| How to connect from an RCP Client via RMI to an EJB (over Http) [message #443166] |
Tue, 24 January 2006 07:47  |
Originally posted by: rene.huguet.besonet.ch
Hi there
We like to use rcp as client platform an the business processes on a JBoss AS (client and server separated).
We have the problem to connect from the plug-in via HttpNamingContextFactory (RMI over Http)
to the EJB on the JBoss AS.
When connecting with a JavaClient (not plug-in) the connection to the EJB works fine.
When connecting from a RCP Plugin we get the exception: (thrown in ObjectInputStream readObject())
Caused by: java.lang.ClassNotFoundException: com.prodega.ejbtest.interfaces.BenutzerManagerHome (no security manager: RMI class loader disabled)
at sun.rmi.server.LoaderHandler.loadProxyClass(LoaderHandler.ja va:531)
at java.rmi.server.RMIClassLoader$2.loadProxyClass(RMIClassLoad er.java:628)
at java.rmi.server.RMIClassLoader.loadProxyClass(RMIClassLoader .java:294)
at sun.rmi.server.MarshalInputStream.resolveProxyClass(MarshalI nputStream.java:238)
at java.io.ObjectInputStream.readProxyDesc(ObjectInputStream.ja va:1494)
at java.io.ObjectInputStream.readClassDesc(ObjectInputStream.ja va:1457)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStre am.java:1693)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java :1299)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java: 339)
at java.rmi.MarshalledObject.get(MarshalledObject.java:135)
at org.jnp.interfaces.MarshalledValuePair.get(MarshalledValuePa ir.java:57)
at org.jnp.interfaces.NamingContext.lookup(NamingContext.java:6 37)
... 33 more
<b>The jndi.properties:</b>
java.naming.factory.initial=org.jboss.naming.HttpNamingConte xtFactory
java.naming.provider.url=http://localhost:8080/invoker/JNDIFactory
java.naming.security.authentication=none (tested with and without this statement)
<b>The Java Code</b> (Exception in statement: <b>Object ref = context.lookup("ejb/BenutzerManager");</b> ):
Context context = new InitialContext();
context.getEnvironment();
BenutzerManagerHome home = (BenutzerManagerHome) PortableRemoteObject.narrow(ref, BenutzerManagerHome.class);
BenutzerManager bean = home.create();
<b>JBoss Security Policy</b> (server.policy file on JBoss AS): //
grant {
// Allow everything for now
permission java.security.AllPermission;
As mentioned above the EJB is deployed on the JBoss AS and works fine when calling from a JavaClient (with same Java Code).
What do i need more ????
Thanks in advance
René
| Re: How to connect from an RCP Client via RMI to an EJB (over Http) [message #443196 is a reply to message #443166] |
Tue, 24 January 2006 09:58   |
Hi Stefan
Thanks for your help, but after setting the securityManager i have still problems.
Here is what i have done:
1. JavaCode
System.setSecurityManager( new RMISecurityManager() );
2. VM Arguments in the richclient.product
-Djava.security.policy=rmi.policy
I'm not sure if the system reads the policy file.
3. rmi.policy file with
grant
Now i get a access denied exception by the statement
Context ctx = new InitialContext();
Exception:
java.security.PrivilegedActionException: javax.naming.NoInitialContextException:
Cannot instantiate class: org.jboss.naming.HttpNamingContextFactory
[Root exception is java.security.AccessControlException: access denied (java.lang.RuntimePermission getClassLoader)]
What is wrong or what is missing ??
Thanks for Your help
René
| Re: How to connect from an RCP Client via RMI to an EJB (over Http) [message #443197 is a reply to message #443192] |
Tue, 24 January 2006 10:02   |
Hi Stefan
1. JavaCode
grant
Exception:
René
| Re: How to connect from an RCP Client via RMI to an EJB (over Http) [message #443297 is a reply to message #443197] |
Thu, 26 January 2006 10:52   |
Hi Stefan, hi Alex
I still have problems to connect with a RCP Client via RMI to a Application server.
After reading:
http://www.genady.net/forum/viewtopic.php?t=205
i decided to create my own Security Manager with all permissions.
<b>My SecurityManager</b> that allows everything (is it correct ??):
package com.prodega.ejbtest.security;
import java.security.Permission;
public class MySecurityManager extends SecurityManager {
public MySecurityManager() {
public void checkPermission() {
public void checkPermission(Permission perm) {
public void checkPermission(Permission perm, Object context) {
<b>My JavaCode to connect from the RCP Client:</b>
ctx.getEnvironment();
// Save actuel SecurityManager. The result secMan = null. Is this normal ??
