Home » Eclipse Projects » Rich Client Platform (RCP) » Problem in PreferenceDialog
Problem in PreferenceDialog [message #449618] Tue, 16 May 2006 22:08 Go to next message
Originally posted by: aschneid.onlinehome.de
I have a problem when calling the following from an RCP application:
PreferenceNode one = new PreferenceNode( "one", new FieldEditorPageOne());
PreferenceNode two = new PreferenceNode("two", "Logging", null,
FieldEditorPageTwo.class.getName());
The first one works, but when selecting the second page, I get the
following in the log:
!ENTRY org.eclipse.jface 4 2 2006-05-16 23:57:14.438
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
org.eclipse.jface.preference.PreferenceNode.createPage(Prefe renceNode.java:161)
org.eclipse.jface.preference.PreferenceDialog.createPage(Pre ferenceDialog.java:1241)
What can be wrong?
Achim
Re: Problem in PreferenceDialog [message #449633 is a reply to message #449618] Wed, 17 May 2006 11:53 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
asc wrote:
> Hi
> !STACK 0
> java.lang.NullPointerException
> at
If I had to guess, the PreferenceNode is returning null from the call to
createObject(classname) ... set a breakpoint in
PreferenceNode#createPage() and you can find out.
Later,
PW
Re: Problem in PreferenceDialog [message #449692 is a reply to message #449633] Wed, 17 May 2006 20:52 Go to previous messageGo to next message
> Later,
> PW
Paul,
yes, yes you are right - setting the breakpoint shows that the
createObject is failing because the classname somehow cannot be
resolved- but the question is why?
Achim
Re: Problem in PreferenceDialog [message #449728 is a reply to message #449692] Thu, 18 May 2006 11:54 Go to previous messageGo to next message
asc wrote:
> Paul,
your plugin depends on the jface plugin ... but that means that jface
can't load a class from your plugin. That's why it fails.
i.e. you can use that constructor in a java app using JFace+SWT, but not
in a plugin, in RCP or Eclipse.
Later,
PW
Re: Problem in PreferenceDialog [message #449831 is a reply to message #449728] Sat, 20 May 2006 22:10 Go to previous messageGo to next message
Paul Webster wrote:
> asc wrote:
>> Paul,
> Later,
> PW
Paul, (sorry, where on business trip)
do you mean its not possible at all? Or is there any way?
Achim
Re: Problem in PreferenceDialog [message #449857 is a reply to message #449831] Tue, 23 May 2006 13:38 Go to previous message
I mean AFAIK, you cannot use that constructor while in a plugin. The
problem is the jface plugin cannot load a class from a dependent plugin.
If you were just using the jface jar as part of a java app
(non-eclipse), it would work.
Later,
PW
Previous Topic:system32 and DLLs
Next Topic:Tasks and Bookmarks
Current Time: Sat Jan 20 19:15:47 GMT 2018
Powered by FUDForum. Page generated in 0.01500 seconds
