Home » Eclipse Projects » Standard Widget Toolkit (SWT) » create a plugin from source
create a plugin from source [message #466485] Tue, 10 January 2006 17:41 Go to next message
IchBin is currently offline IchBinFriend
Member
I would like to create a plugin project from the source found at a
project at sourceforge.net called 'Graysky Plugins for Eclipse'.
http://sourceforge.net/projects/graysky.
LogWatcher is the project I am interested in creating.
I have download their source but not sure how to create and import this
code for a Eclipse plugin. I have posted a problem with that project in
their forum. Not sure how active the project is because I see no
responses in their help or bug forums for few years.
So I want to fix the problem. Again not sure what type of plugin project
to create to import the code.
Any help would be appreciated.
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: create a plugin from source [message #466489 is a reply to message #466485] Tue, 10 January 2006 18:51 Go to previous messageGo to next message
Haris Peco is currently offline Haris PecoFriend
you can use binary structure for plugin and add source
or easier download cvs
Re: create a plugin from source [message #466500 is a reply to message #466485] Tue, 10 January 2006 18:41 Go to previous messageGo to next message
Ricky is currently offline RickyFriend
This thread may be useful:
Newsgroups: eclipse.platform.rcp
Subject: How to add code to a library plugin, and deploy that code
As the code is a eclipse plugin already maybe the project can be checked
out from there cvs.
Ricky
Re: create a plugin from source [message #466525 is a reply to message #466500] Tue, 10 January 2006 23:30 Go to previous message
Member
> From: Paul Keyser <rolarenfan@earthlink.net>
> out from there cvs.
> Ricky
Thanks guy's for your directions..
I was confused by all of the different types plugin projects when I
first tried to import the code. Did not know which one to use.
It maybe the tough way but maybe the best way to get up to snuff on
Eclipse plugins. That is, by jumping right into the middle of it.
Previous Topic:What's the difference, RGB vs Color
Next Topic:C-SWT project is opened / requirement wanted.
Current Time: Sat Jan 20 15:26:17 GMT 2018
Powered by FUDForum. Page generated in 0.01387 seconds
