Home » Modeling » Papyrus » Missing operations of realized interfaces in StateMachine Diagram
Missing operations of realized interfaces in StateMachine Diagram [message #469782] Thu, 26 March 2009 05:45 Go to next message
Timothy Marc is currently offline Timothy Marc
Hey all,
i've created an interface, which is realized by a component. In the
context of this component, i've defined a state machine, just with a few
states and transitions. Now, i want to create a CallEvent as the
transitions trigger, which points to a operation, provided by the
realized interface. That is not possible! Only directly contained
operations can be selected.
Is there a work around because it seems to me very cumbersome, to
recreate each operation, which is already defined in the interface.
Thx
Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #469788 is a reply to message #469782] Thu, 26 March 2009 15:08 Go to previous messageGo to next message
Yann Tanguy is currently offline Yann Tanguy
Member
In fact, we assumed that an Interface operation should have an
implementation in the realizing Class for operations defined in the
interfaces.
This is slightly different with Class inheritance, as the operation can
be defined and implemented in the father class without necessary being
overrided in children. In this case you can refers Class owned
operations and inherited operations.
As a workaround you may want to use a Generalization between the Class
and Interface (instead of Realization).
Alternately, you could implement a small Popup action the copies
operations from realized Interfaces into current Class.
regards,
Yann Tanguy
Timothy Marc a écrit :
> Hey all,
> Thx
> Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #469790 is a reply to message #469788] Thu, 26 March 2009 21:54 Go to previous messageGo to next message
Eclipse User
Originally posted by: give.a.damus.gmail.com
Hi, Yann,
Unfortunately, UML does not permit Classes to have Generalization
relationships to Interfaces. Generalizations are only well-formed from
a specializing classifier to a general classifier of the same metaclass
or a more general metaclass. Thus, for example, an AssociationClass may
specialize an Association or a Class, but a Class or Association may not
specialize an AssociationClass or an Interface.
Christian
-----8<-----
Re: Missing operations of realized interfaces in StateMachine Diagram [message #469792 is a reply to message #469788] Fri, 27 March 2009 05:15 Go to previous messageGo to next message
So, if this behavior is not a bug, but a feature. But due to the fact,
that the UML Superstructure doesn't allow a Generalization between Class
und Interface, it would be nice, if the Operations provided by
InterfaceRealization are shown within the Dialog in a seperate Tree,
that shows only these kind of Operations.
I think this might be a good alternative in contrast to those hacky
workarounds, isn't it?
Timothy
> interfaces.
> regards,
> Yann Tanguy
>> Hey all,
>> few states and transitions. Now, i want to create a CallEvent as the
>> Thx
>> Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #469794 is a reply to message #469790] Fri, 27 March 2009 05:55 Go to previous messageGo to next message
Member
Hi Christian,
You are probably right but I could not figure out the constraint you
mention in the UML2 spec.
Structurally, Interface inherits from Classifier and Generalization
links Classifiers. I did not see constraint related to Generalization in
the specification except this one:
[1] Every Generalization associated with a given GeneralizationSet must
have the same general Classifier. That is, all
Generalizations for a particular GeneralizationSet must have the same
superclass.
Yann
Christian W. Damus a écrit :
> Hi, Yann,
> Cheers,
> Christian
> -----8<-----
Re: Missing operations of realized interfaces in StateMachine Diagram [message #469796 is a reply to message #469792] Fri, 27 March 2009 09:46 Go to previous messageGo to next message
Member
Hi Timothy,
Sorry for the confusion, my mistake:
- yes this should be possible (atually it is, I just fixed this in the
source code)
The workaround I proposed were "ready-to-use-alternate" solutions to
resume your modeling work without waiting for the fix.
regards,
Yann
> Timothy
>> interfaces.
