Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Vertical alignment in label; Preferred size of label
Vertical alignment in label; Preferred size of label [message #458248] Mon, 11 July 2005 23:16 Go to next message
Arun is currently offline ArunFriend
Member
I am trying to get text aligned vertically on a label.
But not able to find any option for this.
I also want to set an aolsute height for the label.
Currently the label height is the same as that of the text within it.
have tried invoking label.setpreferredHeight(), but does not seem to work.
Any pointers are appreciated.
Thanks in advance
Arun
Re: Vertical alignment in label; Preferred size of label [message #458268 is a reply to message #458248] Tue, 12 July 2005 14:15 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
Believe it or not, aligning a label vertically is not supported on all
operating systems. If you want to do this in SWT, align the label in it's
parent using a layout or by calling setBounds() on the label when the parent
is resized.
If you want to set the bounds of any control, including labels, use
setBounds(). Note that when a control is a child of a composite that
includes a layout, the layout will almost certainly override and setBounds()
call that you make as part of the layout algorithm.
Hope this helps.
"Arun" <jacob.arun@gmail.com> wrote in message
news:2cf406068266d2b959efe1b46b0bf5df$1@www.eclipse.org...
> Hi
> Thanks in advance
> Arun
Re: Vertical alignment in label; Preferred size of label [message #458273 is a reply to message #458268] Tue, 12 July 2005 15:01 Go to previous messageGo to next message
Originally posted by: jacob.arun.gmail.com
By vertical alignment, I meant th alignment of text inside the label,
instead of alignment of the label within its parent.
As attched in this (label_buttons.jpg), I have 4 labels, which I use as
buttons as SWT button foreground and background cannot be customised. The
problem is that the text in one 1 of the 4 labels wraps. Due tp the layout
the height of all 4 lbels also double. But the text in the labels with
non-wrapping text does not align centrally vertically.
Thanks in advance
Arun
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:db0j9g$d0d$1@news.eclipse.org...
parent
> is resized.
setBounds()
> Hope this helps.
> > Hi
work.
> > Thanks in advance
> > Arun
Re: Vertical alignment in label; Preferred size of label [message #458520 is a reply to message #458273] Thu, 14 July 2005 13:41 Go to previous message
You will need to provide code.
"Arun Jacob" <jacob.arun@gmail.com> wrote in message
news:db0m1e$h6b$1@news.eclipse.org...
> Hi
> Thanks in advance
> Arun
it's
> parent
> > is resized.
> setBounds()
> > Hope this helps.
> > > Hi
> work.
> > > Thanks in advance
> > > Arun
Previous Topic:Opaque Canvas
Next Topic:Dynamic Buttons in Wizard Pages
Current Time: Sun May 27 23:50:36 GMT 2018
Powered by FUDForum. Page generated in 0.02139 seconds
