Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Converting AWT Image to SWT Image on a Mac
Converting AWT Image to SWT Image on a Mac [message #466235] Thu, 05 January 2006 07:31 Go to next message
Mark McLaren is currently offline Mark McLarenFriend
Member
I'm trying to run Snippet156 on OS X 10.3.9 (Convert between SWT and AWT
images).
I get this error:
Exception in thread "main" java.lang.InternalError: Can't start the AWT
because Java was started on the first thread. Make sure
StartOnFirstThread is not specified in your application's Info.plist or on
the command line
(I am running with -Djava.awt.headless=true)
Anyone seen this?
Re: Converting AWT Image to SWT Image on a Mac [message #466238 is a reply to message #466235] Thu, 05 January 2006 10:06 Go to previous message
Yves Harms is currently offline Yves HarmsFriend
Member
Due to a bug in MacOSX -Djava.awt.headless=true has no effect at all
prior to OSX 10.4, you will have to upgrade to Tiger.
With Java 1.5 on MacOSX 10.4 or higher SWT is recognised and that system
property is set automaticly. (Java 1.4 on 10.4 still reqires you to set
the system property manually however)
Yves
> images).
> I get this error:
> on the command line
> Anyone seen this?
> Thanks
Previous Topic:SWT InputBox
Next Topic:Problem making a view scrollable
Current Time: Mon Apr 23 09:53:57 GMT 2018
Powered by FUDForum. Page generated in 0.01434 seconds
