Home » Eclipse Projects » Rich Client Platform (RCP) » How to refresh the Tree Element while expanding
How to refresh the Tree Element while expanding [message #467759] Thu, 10 May 2007 14:27 Go to next message
Originally posted by: johansusai.yahoo.co.in
I have created tree using Treeviewer. while expanding the tree element i want to refresh that particular node along with its child. kindly give suggestion on how to do this.
whether to use listener or is there other any way to do it.
johan
Re: How to refresh the Tree Element while expanding [message #467773 is a reply to message #467759] Thu, 10 May 2007 17:10 Go to previous messageGo to next message
David Kyle is currently offline David KyleFriend
Johan,
Try using a ITreeContentProvider with your Treeviewer.
ITreeContentProvider#getChildren(Object) will give you the flexibility of
caching your results or always fetching the most current children.
treeviewer.setContentProvider(new ITreeContentProvider() {
// implement interface
David
"Johanantonysusai" <johansusai@yahoo.co.in> wrote in message
news:15551278.1178807288426.JavaMail.root@cp1.javalobby.org...
> johan
Re: How to refresh the Tree Element while expanding [message #467781 is a reply to message #467773] Thu, 10 May 2007 17:35 Go to previous message
Thomas Schindl is currently offline Thomas SchindlFriend
That's not true. When the items are already created the this method is
not called any more. You need to to call treeViewer#refresh(Object).
This will refresh the children from this object.
Tom
David Kyle schrieb:
> Johan,
> David
>> Thanks,
>> johan
Previous Topic:Redirect logs
Next Topic:Eclipse RCP 3.3M6 and Java Web Start
Current Time: Fri May 25 09:21:45 GMT 2018
Powered by FUDForum. Page generated in 0.02030 seconds