SecurityManager secMan = System.getSecurityManager();
// Set MySecurityManager
System.setSecurityManager(new MySecurityManager());
Object ref = ctx.lookup("ejb/BenutzerManager");
<b>The Result:</b>
The ctx.lookup returns a Proxy with my ejb/BenutzerManager Object
but in PortableRemoteObject.narrow(ref, BenutzerManagerHome.class);
i get a ClassCastException.
<b>The Reason:</b>
if (narrowTo.isAssignableFrom(narrowFrom.getClass())); returns <b>false</b> (in PortableRemoteObject.narrow(...))
and
org.omg.CORBA.Object narrowObj = (org.omg.CORBA.Object) ref; throws a ClassCastException
When i start the same from a JavaClient (main method) all works fine
if (narrowTo.isAssignableFrom(narrowFrom.getClass())) returns <b>true</b>
and i get my BenutzerManagerHome object.
<b>Exception:</b>
java.lang.ClassCastException
at com.sun.corba.se.impl.javax.rmi.PortableRemoteObject.narrow( PortableRemoteObject.java:229)
at javax.rmi.PortableRemoteObject.narrow(PortableRemoteObject.j ava:137)
at com.prodega.ejbtest.EjbtestPlugin.start(EjbtestPlugin.java:8 7)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:994)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:988)
ClassCastException in: PortableRemoteObject.narrow(ref, BenutzerManagerHome.class);
While does it work with a JavaClient and not with a RCP Client ??
Have You experiene to connect from a RCP Client (Plug-in) via RMI to a JBoss AS ??
Do You have en example which works with a RCP Client (Plug-in) ??
Best reagrds and thanks in advance for Your help
Rene
| Re: How to connect from an RCP Client via RMI to an EJB (over Http) [message #443338 is a reply to message #443302] |
Fri, 27 January 2006 05:47   |
Hi Alex
Thanks for Your help but
i still have the problem with the connection via RMI.
The JavaApplication (is better than JavaClient) is also called from inside Eclipse in debug mode.
The Program is in the same package as the RCP Client (Plug-in).
I recompiled the programs and deployed them on the server (version on Server and Client are the same).
Corba should not been involved.
I removed the statement which called a Corba method
(PortableRemoteObject.narrow(ref, BenutzerManagerHome.class);
and replaced it by:
BenutzerManagerHome home = (BenutzerManagerHome) ref; // (ref=the Proxy)
But, as expected, the result is the same.
With the JavaApplication it works fine, with the Plug-in i get the ClassCastException.
I compared the Proxys which i receive from the Server for the JavaApplication and for the RCP Client. For me they look the same.
Here an extract of the Proxy from the JavaApplication (which works):
ref= $Proxy1 (id=38 )
loaderToCache= WeakHashMap<K,V> (id=50)
m0= Method (id=54)
m1= Method (id=60)
m2= Method (id=61)
m3= Method (id=62)
m4= Method (id=63)
m5= Method (id=64)
m6= Method (id=65)
m7= Method (id=66)
m8= Method (id=67 )
nextUniqueNumber= 2 [0x2] [^B]
nextUniqueNumberLock= Object (id=68 )
pendingGenerationMarker= Object (id=69)
proxyClasses= Collections$SynchronizedMap<K,V> (id=70)
h= ClientContainer (id=73)
ejb/BenutzerManagerHome
{sun.misc.Launcher$AppClassLoader@92e78c={[org.jnp.interfaces.Naming]=java.lang.ref.WeakReference@bcb23e}, sun.rmi.server.LoaderHandler$Loader@1c4f0f8["http://RhuLaptop:8083/"]={[com.prodega.ejbtest.interfaces.BenutzerManagerHome, javax.ejb.Handle]=java.lang.ref.WeakReference@5a3923}}
public native int java.lang.Object.hashCode()
public boolean java.lang.Object.equals(java.lang.Object)
public java.lang.String java.lang.Object.toString()
public abstract com.prodega.ejbtest.interfaces.BenutzerManager com.prodega.ejbtest.interfaces.BenutzerManagerHome.create() throws javax.ejb.CreateException,java.rmi.RemoteException
public abstract void javax.ejb.EJBHome.remove(java.lang.Object) throws java.rmi.RemoteException,javax.ejb.RemoveException
public abstract void javax.ejb.EJBHome.remove(javax.ejb.Handle) throws java.rmi.RemoteException,javax.ejb.RemoveException
public abstract javax.ejb.EJBMetaData javax.ejb.EJBHome.getEJBMetaData() throws java.rmi.RemoteException
public abstract javax.ejb.HomeHandle javax.ejb.EJBHome.getHomeHandle() throws java.rmi.RemoteException
public abstract javax.ejb.EJBObject javax.ejb.Handle.getEJBObject() throws java.rmi.RemoteException
2
java.lang.Object@17918f0
java.lang.Object@1546dbc
{class $Proxy0=null, class $Proxy1=null}
org.jboss.proxy.ClientContainer@1d9e282
