Home » Eclipse Projects » Standard Widget Toolkit (SWT) » How to use ColorCellEditor
How to use ColorCellEditor [message #463217] Mon, 31 October 2005 14:14 Go to next message
Originally posted by: sunxufeng962.gmail.com
I use TableView to edit data.
the table has two columns, one column is TextCellEditor ,anther column is
ColorCellEditor.TextCellEditor works well, but ColorCellEditor does't
change the data.
can any body help me. or give me some example.
Re: How to use ColorCellEditor [message #463224 is a reply to message #463217] Tue, 01 November 2005 09:04 Go to previous message
I found a example use ColorCellEditor,it's same to my code.
http://www.java2s.com/ExampleCode/SWT-JFace-Eclipse/Demonstr atesCellEditors.htm
I paste the code in eclipse 3.2M1(i current use),it's does not work.
but when i paste it to eclipse 3.0.2,it's work ok.
so i think it's a swt bug.
Previous Topic:KTable or SWT Table or ...
Next Topic:Possible to get the HTML text/source from the Browser widget?
Current Time: Mon Apr 23 08:00:25 GMT 2018
Powered by FUDForum. Page generated in 0.01567 seconds
