SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #474156] |
Mon, 30 April 2007 09:06 |
Originally posted by: dnatochy.gmail.com
Hello there,
Pardon my ignorance, I am new to Eclipse and JSF.
I followed the steps from this webinar
https://admin.adobe.acrobat.com/_a300965365/p87371911/ to create a demo app.
However when I click on a jsp file and select Run As -> Run on Server, I am
getting a nasty error from Tomcat:
Apr 30, 2007 1:58:57 AM org.apache.catalina.core.ApplicationContext log
SEVERE: StandardWrapper.Throwable
at javax.faces.webapp.FacesServlet.init(FacesServlet.java:144)
org.apache.catalina.core.StandardWrapper.loadServlet(Standar dWrapper.java:1139)
at org.apache.catalina.core.StandardWrapper.load(StandardWrappe r.java:966)
org.apache.catalina.core.StandardContext.loadOnStartup(Stand ardContext.java:3956)
at org.apache.catalina.core.StandardContext.start(StandardConte xt.java:4230)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1014)
at org.apache.catalina.core.StandardHost.start(StandardHost.jav a:736)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:443)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:448)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:700)
at org.apache.catalina.startup.Catalina.start(Catalina.java:552 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 95)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:43 3)
Apr 30, 2007 1:58:57 AM org.apache.catalina.core.StandardContext
loadOnStartup
SEVERE: Servlet /jsfwebinar threw load() exception
Apr 30, 2007 1:58:57 AM org.apache.coyote.http11.Http11BaseProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Apr 30, 2007 1:58:57 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Apr 30, 2007 1:58:57 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/15 config=null
Apr 30, 2007 1:58:57 AM org.apache.catalina.storeconfig.StoreLoader load
INFO: Find registry server-registry.xml at classpath resource
Apr 30, 2007 1:58:57 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 719 ms
Apr 30, 2007 1:58:58 AM org.apache.catalina.core.ApplicationContext log
org.apache.catalina.core.StandardWrapper.allocate(StandardWr apper.java:791)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:127)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:174)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:151)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:870)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:685)
at java.lang.Thread.run(Unknown Source)
Apr 30, 2007 1:58:58 AM org.apache.catalina.core.StandardWrapperValve invoke
My guess is that JSF jars are not included in the deployed app. If so, how I
do tell Eclipse to do that?
I am running Eclipse 3.3 with Tomcat 5.5 (java jre1.5.0_10).
Dennis
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #474179 is a reply to message #474157] |
Wed, 02 May 2007 05:05 |
Cameron/Raghu,
I am using :
Sun Reference implementation (RI) for JSR 127 (jsf1.1):
http://javashoplm.sun.com/ECom/docs/Welcome.jsp?StoreId=22&a mp;PartDetailId=jsf-1.1-ri-oth-JPR&SiteId=JSC&Transa ctionId=noreg
JSF facet is installed in Eclipse.
web.xml:
<?xml version="1.0" encoding="UTF-8"?><!DOCTYPE web-app PUBLIC "-//Sun
Microsystems, Inc.//DTD Web Application 2.3//EN"
"http://java.sun.com/dtd/web-app_2_3.dtd">
<web-app id="WebApp_ID">
<display-name>JSFWebinarDemo2</display-name>
<servlet>
<servlet-name>Faces Servlet</servlet-name>
<servlet-class>
javax.faces.webapp.FacesServlet</servlet-class>
<load-on-startup>1</load-on-startup>
</servlet>
<servlet-mapping>
<url-pattern>*.faces</url-pattern>
</servlet-mapping>
<welcome-file-list>
<welcome-file>index.html</welcome-file>
<welcome-file>index.htm</welcome-file>
<welcome-file>index.jsp</welcome-file>
<welcome-file>default.html</welcome-file>
<welcome-file>default.htm</welcome-file>
<welcome-file>default.jsp</welcome-file>
</welcome-file-list>
</web-app>
faces-config.xml:
<!DOCTYPE faces-config PUBLIC
"-//Sun Microsystems, Inc.//DTD JavaServer Faces Config 1.1//EN"
"http://java.sun.com/dtd/web-facesconfig_1_1.dtd">
<faces-config>
</faces-config>
JSF libraries do not have spaces in their names.
One strange thing: I've been testing on Tomcat 5.5. Then I installed 6.0 -
same issue. Tried 5.0 - works! Unfortunately I would like to use java 1.5,
which is not supported by tomcat 5.0 as far as I understand. :(
"Cameron Bateman" <cameron.bateman@oracle.com> wrote in message
news:5042aabec15132cd1df464eb5a8d0c9f$1@www.eclipse.org...
> Did you install the JSF facet when you created the dynamic web project?
> That should cause the addition of the JSF libraries.
> Can you show me your web.xml and faces-config.xml files? Also, which JSF
> implementation are you using (i.e. where did you download it from).
> --Cam
Re: SEVERE: Allocate exception for servlet Faces Servlet java.lang.NullPointerException [message #610954 is a reply to message #474157] |
Cameron/Raghu,
I am using :
web.xml:
<servlet>
<servlet-class>
</servlet>
<servlet-mapping>
</servlet-mapping>
<welcome-file-list>
</web-app>
faces-config.xml:
<faces-config>
</faces-config>
> --Cam
FUDForum. Page generated in 0.04599 seconds
