Home » Eclipse Projects » JavaServer Faces » Is it possible to run JSF (EL) Validator against a Stream?
Is it possible to run JSF (EL) Validator against a Stream? [message #474838] Wed, 11 July 2007 14:30 Go to next message
Tanyu Trifonov is currently offline Tanyu TrifonovFriend
Member
I'm writing a plugin. I have a stream and I want to check it with the JSF
(Expression Language) Validator to see if it valid JSF. How can I do that?
Thanks in advanced!
Tanyu
Re: Is it possible to run JSF (EL) Validator against a Stream? [message #474840 is a reply to message #474838] Wed, 11 July 2007 23:59 Go to previous messageGo to next message
Cameron Bateman is currently offline Cameron BatemanFriend
You have several options depending on what you want to do. If all you
want to do is a syntax check, then have a look at how
ELExpressionValidator.validateXMLNode() makes use of the JSPELParser.
This will give an AST if successful (valid) and an error otherwise
(invalid).
If you want to do a semantic analysis, you currently need to provide the
file context within which your JSF EL is embedded. You can look at
AbstractDataModelVariableFactory.createValueExpression() to see how to do
this.
We currently have this enhancement request:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=151703 tracking requirements
to support JSF EL more widely. If you have specific requirements in this
area that you would like to see, please post them to that bug so we can
get a more specific idea of what people need in this area.
Re: Is it possible to run JSF (EL) Validator against a Stream? [message #474845 is a reply to message #474840] Thu, 12 July 2007 07:48 Go to previous messageGo to next message
Member
Hi Cameron,
It seems this is what I need. Thanks for your answer. But I noticed that
ELExpressionValidator was internal. What are your plans for the future
about it? Will you make it public?
Tanyu
> (invalid).
> this.
Re: Is it possible to run JSF (EL) Validator against a Stream? [message #474851 is a reply to message #474845] Fri, 13 July 2007 18:27 Go to previous message
We had plans to do so in 2.0 but had to back off for lack of time
(creating public API has a cost because it increases the maintenance
requirements). If you attach your requirements to the bug I mentioned in
the previous post, this will help us to prioritize the requirements in
this area.
--Cam
Re: Is it possible to run JSF (EL) Validator against a Stream? [message #613086 is a reply to message #474838] Wed, 11 July 2007 23:59 Go to previous message
(invalid).
this.
Re: Is it possible to run JSF (EL) Validator against a Stream? [message #613088 is a reply to message #474840] Thu, 12 July 2007 07:48 Go to previous message
Member
Hi Cameron,
Tanyu
> (invalid).
> this.
Re: Is it possible to run JSF (EL) Validator against a Stream? [message #613091 is a reply to message #474845] Fri, 13 July 2007 18:27 Go to previous message
this area.
--Cam
Previous Topic:JSFLibraries and PluginProvidedJsfLibraries
Next Topic:JSF message bundle auto-complete with localization?
Current Time: Mon Apr 23 15:44:14 GMT 2018
Powered by FUDForum. Page generated in 0.02324 seconds
