Home » Eclipse Projects » Standard Widget Toolkit (SWT) » first table column no alignment
first table column no alignment [message #457161] Mon, 20 June 2005 08:55 Go to next message
Eclipse User
Originally posted by: elbucho.gmx.de
there seems to be a strange problem.
The following code sets center alignment to all columns except(!) the first
one. I can't even imagine why this happens.
Aligning it to the right doesn't work either. The first column is always
left aligned. Can you change this behaviour ?
Roland
Display display = new Display();
Shell shell = new Shell(display);
GridLayout layout = new GridLayout();
layout.numColumns = 1;
shell.setLayout(layout);
Table table = new Table(shell, SWT.SINGLE | SWT.BORDER);
table.setLinesVisible(true);
table.setHeaderVisible(true);
TableColumn[] columns = new TableColumn[10];
for (int i = 0; i < 10; i++)
columns[i] = new TableColumn(table, SWT.CENTER);
columns[i].setText("I"+i);
columns[i].setWidth(50);
columns[i].setResizable(true);
shell.open();
while ( ! shell.isDisposed())
if ( ! display.readAndDispatch())
display.sleep();
display.dispose();
Re: first table column no alignment [message #457167 is a reply to message #457161] Mon, 20 June 2005 09:51 Go to previous messageGo to next message
Yves Harms is currently offline Yves Harms
Member
You can't. This is a limitation that swt inherited from Windows.
You can however use a workaround. Just use a "hidden" first column with
setWidth(0), setResizable(false).
Yves
Roland Jürgens wrote:
> Hello,
> Thanks
> Roland
> shell.open();
> display.sleep();
> display.dispose();
Re: first table column no alignment [message #457168 is a reply to message #457161] Mon, 20 June 2005 09:54 Go to previous message
Grant Gayed is currently offline Grant Gayed
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=39568
"Roland J
Previous Topic:Can't use MessageDialog(JFace) in SWT application
Next Topic:Resize a Dialog Does not work??
Current Time: Tue Oct 08 07:57:51 EDT 2013
Powered by FUDForum. Page generated in 0.01942 seconds
