Home » Eclipse Projects » Rich Client Platform (RCP) » The chosen operation is not currently avialable.
The chosen operation is not currently avialable. [message #464194] Tue, 27 February 2007 09:11 Go to next message
Originally posted by: m.hybler.aegis.cz
I have declaratively set a ActionSet with one action.
This is a part of plugin.xml where ActionSet has been declared.
<extension
point="org.eclipse.ui.actionSets">
<actionSet
description="Pro trideni stromu"
id="cz.aegis.cms.viewer.trideni"
label="Trideni"
visible="true">
<menu
id="cz.aegis.cms.viewer.trideniMenu"
label="Třídění"
path="additions">
<separator name="slot1"/>
</menu>
<action
class="cz.aegis.cms.sorting.Search"
id="cz.aegis.cms.sorting.Search"
label="Třídit dle vlastností"
menubarPath="cz.aegis.cms.viewer.trideniMenu/slot1"
style="push"
tooltip="Slouzi k trideni stromu pro lepsi prehlednost"/>
</actionSet>
</extension>
But when I try to click on this menu item the following message followed.
"The chosen operation is not currently avialable."
In my log is this text.
!SESSION 2007-02-27 10:00:13.812
eclipse.buildId=unknown
java.version=1.6.0
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=cs_CZ
Framework arguments: -application cz.aegis.cms.run.application
Command-line arguments: -application cz.aegis.cms.run.application -data
C:\aegis\eclipse\work/../runtime-cmsviewer -dev
file:C:/aegis/eclipse/work/.metadata/.plugins/org.eclipse.pd e.core/CMS
viewer/dev.properties -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 4 4 2007-02-27 10:00:15.906
!MESSAGE Part already exists in page layout: org.eclipse.ui.editorss.
!ENTRY org.eclipse.ui 4 4 2007-02-27 10:00:17.187
!MESSAGE Could not create action delegate for id:
!ENTRY org.eclipse.equinox.registry 4 1 2007-02-27 10:00:17.187
!MESSAGE Plug-in "cz.aegis.cms.viewer" was unable to instantiate class
"cz.aegis.cms.sorting.Search".
!STACK 0
java.lang.InstantiationException: cz.aegis.cms.sorting.Search
at java.lang.Class.newInstance0(Class.java:340)
at java.lang.Class.newInstance(Class.java:308)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:157)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:234)
org.eclipse.ui.internal.PluginAction.createDelegate(PluginAc tion.java:120)
org.eclipse.ui.internal.PluginAction.selectionChanged(Plugin Action.java:278)
org.eclipse.ui.internal.WWinPluginAction.refreshSelection(WW inPluginAction.java:275)
org.eclipse.ui.internal.WWinPluginAction.<init>(WWinPluginAction.java:121)
org.eclipse.ui.internal.ActionDescriptor.createAction(Action Descriptor.java:259)
org.eclipse.ui.internal.ActionDescriptor.<init>(ActionDescriptor.java:170)
org.eclipse.ui.internal.PluginActionSetBuilder.createActionD escriptor(PluginActionSetBuilder.java:132)
org.eclipse.ui.internal.PluginActionBuilder.readElement(Plug inActionBuilder.java:158)
org.eclipse.ui.internal.registry.RegistryReader.readElements (RegistryReader.java:138)
org.eclipse.ui.internal.registry.RegistryReader.readElementC hildren(RegistryReader.java:127)
org.eclipse.ui.internal.PluginActionBuilder.readElement(Plug inActionBuilder.java:141)
org.eclipse.ui.internal.PluginActionSetBuilder.readActionExt ensions(PluginActionSetBuilder.java:259)
org.eclipse.ui.internal.PluginActionSetBuilder.processAction Sets(PluginActionSetBuilder.java:221)
org.eclipse.ui.internal.ActionPresentation.setActionSets(Act ionPresentation.java:187)
org.eclipse.ui.internal.WorkbenchWindow.updateActionSets(Wor kbenchWindow.java:2826)
at org.eclipse.ui.internal.WorkbenchWindow$6.run(WorkbenchWindo w.java:2636)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchWindow.setActivePage(Workbe nchWindow.java:2597)
org.eclipse.ui.internal.WorkbenchWindow.busyOpenPage(Workben chWindow.java:658)
org.eclipse.ui.internal.Workbench.busyOpenWorkbenchWindow(Wo rkbench.java:795)
org.eclipse.ui.internal.Workbench.doOpenFirstTimeWindow(Work bench.java:1437)
org.eclipse.ui.internal.Workbench.openFirstTimeWindow(Workbe nch.java:1388)
org.eclipse.ui.internal.WorkbenchConfigurer.openFirstTimeWin dow(WorkbenchConfigurer.java:190)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:708)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at cz.aegis.cms.run.Application.run(Application.java:18)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.ui 4 4 2007-02-27 10:00:20.453
!MESSAGE Context menu missing standard group
'org.eclipse.ui.IWorkbenchActionConstants.MB_ADDITIONS'. (menu ids =
[cz.aegis.cms.viewer.CMSview]) part id = cz.aegis.cms.viewer.CMSview)
!ENTRY org.eclipse.ui 4 4 2007-02-27 10:00:34.015
Someone can help me?
Thanking Michal
Re: The chosen operation is not currently avialable. [message #464228 is a reply to message #464194] Wed, 28 February 2007 06:36 Go to previous message
Karsten Panier is currently offline Karsten PanierFriend
Member
> <extension
> <actionSet
> label="Trideni"
> visible="true">
> <menu
> label="Třídění"
> path="additions">
> </menu>
> <action
> style="push"
> </actionSet>
> </extension>
> java.version=1.6.0
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> Thanking Michal
Has the class cz.aegis.cms.sorting.Search a default constructur? The
Platfrom needs that to create an instance.
Karsten
Previous Topic:RCP + Features + Resource
Next Topic:Calling helpsystem out of dialog
Current Time: Tue Feb 20 23:49:56 GMT 2018
Powered by FUDForum. Page generated in 0.01797 seconds
