Home » Eclipse Projects » Rich Client Platform (RCP) » Use of setShowPerspectiveBar
Use of setShowPerspectiveBar [message #466627] Mon, 23 April 2007 10:45 Go to next message
Dominic Hanlan is currently offline Dominic HanlanFriend
Member
I have an RCP application where by I have an initial login screen
created with a non closeable view, this belongs to a login perspective.
When I have a successful login I switch to a different perspective.
My question is, is it possible to not show the perspective bar in the
initial login perspective and then show it when a successful login has
occurred.
It appears that the setShowPerspectiveBar is only available during the
preWindowOpen phase of the application.
Any ideas on how to access this at other times, if indeed it is possible??
/Dominic
Re: Use of setShowPerspectiveBar [message #466646 is a reply to message #466627] Mon, 23 April 2007 16:26 Go to previous message
Prakash G.R. is currently offline Prakash G.R.Friend
If your idea is to prevent the user from doing anything before logging in, I think there is a better solution. Eclipse 3.3 M6 has a custom splash screen where you can do the login part. Have a look at:
http://download.eclipse.org/eclipse/downloads/drops/S-3.3M6- 200703231616/eclipse-news-M6.html
Previous Topic:Palette.Label
Next Topic:RCP build using wrong version of plugin - how to specify?
Current Time: Thu Apr 26 21:10:30 GMT 2018
Powered by FUDForum. Page generated in 0.01476 seconds