>> can be defined and implemented in the father class without necessary
>> being overrided in children. In this case you can refers Class owned
>> regards,
>> Yann Tanguy
>>> Hey all,
>>> Thx
>>> Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #469799 is a reply to message #469796] Fri, 27 March 2009 12:02 Go to previous messageGo to next message
Well, i'm looking forward to test it :-)
Thx Timothy
> Hi Timothy,
> source code)
> regards,
> Yann
>> Class und Interface, it would be nice, if the Operations provided by
>> Timothy
>>> interfaces.
>>> Class and Interface (instead of Realization).
>>> regards,
>>> Yann Tanguy
>>>> Hey all,
>>>> the transitions trigger, which points to a operation, provided by
>>>> the realized interface. That is not possible! Only directly
>>>> contained operations can be selected.
>>>> Thx
>>>> Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #469832 is a reply to message #469794] Sat, 28 March 2009 11:40 Go to previous message
Eclipse User
Hi, Yann,
It isn't actually a Generalization constraint, but a Classifier constraint:
[3] A classifier may only specialize classifiers of a valid type.
self.parents()->forAll(c | self.maySpecializeType(c))
Classifier::maySpecializeType(Classifier) is defined thus:
[8] The query maySpecializeType() determines whether this classifier may
have a generalization relationship to classifiers of
the specified type. By default a classifier may specialize classifiers
of the same or a more general type. It is intended to be
redefined by classifiers that have different specialization constraints.
Classifier::maySpecializeType(c : Classifier) : Boolean;
maySpecializeType = self.oclIsKindOf(c.oclType)
It uses the non-existent oclType attribute which, in OCL 2.1, will be
re-introduced as an oclType() query. It obtains an element's metaclass.
As it happens, maySpecializeType() is nowhere redefined, so this
constraint holds for all classifiers.
Christian
Yann Tanguy wrote:
> Hi Christian,
> superclass.
> Best regards,
> Yann
-----8<-----
Re: Missing operations of realized interfaces in StateMachine Diagram [message #582267 is a reply to message #469782] Thu, 26 March 2009 15:08 Go to previous message
Member
interfaces.
regards,
Yann Tanguy
> Hey all,
> Thx
> Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #582285 is a reply to message #469788] Thu, 26 March 2009 21:54 Go to previous message
Eclipse User
Hi, Yann,
Christian
-----8<-----
Re: Missing operations of realized interfaces in StateMachine Diagram [message #582300 is a reply to message #469788] Fri, 27 March 2009 05:15 Go to previous message
Timothy
> interfaces.
> regards,
> Yann Tanguy
>> Hey all,
>> Thx
>> Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #582308 is a reply to message #469790] Fri, 27 March 2009 05:55 Go to previous message
Member
Hi Christian,
superclass.
Yann
> Hi, Yann,
> Cheers,
> Christian
> -----8<-----
Re: Missing operations of realized interfaces in StateMachine Diagram [message #582322 is a reply to message #469792] Fri, 27 March 2009 09:46 Go to previous message
Member
Hi Timothy,
source code)
regards,
Yann
> Timothy
>> interfaces.
>> regards,
>> Yann Tanguy
>>> Hey all,
>>> Thx
>>> Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #582341 is a reply to message #469796] Fri, 27 March 2009 12:02 Go to previous message
Thx Timothy
> Hi Timothy,
> source code)
> regards,
> Yann
>> Timothy
>>> interfaces.
>>> regards,
>>> Yann Tanguy
>>>> Hey all,
>>>> Thx
>>>> Timothy
Re: Missing operations of realized interfaces in StateMachine Diagram [message #584485 is a reply to message #469794] Sat, 28 March 2009 11:40 Go to previous message
Eclipse User
Hi, Yann,
Christian
Yann Tanguy wrote:
> Hi Christian,
> superclass.
> Best regards,
> Yann
-----8<-----
Previous Topic:Static profiles from 3rd party for Papyrus
Next Topic:Buildin PapyrusUML from souce
Current Time: Thu May 23 21:45:26 EDT 2013
Powered by FUDForum. Page generated in 0.04842 seconds
