Home » Eclipse Projects » Platform - User Assistance (UA) » Please confirm allowable link_to path structures using PLUGINS_ROOT
Please confirm allowable link_to path structures using PLUGINS_ROOT [message #475569] Tue, 26 May 2009 15:37 Go to next message
Lee Anne Kowalski is currently offline Lee Anne KowalskiFriend
Member
Would someone on the Eclipse UA team please confirm which of the
following are supposed to work when specified in the link_to attribute?
And which one you would consider is a "best practice"?
Given a doc plug-in with:
pluginID = edition1_1
toc file = edition1_1.xml
anchorID in edition1_1.xml = comps
Trying to anchor into that anchorID using link_to, I see the following
behaviors:
link_to="/../edition1_1/edition1_1.xml#comps Works in Eclipse 3.4.1
link_to="/edition1_1/edition1_1.xml#comps Works
link_to="../edition1_1/edition1_1.xml#comps Works (this is also
in the help doc example in ua_help_content_nested.htm topic)
link_to="PLUGINS_ROOT/edition1_1/edition1_1.xml#comps Works
link_to="/PLUGINS_ROOT/edition1_1/edition1_1.xml#comps Does Not work
Now, the help topic on Content Extensions
( http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.platform.doc.isv/guide/ua_dynamic_extensions.htm)
says that the format of the 'path" attribute is:
/pluginID/path/file.xml#elementID
So, is it a bug that link_to="/PLUGINS_ROOT/<pluginID>/<tocfile>#anchorID"
does not work?
Or is PLUGINS_ROOT not useful for contributing into an anchor?
Is the best practice to use the path attribute format? For example:
link_to="/pluginID/path/file.xml#anchorID"
Thanks in advance!
--Lee Anne
Re: Please confirm allowable link_to path structures using PLUGINS_ROOT [message #475603 is a reply to message #475569] Wed, 27 May 2009 22:59 Go to previous messageGo to next message
Chris Goldthorpe is currently offline Chris GoldthorpeFriend
> does not work?
It really is not necessary to specify PLUGINS_ROOT when contributing to
an anchor. The support for PLUGINS_ROOT is only there to allow the TOC
contributions to use the same format as is used for hrefs. I suppose
that if we are going to support PLUGINS_ROOT we should also support
/PLUGINS_ROOT and you could file a bug on that.
Thanks! (was Re: Please confirm allowable link_to path structures using PLUGINS_ROOT [message #475606 is a reply to message #475603] Fri, 29 May 2009 20:38 Go to previous message
Member
Hi Chris,
Thanks for that confirmation about anchor contributions and PLUGINS_ROOT.
I was using a tool that kept inserting a slash into the path that I
typed for my link_to, and that was messing things up when I included
PLUGINS_ROOT in the path, and I could't figure out why having that slash
made such a difference in that case. :-)
Thanks again!
--Lee Anne
> > does not work?
Re: Please confirm allowable link_to path structures using PLUGINS_ROOT [message #623378 is a reply to message #475569] Wed, 27 May 2009 22:59 Go to previous message
> does not work?
Thanks! (was Re: Please confirm allowable link_to path structures using PLUGINS_ROOT [message #623380 is a reply to message #475603] Fri, 29 May 2009 20:38 Go to previous message
Member
Hi Chris,
Thanks again!
--Lee Anne
> > does not work?
Previous Topic:Force Welcome page for product to open docked?
Next Topic:Link to a file outside the plugins folder
Current Time: Wed May 23 11:29:07 GMT 2018
Powered by FUDForum. Page generated in 0.01685 seconds
