Home » Eclipse Projects » Rich Client Platform (RCP) » exe file for pulg-in project
exe file for pulg-in project [message #464618] Tue, 13 March 2007 08:08 Go to next message
Originally posted by: vibhoodh_srikar.yahoo.co.in
Hi All,
I have three views added in single perspective. I want to test this
using Squish Testing tool.
Squish expects an executable file to be given to execute and records the
events for our UI.
I was successful in making the executable for an RCP application of type
template - RCP Application with View and tested well using Squish
But for an RCP application of type template - Pulg-in project with a
View, I am unable to create Executable file , b'coz we'r in confusion as
to which file to use as the Application in the Product Configuration
Wizard.. B'coz for plug-in project of type Pulg-in Project With a View ,
we don't have Application file...
Can anyone help me this.....Its pretty urgent..
Vibhoodh
Re: exe file for pulg-in project [message #464676 is a reply to message #464618] Tue, 13 March 2007 15:08 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
You will need to export a product that contains your plug-in.
Your can create a new Product Configuration file in your plug-in.
In the overview tab of the product configuration file, base it on plug-ins.
In the Configuration tab add your plug-in and click "Add Required Plug-ins".
you can then use this to export a standalone product that contains your plug-in
and an executable file.
-Andrew
Vibhoodh wrote:
> Hi All,
> this using Squish Testing tool.
> events for our UI.
> type template - RCP Application with View and tested well using Squish
> Vibhoodh
Re: exe file for pulg-in project [message #464710 is a reply to message #464676] Wed, 14 March 2007 04:10 Go to previous messageGo to next message
But in product config wizard , OverView tab what to give as the
appliaction,
because there is no application file for a Pulg-in Project with View type
Sujatha
Re: exe file for pulg-in project [message #464734 is a reply to message #464710] Wed, 14 March 2007 15:47 Go to previous message
Create a new product Id, and in the New Product Definition dialog, choose
org.eclipse.ui.ide.workbench for the application.
-Andrew
Vibhoodh wrote:
> appliaction,
> type ..
> Sujatha
Previous Topic:Problems with MessageConsole.clearConsole()
Next Topic:TreeViewer
Current Time: Sat Feb 24 18:42:56 GMT 2018
Powered by FUDForum. Page generated in 0.01989 seconds
