Home » Eclipse Projects » Rich Client Platform (RCP) » How to notify other view?
How to notify other view? [message #445962] Sat, 11 March 2006 17:23 Go to next message
Lukas Zapletal is currently offline Lukas ZapletalFriend
Member
I have a view with a Tree and other view with a Property Sheet. When a
user double click on an object in the tree, I want to load the object
properties in the Sheet.
How to get a reference to the Sheet view?
Should I notify the Sheet view directly (with a method call), using my
own listener mechanism or should I use an action?
Thank you for help
Lukas Zapletal
Re: How to notify other view? [message #445963 is a reply to message #445962] Sat, 11 March 2006 17:33 Go to previous messageGo to next message
James Leotta is currently offline James LeottaFriend
Hello Lukas,
imlement ISelectionListener in the view with the property and add
getSite().setSelectionProvider(treeViewer);
to your createpartcontrol of your view with the tree.
Lukas Zapletal wrote:
> Hello,
> Thank you for help
Re: How to notify other view? [message #445966 is a reply to message #445963] Sat, 11 March 2006 18:09 Go to previous messageGo to next message
Member
Dne Sat, 11 Mar 2006 12:33:51 -0500
James Leotta <jleotta@bascom.com> napsal(a):
But I do not have a reference to treeViewer in the createPartControl
method. Is there any standard way to get it?
Lukas Zapletal
Re: How to notify other view? [message #445967 is a reply to message #445966] Sat, 11 March 2006 18:25 Go to previous messageGo to next message
Where ever your tree is defined.
Re: How to notify other view? [message #445970 is a reply to message #445967] Sat, 11 March 2006 20:57 Go to previous messageGo to next message
Member
Dne Sat, 11 Mar 2006 13:25:53 -0500
Oh I wrote treeView? I thought you meant
getSite().setSelectionProvider(sheetViewer);
and I have no reference to the sheetViewer.
ps - does it mean I have to create a class (say PropertyView) extending
the ViewPart?
Lukas Zapletal
Re: How to notify other view? [message #445972 is a reply to message #445970] Sat, 11 March 2006 21:30 Go to previous messageGo to next message
I thought you already did have a view with the Tree in it?
Creating the view extending viewpart is the only way I know.
> the ViewPart?
> Best regards,
> Lukas Zapletal
Re: How to notify other view? [message #445973 is a reply to message #445962] Sat, 11 March 2006 21:42 Go to previous message
Cristi Angheluta is currently offline Cristi AnghelutaFriend
Take a look at this tutorial
"Make your Eclipse applications richer with view linking":
http://www.ibm.com/developerworks/opensource/library/os-ecll ink/
it might help you.
Cristinel Angheluta
On Sat, 11 Mar 2006 19:23:44 +0200, Lukas Zapletal =
<lukas.zapletal@linuxexpres.cz> wrote:
> Hello,
> I have a view with a Tree and other view with a Property Sheet. When a=
> Should I notify the Sheet view directly (with a method call), using my=
> Thank you for help
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Previous Topic:3.1 jar bundle classloading vs. 3.0 folder bundles
Next Topic:test
Current Time: Wed Jan 17 20:24:43 GMT 2018
Powered by FUDForum. Page generated in 0.02120 seconds
