Home » Eclipse Projects » Standard Widget Toolkit (SWT) » WizardSelectionPage example?
WizardSelectionPage example? [message #447641] Wed, 15 December 2004 19:06 Go to next message
Horst Dehmer is currently offline Horst DehmerFriend
I'm trying to set up a wizard which should
display a wizard selection page up front
to select the actual wizard/wizard pages to
use in following steps.
After selecting a wizard and proceeding to
the next page (first page of the selected
wizard) the dialog's content area goes blank.
No exception and the dialogs title is updated
correctly to the selected wizards title.
Going back to the selection page results in
a blank content area, too.
Any ideas?
Is there a simple example around which uses
- org.eclipse.jface.wizard.WizardSelectionPage
- org.eclipse.jface.wizard.IWizardNode
Horst
Re: WizardSelectionPage example? [message #447651 is a reply to message #447641] Wed, 15 December 2004 22:52 Go to previous message
Horst Dehmer wrote:
> Any ideas?
> Thanks
> Horst
Just got to put a Composite between parent
and my widgets:
public void createControl(Composite parent) {
Composite container = new Composite(parent, SWT.NONE);
setControl(container);
// add more widgets to container (AND NOT to parent!)
Previous Topic:forcing repaint on a control
Next Topic:What is that drop-down Coolbar button widget?
Current Time: Thu Jan 18 12:11:06 GMT 2018
Powered by FUDForum. Page generated in 0.01847 seconds
