Home » Language IDEs » AJDT » How to access 'this'
How to access 'this' [message #45111] Mon, 20 December 2004 19:22 Go to next message
Originally posted by: sekar.gopinathan.fhlbny.com
I am trying to create an aspect for auditing within our application.
Usually our application has a service object and the service object passes
itself to the auditing service object. So in effect our service object
code would look like
serviceA{
execute(...){
//Do the task
auditService.execute(this)
Now I want to put the 'auditService.execute(this) into an aspect.
Inside my aspect can I write something like?
public aspect DoAudit {
pointcut doAudit():execution(* AbstractBusinessService.execute);
after():doAudit(){
auditStep.execute(thisJoinPoint.getThis());
When I was reading the API spec, I read that for perfomance reasons
getThis should not be used. Is my understanding correct? Or is there
any other way to do the same task. I am not sure if I missed something
from the manual. I appreciate if someone can point me in the right
direction.
Re: How to access 'this' [message #45145 is a reply to message #45111] Mon, 20 December 2004 22:50 Go to previous messageGo to next message
> after():doAudit(){
> direction.
Indeed. correct it to:
pointcut doAudit(serviceA s):
execution(* AbstractBusinessService.execute(serviceA)) && this(s);
after(serviceA sa):doAudit(sa){
auditStep.execute(sa);
Then in the pointcut, "this" is bound to the formal s. In the piece of
advice, "sa" is bound to that very instance.
Eric
Eric Bodden, ICQ: 12656220, http://www.bodden.de, PGP: BB465582
Active Desktop Wallpaper Changer: That's what it is...
http://bodden.de/projects/wpchanger/
Re: How to access 'this' [message #45176 is a reply to message #45145] Tue, 21 December 2004 00:28 Go to previous message
Eric,
It worked.
AOP requries one to think very differently. I am getting there.
Thanks you.
>> after():doAudit(){
>> direction.
> Eric
Re: How to access 'this' [message #585360 is a reply to message #45111] Mon, 20 December 2004 22:50 Go to previous message
Eric Bodden is currently offline Eric BoddenFriend
Member
> after():doAudit(){
> direction.
Eric
Re: How to access 'this' [message #585378 is a reply to message #45145] Tue, 21 December 2004 00:28 Go to previous message
Eric,
It worked.
Thanks you.
>> after():doAudit(){
>> direction.
> Eric
Previous Topic:How to access 'this'
Next Topic:aspect in J2ee
Current Time: Thu May 24 06:38:16 GMT 2018
Powered by FUDForum. Page generated in 0.02163 seconds
