Home » Eclipse Projects » Platform - User Assistance (UA) » Re: Help search displaying <?xml tag in the search results
Re: Help search displaying <?xml tag in the search results [message #474326] Tue, 09 September 2008 11:36 Go to next message
Chris Aniszczyk is currently offline Chris Aniszczyk
Moving to the proper newsgroup
Mike Higginbotham wrote:
> Hello,
> The newest release of our RCP app is using Eclipse 3.4. It had
> previously been using 3.2. With the change to 3.4 we are seeing an
> oddity in the help search results. Some of the search results are
> displaying the <?xml tag in the summary information of the results as
> shown in the attached screen shot.
> As shown in the screen shot, the first result does not have the <?xml
> but the second does. Both files are named using a .htm extension. The
> file for the first result starts with:
> <!doctype HTML public "-//W3C//DTD HTML 4.0 Frameset//EN">
> <html>
> The file for the second result starts with:
> <html xmlns="http://www.w3.org/1999/xhtml">
> Apparently, something has changed in the framework that is causing this.
> In looking for an answer to this on the web I noticed that a similar
> problem shows up on the help index page for 3.3
> (http://help.eclipse.org/help33/index.jsp) when searching for "essential
> xpath". However, the same search using the help index page for 3.4
> (http://help.eclipse.org/ganymede/index.jsp) does not have this problem.
> What do I need to do in 3.4 to keep the <?xml tag from being displayed
> in the search results?
> Mike Higginbotham
Re: Help search displaying <?xml tag in the search results [message #474328 is a reply to message #474326] Tue, 09 September 2008 13:44 Go to previous messageGo to next message
Chris Goldthorpe is currently offline Chris Goldthorpe
See https://bugs.eclipse.org/bugs/show_bug.cgi?id=246095 for a
discussion of how to work round this.
Re: Help search displaying <?xml tag in the search results [message #474331 is a reply to message #474328] Tue, 09 September 2008 17:38 Go to previous message
Mike Higginbotham is currently offline Mike Higginbotham
Re: Help search displaying <?xml tag in the search results [message #619856 is a reply to message #474326] Tue, 09 September 2008 13:44 Go to previous message
Re: Help search displaying <?xml tag in the search results [message #619859 is a reply to message #474328] Tue, 09 September 2008 17:38 Go to previous message
Previous Topic:Something missing?: 3.4 minimal standalone help system instructions
Next Topic:Some ViewPart's do not activate dynamic help correctly.
Current Time: Fri May 24 02:59:43 EDT 2013
Powered by FUDForum. Page generated in 0.07117 seconds
