Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ICellEditorValidator problem
ICellEditorValidator problem [message #464203] Fri, 18 November 2005 16:48 Go to next message
martin is currently offline martinFriend
Member
Hi all,
I want to add input validation to a TableViewer. I do this by setting an
ICellEditorValidator as validator of a TextCellEditor. The method
isValid just checks if the entered String is empty:
public String isValid(Object value) {
if (((String)value).trim().length() == 0) {
return "a name is required";
return null;
isValid gets called correctly and returns the error message if an empty
String is entered into the TextCellEditor, but the TableViewer ignores
this and accepts the new value instead of rejecting it and showing the
error message.
Am I missing some kind of validation-enabling, or is validation not
implemented by TableViewer/TextCellEditor?
tia,
M
Re: ICellEditorValidator problem [message #464233 is a reply to message #464203] Fri, 18 November 2005 20:04 Go to previous message
Steve Northover is currently offline Steve NorthoverFriend
You need to ask this question on eclipse.platform. That's where JFace
issues are discussed.
"martin" <address.starts.after.hyphen-martin.umgeher@joanneum.at> wrote in
message news:dll0of$th7$1@news.eclipse.org...
> Hi all,
> return null;
> error message.
> tia,
> M
Previous Topic:DDE Conflict (Excel/Bloomberg)
Next Topic:Table behavior when pressing CTRL+UP/DOWN
Current Time: Thu Apr 19 21:36:27 GMT 2018
Powered by FUDForum. Page generated in 0.01238 seconds
