Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Radio button in a table
Radio button in a table [message #452305] Thu, 17 March 2005 10:19 Go to next message
vipashwi is currently offline vipashwiFriend
Iam creating table with with Tableviewer and Cell editors.
the first column in my table is a check box and so i use the check box
cell editor to get the functionality.
but my problems lies t=in coloumn two where i want a Radio button, i ahev
checked evrywhere for a radiobutton cell editor, but invain.
any help how i cud get this.
The table will be populated from the db on button click.. so initially no
data in the table.
Re: Radio button in a table [message #637129 is a reply to message #452305] Thu, 04 November 2010 10:05 Go to previous messageGo to next message
No real name is currently offline No real nameFriend
I have the same problem - I assume, since there has been no reply, that there is no other option than to use the standard swt radio button.
regards,
Michael
Re: Radio button in a table [message #637146 is a reply to message #637129] Thu, 04 November 2010 11:38 Go to previous message
Daniel Krügler is currently offline Daniel KrüglerFriend
A generally recommended procedure to embed controls (especially
Buttons) in a SWT table or tree is to use a "snap-shot" technique,
as described in
http://tom-eclipse-dev.blogspot.com/2007/01/tableviewers-and -nativelooking.html
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet061FakedNativeCellEditor.java?view=markup
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:[SOLVED] Setting images of different widths to TableItem
Next Topic:changing background color on a table viewer depending on other view selection
Current Time: Tue Feb 20 02:17:28 GMT 2018
Powered by FUDForum. Page generated in 0.01564 seconds
