Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Hexagon
| Hexagon [message #467655] |
Fri, 03 February 2006 00:59  |
Mark Baldridge Messages: 1 Registered: July 2009 |
Junior Member |
I have been attempting to render a (playing) field of 60x100 hexagons in a
JScrollPane that I have working in Swing into an SWT environment as a
learning project.
I have perused SWT Volume 1 by Steve Northover, and have so far only
succeeded by modifying the Shell bounded by a Region as in one of the
book's examples. Each shell, however, has its own identity on the task
bar. It seems that only a shell supports the Region clipping. The Swing
implementation subclasses a JButton and uses the contains() to clip the
hexagon.
In SWT, I extended Canvas as the typical extension point. I have not
figured out how to clip the drawing area to a hexagon so another hexagonal
image can fit up to its edge. The Canvas only understands a rectangular
bounds. I thought I might peruse the source to
org.eclipse.tptp.platform.report.drawutil.internal.ISymbol.H exagon for
additional ideas, but have not been able to access/find it.
So if a hexagon looks like:
1
6 2
5 3
4
and I add another hexagon adjacent to the 3-4 edge, the rectangle at the
3-4 edge overwrites the corner of the lower hexagon. I have not been able
to get the clipping to stop the rectangular bounds from obscuring the next
hexagon.
The following code demonstrates my consternation.
import org.eclipse.swt.SWT;
//import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.GC;
//import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.graphics.Region;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Canvas;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.custom.ScrolledComposite;
* Created on Jan 18, 2006
* To change this generated comment go to
* Window>Preferences>Java>Code Generation>Code and Comments
public class Hexagon extends Canvas implements Listener {
static final Color[][] colors = new Color[5][5];
static Region staticRegion = null;
Region region = null;
int[] hexagon = new int[12];
int colorNumber = 0;
boolean stateNormal = true;
public Hexagon(Composite parent, int style) {
super(parent, style);
addListener(SWT.Paint, this);
addListener(SWT.FocusIn, this);
addListener(SWT.FocusOut, this);
addListener(SWT.KeyDown, this);
addListener(SWT.MouseDown,this);
addListener(SWT.MouseUp,this);
// Rectangle bounds = this.getClientArea();
// System.out.println("ClientArea: "+bounds.toString());
// this.setSize(bounds.width,bounds.height);
static {
public void setColorNumber(int colorNumber) {
this.colorNumber = colorNumber;
public void setSize(int w, int h /*Shell hexShell*/) {
// int[] hexagon = new int[12];
// Rectangle bounds = hexShell.getBounds();
// int w = bounds.x;
// int h = bounds.y;
super.setSize(w,h);
if (staticRegion == null) {
staticRegion = new Region();
staticRegion.add(makeHexagon(w,h));
if (region == null) {
region = new Region();
this.hexagon = makeHexagon(w,h);
region.add(hexagon);
public int[] makeHexagon(int x, int y, int width, int height) {
// 5
// 4 6
// 3 1
// 2
// int x = rectangle.x;
// int y = rectangle.y;
// int width = rectangle.width;
// int height = rectangle.height;
int height1Quarter = (height-y)*1/4;
int height3Quarter = (height-y)*3/4;
int widthHalf = (width-x)/2;
hexagon[ 0] = width;
hexagon[ 1] = height3Quarter;
hexagon[ 2] = widthHalf;
hexagon[ 3] = height;
hexagon[ 4] = x;
hexagon[ 5] = height3Quarter;
hexagon[ 6] = x;
hexagon[ 7] = height1Quarter;
hexagon[ 8] = widthHalf;
hexagon[ 9] = y;
hexagon[10] = width;
hexagon[11] = height1Quarter;
return hexagon;
public static int[] makeHexagon(int w, int h) {
w = w-1;
hexagon[ 0] = w;
hexagon[ 1] = (h*3)/4;
hexagon[ 2] = w/2;
hexagon[ 3] = h;
hexagon[ 4] = 0;
hexagon[ 5] = (h*3)/4;
hexagon[ 6] = 0;
hexagon[ 7] = h/4;
hexagon[ 8] = w/2;
hexagon[ 9] = 0;
hexagon[10] = w;
hexagon[11] = h/4;
// hexagon[12] = w;
// hexagon[13] = (h*3)/4;
return hexagon;
public void handleEvent(Event event) {
GC gc;
switch (event.type) {
case SWT.Paint:
gc = event.gc;
// gc.getForeground()
gc.setClipping(region);
System.out.println("Paint isClipped: "+gc.isClipped()+" doit:
"+event.doit+", stateNormal: "+stateNormal);
System.out.println("colorNumber: "+colorNumber+", Color:
"+colors[colorNumber][((stateNormal) ? 0 : 1)]);
// this.setBackground(colors[colorNumber][((stateNormal) ? 0 : 1)]);
this.setForeground(colors[colorNumber][((stateNormal) ? 0 : 1)]);
// this.setForeground(colors[colorNumber][0]);
// gc.drawPolygon(hexagon);
// gc.fillPolygon(hexagon);
Rectangle size = this.getClientArea();
System.out.println("Size: "+size);
int x = size.x;
int y = size.y;
int width = size.width;
int height = size.height;
while ((width>0) && (height>0)) {
