resource from non UML2 uml model [message #477230 is a reply to message #477145] Wed, 09 April 2008 18:54 Go to previous message
I've gone ahead and submitted the bug for you -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=226322.
Kenn
news:fsgdr2$g8p$1@build.eclipse.org...
> a test case; in the meantime, you can work around the problem by removing
> the documentation element (or moving it to later in the file).
> Kenn
>>> those
>>> provide a
>>> Kenn
>>>> be
>>>> created
>>>> uml
Re: Resource from non UML2 uml model [message #626198 is a reply to message #477066] Wed, 12 March 2008 03:08 Go to previous message
Kenn
Re: Resource from non UML2 uml model [message #626226 is a reply to message #477071] Thu, 13 March 2008 22:02 Go to previous message
> those
> a
> Kenn
>> created
>> uml
Re: Resource from non UML2 uml model [message #626279 is a reply to message #477097] Thu, 27 March 2008 15:17 Go to previous message
Kenn
>> those
>> a
>> Kenn
>>> created
>>> uml
Re: Resource from non UML2 uml model [message #626388 is a reply to message #477145] Wed, 09 April 2008 18:54 Go to previous message
Kenn
> Kenn
>>> those
>>> provide a
>>> Kenn
>>>> be
>>>> created
>>>> uml
Previous Topic:Which Plugin Do I need to view UML graphically?
Next Topic:Operation and Interfaces
Current Time: Sun May 27 07:42:29 GMT 2018
Powered by FUDForum. Page generated in 0.01931 seconds
