Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Excluding custom Composite from tab order
Excluding custom Composite from tab order [message #466599] Wed, 11 January 2006 20:48 Go to next message
Peter Nehrer is currently offline Peter NehrerFriend
I have a custom Composite (with two Labels in it), which I use within a
form Section. When tabbing through other controls in the section, focus
gets "eaten" by the custom composite -- can't tab out of it again (until
I click some other focusable control).
I understand that I can implement TraverseListener and set e.doit = true
to make this piece work, but what I really want to do is make this
composite behave like a Label in that I want it to be skipped altogether
when traversing. I also know that I can do this by excluding the
composite from its parent's tablist.
However, this would require me to modify code outside of the custom
composite itself -- after the parent is constructed, remove all
instances of this custom composite from its tablist.
Is there anything I can do to the custom composite itself to cause any
parents to skip it when traversing?
Thanks in advance for any suggestions.
--Peter
Re: Excluding custom Composite from tab order [message #466672 is a reply to message #466599] Thu, 12 January 2006 19:56 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
Do not add any KeyListener to your custom control and it will not be in the
tab order.
"Peter Nehrer" <pnehrer@freeshell.org> wrote in message
news:dq3qub$rok$1@utils.eclipse.org...
> gets "eaten" by the custom composite -- can't tab out of it again (until I
> when traversing. I also know that I can do this by excluding the composite
> composite itself -- after the parent is constructed, remove all instances
> --Peter
Re: Excluding custom Composite from tab order [message #466673 is a reply to message #466672] Thu, 12 January 2006 20:10 Go to previous message
Veronika,
thanks for the tip -- indeed the composite was being adapted by
FormToolkit in such a way that a key listener was (unnecessarily)
installed on it. It now works as required.
--Peter
Previous Topic:multi-select in trees on linux
Next Topic:How to detect refresh event in Browser
Current Time: Fri May 25 01:41:06 GMT 2018
Powered by FUDForum. Page generated in 0.02111 seconds