// System.out.println("x,y,w,h: "+x+","+y+","+width+","+height);
gc.drawPolygon(makeHexagon(x++,y,width--,height));
break;
case SWT.MouseDown:
System.out.println("MouseDown, xy: "+event.x+","+event.y+" doit:
"+event.doit);
System.out.println("Bounds: "+this.getBounds());
System.out.println("ClientArea: "+this.getClientArea());
if (region.contains(event.x,event.y)) {
stateNormal = false;
redraw();
} else {
event.doit = false;
break;
case SWT.MouseUp:
System.out.println("MouseUp, xy: "+event.x+","+event.y);
stateNormal = true;
redraw();
break;
case SWT.Dispose:
region.dispose();
break;
* @param args
Display display = new Display();
Color black = display.getSystemColor(SWT.COLOR_BLACK);
Color gray = display.getSystemColor(SWT.COLOR_GRAY);
final Color green = display.getSystemColor(SWT.COLOR_GREEN);
Color greenDark = display.getSystemColor(SWT.COLOR_DARK_GREEN);
final Color cyan = display.getSystemColor(SWT.COLOR_CYAN);
Color cyanDark = display.getSystemColor(SWT.COLOR_DARK_CYAN);
final Color red = display.getSystemColor(SWT.COLOR_RED);
Color redDark = display.getSystemColor(SWT.COLOR_DARK_MAGENTA);
// Color[] colors = new Color[32];
colors[0][0] = gray;
colors[0][1] = gray;
colors[1][0] = green;
colors[1][1] = greenDark;
colors[2][0] = cyan;
colors[2][1] = cyanDark;
colors[3][0] = red;
colors[3][1] = redDark;
GC gc = null;
// Region region = new Region();
int WIDTH = 60;
int HEIGHT = 80;
int WIDTH_DELTA = 30;
int HEIGHT_DELTA = 60;
// region.add(makeHexagon(WIDTH,HEIGHT));
Shell shell = new Shell(display,SWT.SHELL_TRIM);
Composite composite1 = new Composite(shell,SWT.NONE);
// ScrolledComposite composite1 = new
ScrolledComposite(shell,SWT.H_SCROLL | SWT.V_SCROLL);
// ScrolledComposite composite1 = new ScrolledComposite(shell,SWT.NONE);
Hexagon hexagon = new Hexagon(composite1,SWT.NONE);
// hexagon.setBounds(100,100,160,180);
hexagon.setLocation(100,100);
hexagon.setSize(WIDTH,HEIGHT);
hexagon.setColorNumber(1);
// gc = new GC(hexagon);
// gc.setClipping(region);
Hexagon hexagon2 = new Hexagon(composite1,SWT.NONE);
hexagon2.setLocation(130,160);
// hexagon2.setLocation(200,200);
// hexagon2.setLocation(100,100);
// hexagon2.setBounds(130,160,190,240);
hexagon2.setSize(WIDTH,HEIGHT);
hexagon2.setColorNumber(2);
Hexagon hexagon3 = new Hexagon(composite1,SWT.NO_BACKGROUND);
hexagon3.setLocation(250,250);
hexagon3.setSize(100,100);
hexagon3.setColorNumber(3);
composite1.pack();
shell.pack();
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
// region.dispose();
for (int ndxRow=0; ndxRow<5; ndxRow++) {
for (int ndxCol=0; ndxCol<5; ndxCol++) {
if (colors[ndxRow][ndxCol] != null) colors[ndxRow][ndxCol].dispose();
display.dispose();
| Re: Hexagon [message #467769 is a reply to message #467655] |
Mon, 06 February 2006 10:06  |
Veronika Irvine Messages: 1272 Registered: July 2009 |
Only Shells support a non-rectangular shape.
If you are drawing a playing field, why not just have one Canvas and draw
all of the hexagons on the same canvas? Why do you need to create a
separate widget (with on OS handle) for each hexagon? I would consider the
hexagons to be items - much in the same relationship as CTabItem and
CTabFolder. All the items are drawn on the same Canvas and you can impement
clipping within the Canvas. See GC.setClipping(Region).
"Mark Baldridge" <mbaldrid@us.ibm.com> wrote in message
news:c2e1a42ff86f403dc3a72e699788acf1$1@www.eclipse.org...
>learning project.
> hexagon.
> 1
> 6 2
> 5 3
> 4
> hexagon.
> import org.eclipse.swt.widgets.Display;
> * To change this generated comment go to * Window>Preferences>Java>Code
> static {
> super.setSize(w,h);
> // 5
> // 4 6
> // 3 1
> // 2
> hexagon[ 4] = x;
> hexagon[ 6] = x;
> hexagon[ 9] = y;
> return hexagon;
> w = w-1;
> hexagon[ 0] = w;
> hexagon[ 2] = w/2;
> hexagon[ 3] = h;
> hexagon[ 4] = 0;
> hexagon[ 6] = 0;
> hexagon[ 7] = h/4;
> hexagon[ 8] = w/2;
> hexagon[ 9] = 0;
> hexagon[10] = w;
> hexagon[11] = h/4;
> // hexagon[12] = w;
> return hexagon;
> GC gc;
> case SWT.Paint:
> gc = event.gc;
> int x = size.x;
> int y = size.y;
> break;
> case SWT.MouseDown:
> "+event.doit);
> redraw();
> } else {
> event.doit = false;
> break;
> case SWT.MouseUp:
> stateNormal = true;
> redraw();
> break;
> case SWT.Dispose:
> region.dispose();
> break;
> * @param args
> public static void main(String[] args) {
> colors[3][0] = red;
> GC gc = null;
> int WIDTH = 60;
> int HEIGHT = 80;
> // ScrolledComposite composite1 = new ScrolledComposite(shell,SWT.H_SCROLL
> | SWT.V_SCROLL);
> composite1.pack();
> shell.pack();
> shell.open();
> if (colors[ndxRow][ndxCol] != null) colors[ndxRow][ndxCol].dispose(); }
> display.dispose();
Current Time: Sun May 19 23:36:43 EDT 2013
Powered by FUDForum. Page generated in 0.01686 seconds
