Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Single column table possible?
Re: Single column table possible? [message #443530 is a reply to message #443494] |
Mon, 27 September 2004 13:18 |
Grant Gayed Messages: 2150 Registered: July 2009 |
Hi Craig,
I think the following does what you want. It's based on
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet88.java?rev=HEAD&a mp;content-type=text/vnd.viewcvs-markup .
Display display = new Display();
Shell shell = new Shell(display);
final Table table = new Table(shell, SWT.FULL_SELECTION |
SWT.HIDE_SELECTION);
table.setLinesVisible(true);
TableColumn column = new TableColumn(table, SWT.NONE);
for (int i = 0; i < 10; i++) {
TableItem item = new TableItem(table, SWT.NONE);
item.setText("item " + i);
final TableEditor editor = new TableEditor(table);
editor.horizontalAlignment = SWT.LEFT;
editor.grabHorizontal = true;
editor.minimumWidth = 50;
final int EDITABLECOLUMN = 0;
table.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
Control oldEditor = editor.getEditor();
if (oldEditor != null) oldEditor.dispose();
TableItem item = (TableItem)e.item;
if (item == null) return;
Text newEditor = new Text(table, SWT.NONE);
newEditor.setText(item.getText(EDITABLECOLUMN));
newEditor.addModifyListener(new ModifyListener() {
public void modifyText(ModifyEvent e) {
Text text = (Text)editor.getEditor();
editor.getItem().setText(EDITABLECOLUMN,
text.getText());
newEditor.selectAll();
newEditor.setFocus();
editor.setEditor(newEditor, item, EDITABLECOLUMN);
shell.setSize(300, 300);
table.setBounds(10,10,200,200);
column.setWidth(table.getSize().x); // <--
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
Grant
"Craig Setera" <seterajunk@charter.net> wrote in message
news:cj3p1d$44v$1@eclipse.org...
> I would like to take advantage of the Table CellEditor support and such,
> but what I have essentially is a list of values. It seems that no
> matter what I do, I can't seem to make a single column table. No matter
> what, I always seem to end up with at least two columns in the table.
> This is all on the Window platform (version 3.0.1 of Eclipse). Is this
> some sort of platform requirement? Is there anything else I can do to
> get CellEditor-like functionality? I would even be ok with a two column
> table in which the first column takes 100% of the width, but that
> doesn't seem to be possible even.
> Thanks for any help,
> Craig
Re: Single column table possible? [message #443634 is a reply to message #443530] |
Tue, 28 September 2004 21:51 |
Craig Setera Messages: 54 Registered: July 2009 |
Member |
I was able to apply the concept to my code and it works perfectly. Thanks.
Grant Gayed wrote:
> Hi Craig,
> public static void main(String[] args) {
> text.getText());
> shell.open();
> display.dispose();
Re: Single column table possible? [message #443753 is a reply to message #443706] |
Wed, 29 September 2004 22:29 |
Paul Singleton Messages: 37 Registered: July 2009 |
Member |
>>and
>>are apparently redundant
> The alignment makes the text field line up with the left side of the table
> cell. The minimumWidth means that even if the column is rezzied to be less
> than 50 pixels wide (or part of teh column is offscreen and can only be
> reached by scrolling) then the text editor will be a minimum of 50 pixels
> wide. I don't understand what is redundant about that.
I was experimenting with different values for those two, and
nothing made any difference, even commenting them out.
I think I've figured it out: (at least for win32) you only
get an editor wider than the column if there is extra table
width to the right of the column. Craig wants a virtual
editable List, where the table appears to have exactly one
column, so this will never happen, and setting minimumWidth
is pointless. Without this, grabHorizontal = true fits the
editor to the column, and setting horizontalAlignment is
also pointless.
If you leave these fields alone and add
table.addControlListener(new ControlAdapter() {
public void controlResized(ControlEvent e) {
column.setWidth(table.getClientArea().width);
the gizmo is resizable in x and y, and looks like an editable
list whatever:
final Shell shell = new Shell(display);
shell.setLayout( new FillLayout());
final Table table = new Table(shell, SWT.FULL_SELECTION | SWT.HIDE_SELECTION);
final TableColumn column = new TableColumn(table, SWT.NONE);
TableItem item = (TableItem) e.item;
if (item == null)
return;
Text text = (Text) editor.getEditor();
editor.getItem().setText(EDITABLECOLUMN, text.getText());
shell.open();
display.sleep();
display.dispose();
Paul Singleton
Re: Single column table possible? [message #443762 is a reply to message #443753] |
Thu, 30 September 2004 12:56 |
Member |
Paul hit on exactly the implementation I came up with. The "concept"
that I pulled from Grant's example was setting the width of the column
directly rather than using TableLayout. It seemed that even if I told
the TableLayout to use all of the space, it never really did. I hadn't
realized that I wasn't seeing an extra column, but I was seeing the
extra space the single column wasn't filling.
What is the difference between getClientArea() and getSize()? I used
getSize() in my case and it seemed to work correctly.
> also pointless.
> list whatever:
> if (item == null)
> return;
> text.getText());
> shell.open();
> display.sleep();
> display.dispose();
> Paul Singleton
Re: Single column table possible? [message #443788 is a reply to message #443762] |
Thu, 30 September 2004 15:21 |
Veronika Irvine Messages: 1272 Registered: July 2009 |
Calling getClientArea does not include scrollbars or borders. Calling
getSize gives the outside size of the table.
"Craig Setera" <csetera@spss.com> wrote in message
news:cjgvgc$jsl$1@eclipse.org...
> Paul hit on exactly the implementation I came up with. The "concept" that
> I pulled from Grant's example was setting the width of the column directly
> rather than using TableLayout. It seemed that even if I told the
> realized that I wasn't seeing an extra column, but I was seeing the extra
>> also pointless.
>> list whatever:
>> if (item == null)
>> return;
>> text.getText());
>> shell.open();
>> display.sleep();
>> display.dispose();
>> Paul Singleton
Current Time: Wed Apr 24 16:53:17 GMT 2024
Powered by FUDForum. Page generated in 0.03822 seconds
