Home » Modeling » Papyrus » Is the new Papyrus file format compatible with the old papyrus file format?
Is the new Papyrus file format compatible with the old papyrus file format? [message #469840] Wed, 22 April 2009 19:14 Go to next message
Johan  is currently offline Johan Friend
Member
Dear all,
I am thinking about starting to use the old Papyrus (www.papyrusuml.org)
and later switch to the new Papyrus (www.eclipse.org/mdt) once that is
becoming a bit more completed.
My questions is if the data files are compatible, in other words, can I
start to use the old Papyrus to create UML model files, and just open them
in the new Papyrus later on? Or will that not be possible?
Any suggestions are most welcome.
Kind regards,
Johan
Re: Is the new Papyrus file format compatible with the old papyrus file format? [message #469841 is a reply to message #469840] Thu, 30 April 2009 09:13 Go to previous messageGo to next message
Patrick Tessier is currently offline Patrick TessierFriend
Hi Johan,
In the new papyrus, diagram files will be based on GMF technology. So, we
have planned to develop import tool in order to work on models produced by
the old version of papyrus.
"Johan " <m6b32@hotmail.com> a
Re: Is the new Papyrus file format compatible with the old papyrus file format? [message #469845 is a reply to message #469841] Wed, 06 May 2009 15:23 Go to previous message
Tor Neple is currently offline Tor NepleFriend
Member
Just as a matter of curiosity. Does this mean that the Diagram
Interchange standard will not be supported any more?
Tor
On 2009-04-30 11:13, Patrick Tessier wrote:
> Hi Johan,
> "Johan "<m6b32@hotmail.com> a écrit dans le message de news:
> 17d44da649abc3cf0d8542a54b0da71c$1@www.eclipse.org...
>> Dear all,
>> Kind regards,
>> Johan
Re: Is the new Papyrus file format compatible with the old papyrus file format? [message #584631 is a reply to message #469840] Thu, 30 April 2009 09:13 Go to previous message
Hi Johan,
Re: Is the new Papyrus file format compatible with the old papyrus file format? [message #584679 is a reply to message #469841] Wed, 06 May 2009 15:23 Go to previous message
Member
Tor
> Hi Johan,
>> Dear all,
>> Kind regards,
>> Johan
Previous Topic:Corrupt Ordering of Interaction Fragments in Sequence Diagram
Next Topic:modeling task with UML MARTE on papyrus
Current Time: Fri Jun 22 07:55:38 GMT 2018
Powered by FUDForum. Page generated in 0.01758 seconds
