Home » Modeling » UML2 » Re: [UML2] programmatically set the type of a newly created Parameter???
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #477015] Mon, 03 March 2008 18:27 Go to next message
Kenn Hussey is currently offline Kenn HusseyFriend
Jinhui,
This question is more appropriate for the UML2 newsgroup (copied).
To progammatically set the type of a parameter, simply call setType(Type),
passing the desired type as an argument.
Kenn
"Jinhui" <zhuj@in.tum.de> wrote in message
news:0cf126e1bb6a4f41a1a402583bbd8e00$1@www.eclipse.org...
> Hello everyone,
> I have a questions: I've programmatically created a Parameter, and how can
> I set the type of it to Integer?
> I've tried as following:
> 1 Parameter p = UMLFactory.eINSTANCE.createParameter();
> 2 p.setDirection(ParameterDirectionKind.RETURN_LITERAL);
> 3 p.setUpper(1);
> 4 p.setLower(1);
> 5 LiteralInteger li = UMLFactory.eINSTANCE.createLiteralInteger();
> 6 li.setValue(3);
> 7 System.out.println("type" + li.getType().toString());
> 8 p.setType(li.getType());
> 9 return p;
> but at line 7, the type of "li" is still null??
> so how to set the type of a Parameter to a primitive tpye, such as Integer
> or String or boolean?
> regards
> Jinhui
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #477016 is a reply to message #477015] Mon, 03 March 2008 18:32 Go to previous message
Jinhui,
Additionally, note that a LiteralInteger does not come into existence
knowing that its type is (or even should be) Integer. You will have to
retrieve the Integer primitive type from the UML (or Java) Primitive Types
model library in order to reference it as the parameter's type.
Christian
Kenn Hussey wrote:
> Jinhui,
> Kenn
>> Hello everyone,
>> can I set the type of it to Integer?
>> 3 p.setUpper(1);
>> 4 p.setLower(1);
>> 6 li.setValue(3);
>> 9 return p;
>> Integer or String or boolean?
>> regards
>> Jinhui
Re: [UML2] programmatically set the type of a newly created Parameter??? [message #626120 is a reply to message #477015] Mon, 03 March 2008 18:32 Go to previous message
Jinhui,
Christian
Kenn Hussey wrote:
> Jinhui,
> Kenn
>> Hello everyone,
>> 3 p.setUpper(1);
>> 4 p.setLower(1);
>> 6 li.setValue(3);
>> 9 return p;
>> regards
>> Jinhui
Previous Topic:Re: [UML2] programmatically set the type of a newly created Parameter???
Next Topic:[UML2] how to load UML_PRIMITIVE_TYPES_LIBRARY
Current Time: Sat Jun 23 06:11:29 GMT 2018
Powered by FUDForum. Page generated in 0.02014 seconds
