Home » Eclipse Projects » Standard Widget Toolkit (SWT) » GridData exclude problem
GridData exclude problem [message #460413] Thu, 25 August 2005 13:13 Go to next message
hortiz Mising name is currently offline hortiz Mising nameFriend
Member
I want to switch between two composites when clicking on a button. I use
the GridData.exclude attribute to do so. The problem is that the switch
process only works once. The snippet below illustrates this.
Thanks for your help,
Helene
package test;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
public class SwitchableCompositeWithExclude {
private static Composite bigOne;
private static Composite smallOne;
private static Composite rightComposite;
private static Button button;
Display display = Display.getDefault ();
final Shell shell = new Shell (display);
shell.setLayout(new GridLayout(2, false));
Composite leftComposite = new Composite(shell, SWT.BORDER);
leftComposite.setLayoutData(new GridData());
leftComposite.setLayout(new GridLayout());
button = new Button(leftComposite, SWT.TOGGLE);
button.setText("Switch");
button.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent arg0) {
if (button.getSelection()) {
switchComposite(1);
} else {
switchComposite(0);
button.setLayoutData(new GridData());
rightComposite = new Composite(shell, SWT.BORDER);
rightComposite.setLayoutData(new GridData());
rightComposite.setLayout(new GridLayout());
bigOne = new Composite(rightComposite, SWT.BORDER);
bigOne.setLayoutData(new GridData());
bigOne.setLayout(new GridLayout());
Label label;
for (int i = 0; i < 5; i++) {
label = new Label(bigOne, SWT.NONE);
label.setText("Label number " + i);
label.setLayoutData(new GridData());
smallOne = new Composite(rightComposite, SWT.BORDER);
smallOne.setLayoutData(new GridData());
smallOne.setLayout(new GridLayout());
label = new Label(smallOne, SWT.NONE);
label.setText("SMALL ONE !");
switchComposite(0);
shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose ();
private static void switchComposite(int value) {
GridData smallGridData = (GridData) smallOne.getLayoutData();
GridData bigGridData = (GridData) bigOne.getLayoutData();
if (value == 0) {
System.out.println("Hiding BIG Showing SMALL");
bigGridData.exclude = true;
smallGridData.exclude = false;
} else {
System.out.println("Hiding SMALL Showing BIG");
smallGridData.exclude = true;
bigGridData.exclude = false;
rightComposite.layout();
rightComposite.getParent().layout();
Re: GridData exclude problem [message #460447 is a reply to message #460413] Fri, 26 August 2005 16:27 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
The problem is that exclude just excludes the widget from layout, it doesn't
hide it. Here is the relevent part of your code fixed:
if (value == 0) {
bigOne.setVisible (!(bigGridData.exclude = true));
smallOne.setVisible (!(smallGridData.exclude = false));
} else {
smallOne.setVisible (!(smallGridData.exclude = true));
bigOne.setVisible (!(bigGridData.exclude = false));
"hortiz" <hortiz@xxxxxx.xxx> wrote in message
news:50eb50ab0545a8ece877d51e872287ab$1@www.eclipse.org...
> Helene
> package test;
> import org.eclipse.swt.widgets.Display;
> public static void main(String[] args) {
> switchComposite(1);
> } else {
> switchComposite(0);
> Label label;
> switchComposite(0);
> shell.open();
> display.sleep();
> display.dispose ();
> if (value == 0) {
> } else {
Re: GridData exclude problem [message #460463 is a reply to message #460447] Mon, 29 August 2005 07:32 Go to previous message
Member
Thanks a lot Steve, it works fine
Helene
Previous Topic:Display problem with TableViewer
Next Topic:Simple question: image on button gives red square
Current Time: Fri May 25 09:00:47 GMT 2018
Powered by FUDForum. Page generated in 0.02249 seconds
