Home » Modeling » UML2 Tools » Light bug with save as
Light bug with save as [message #470733] Tue, 15 May 2007 13:35 Go to next message
Philippe is currently offline PhilippeFriend
playing around a little more with UML2Tools,
I simply clicked on 'Save as'
and I got two simple issues :
1- if I let the original name of the file I get the message :
Save could not be completed. Target file is already open in another
editor.
2- if I enter a new file name, I get the error message :
Cannot open input element:
Reason : Resource xxx does not exist
I believe it is not the excepted behavior of 'Save as' ;)
Has anyone already reported this as a bug ?
Philippe
Re: Light bug with save as [message #470739 is a reply to message #470733] Tue, 15 May 2007 21:25 Go to previous messageGo to next message
Tatiana Fesenko is currently offline Tatiana FesenkoFriend
Hi Philippe!
The situation you described looks really wrong. Whatever a person does on
"Save as" error dialog appears. This looks like a GMF or GMF Runtime bug.
UML2Tools Diagrams will be regenerated with new GMF in a few days, so it may
be fixed. Let's wait till Friday and after that I will check the situation
and commit a CR if needed. I think it will be needed, as there is no such
report in "GMF New and Noteworthy"
( http://wiki.eclipse.org/index.php/GMF_New_and_Noteworthy#2.0 _M7_.28May_18.2C_2007.29).
Best wishes,
Tatiana.
"Philippe" <philippeweber57@yahoo.fr> wrote in message
news:f2cd1p$ui6$1@build.eclipse.org...
> editor.
> Regards
> Philippe
Re: Light bug with save as [message #470787 is a reply to message #470733] Fri, 18 May 2007 10:02 Go to previous message
Hi Philippe!
The problem is still relevant with new GMF. I've commited #187772 ""Save
as..." doesn't work" in bugzilla.
Thank you.
Tatiana.
> editor.
> Regards
> Philippe
Re: Light bug with save as [message #593494 is a reply to message #470733] Tue, 15 May 2007 21:25 Go to previous message
Hi Philippe!
Best wishes,
Tatiana.
> editor.
> Regards
> Philippe
Re: Light bug with save as [message #594078 is a reply to message #470733] Fri, 18 May 2007 10:02 Go to previous message
Hi Philippe!
Thank you.
Tatiana.
> editor.
> Regards
> Philippe
Previous Topic:Command for creating Generalization
Next Topic:using uml2tools
Current Time: Wed May 23 15:18:08 GMT 2018
Powered by FUDForum. Page generated in 0.01414 seconds