org.jboss.invocation.InvocationContext@1e0512a
org.jboss.proxy.ejb.HomeInterceptor@1f0aecc
class java.lang.Object
interface javax.ejb.EJBHome
interface javax.ejb.EJBObject
interface javax.ejb.Handle
org.jboss.proxy.SecurityInterceptor@1408a92
An extract from the h=ClientContainer EJB-METADATA
org.jboss.proxy.ejb.EJBMetaDataImpl@aa0877
interface com.prodega.ejbtest.interfaces.BenutzerManagerHome
org.jboss.proxy.ejb.handle.HomeHandleImpl@650892
null
Here an extract of the Proxy from the RCP Client (which failes):
ref= $Proxy1 (id=84)
loaderToCache= WeakHashMap<K,V> (id=99)
m0= Method (id=104)
m1= Method (id=110)
m2= Method (id=111)
m3= Method (id=112)
m4= Method (id=113)
m5= Method (id=114)
m6= Method (id=115)
m7= Method (id=116)
m8= Method (id=117)
nextUniqueNumberLock= Object (id=118)
pendingGenerationMarker= Object (id=119)
proxyClasses= Collections$SynchronizedMap<K,V> (id=120)
h= ClientContainer (id=123)
{sun.rmi.server.LoaderHandler$Loader@135605a["http://RhuLaptop:8083/"]={[com.prodega.ejbtest.interfaces.BenutzerManagerHome, javax.ejb.Handle]=java.lang.ref.WeakReference@1da87db}, org.eclipse.core.runtime.internal.adaptor.ContextFinder@1687e7c={[org.jnp.interfaces.Naming]=java.lang.ref.WeakReference@d6c07}}
2
java.lang.Object@11ff451
java.lang.Object@e0fcac
org.jboss.proxy.ClientContainer@1a73d30
org.jboss.invocation.InvocationContext@aefcbb
org.jboss.proxy.ejb.HomeInterceptor@528780
org.jboss.proxy.SecurityInterceptor@dfbb43
org.jboss.proxy.ejb.EJBMetaDataImpl@189a773
org.jboss.proxy.ejb.handle.HomeHandleImpl@61ec49
null
What could be the problem, do You have any idea
Best Regards and thanks in advance
Rene
| Re: How to connect from an RCP Client via RMI to an EJB (over Http) [message #443343 is a reply to message #443338] |
Fri, 27 January 2006 07:17   |
Alex Blewitt Messages: 946 Registered: July 2009 |
It's still likely to be a classpath issue, where your BenutzerManagerHome.class is being loaded by two classloaders; the Sun RMI one and the Plugin one. The data that's being returned via the Sun RMI classloader has the same name, but has a separate instance, as the class that's referenced by your plugin. You'll probably find that if you print out .identityHashCode() of both classes, that when running as your own application you have identical references to the Class object, whereas in the RCP application you have two different references to the Class object, even if they have the same name.
You might have luck playing around with the Buddy policy, and/or doing export package of your BenutzerManager classes, but frankly I think the only way you're likely to solve this is by not using a dynamic loading of classes and doing some kind of Corba pre-compilation of stub/skeleton classes (i.e. RMI/IIOP instead of RMI/HTTP) and ensuring that the stub/skeletons are present in your plugin's classpath.
http://help.eclipse.org/help31/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/buddy_loading.html
That's not to say that RMI/HTTP isn't possible, but you're going to have to get down and dirty with classloader hacks to make it work.
Alex.
| Re: How to connect from an RCP Client via RMI to an EJB (over Http) [message #443417 is a reply to message #443343] |
Sun, 29 January 2006 08:45   |
Hi Alex
Thanks a lot for Your help.
You are right, it is a classLoader problem.
I have now a version which works. I'am not sure whether it is a good solution or not.
I should solve the security problem with a policy file and not with a SecurityManager which allows everything.
But i was not able to make the plug-in read the policy file.
Here the solution:
System.setProperty( "java.naming.factory.initial", "org.jboss.naming.HttpNamingContextFactory" );
System.setProperty( "java.naming.provider.url", "http://localhost:8080/invoker/JNDIFactory" );
Thread.currentThread().setContextClassLoader(this.getClass() .getClassLoader());
boolean bool = BenutzerManagerHome.class.isAssignableFrom(ref.getClass());
benutzerManagerBean = home.create();
List list = benutzerManagerBean.getBenutzerByName("");
for (Iterator iter = list.iterator(); iter.hasNext();) {
Benutzer b = (Benutzer) iter.next();
System.out.println("Benutzername = " + b.getName());
One week for 10 lines of code. What do You think about that ??
Best regards and thanks a lot
Rene from Berne (CH)
FUDForum. Page generated in 0.01902 seconds
