Home » Eclipse Projects » Plugin Development Environment (PDE) » How to turn off PDE cache in .metadata/.plugins/org.eclipse.pde.core?
How to turn off PDE cache in .metadata/.plugins/org.eclipse.pde.core? [message #369] Tue, 08 April 2008 12:36 Go to next message
Todd E. Williams is currently offline Todd E. Williams
Member
When doing a complex feature export the PDE can become confused and refuse
to export a perfectly valid feature. The workaround I use to "fix" this
issue is:
1) shutdown the workbench
2) delete everything in .metadata/.plugins/org.eclipse.pde.core
3) restart the workbench
4) perform the export again, which will now succeed
Unfortunately, the cycle time on this workaround is rather large for a big
workspace. Is there a way to either clear this cache without a restart or,
even better, keep it from being created in the first place?
Todd
Re: How to turn off PDE cache in .metadata/.plugins/org.eclipse.pde.core? [message #406 is a reply to message #369] Thu, 10 April 2008 02:35 Go to previous messageGo to next message
Eclipse User
To clear the cache, try the hidden system property pde.nocache=true :)
~ Chris
Re: How to turn off PDE cache in .metadata/.plugins/org.eclipse.pde.core? [message #1044 is a reply to message #406] Mon, 14 April 2008 19:15 Go to previous message
Member
Chris,
Thanks very much. That seems to have done the trick!
Todd
"Chris Aniszczyk" <zx@us.ibm.com> wrote in message
news:ftkc4r$fju$1@build.eclipse.org...
>> big workspace. Is there a way to either clear this cache without a
>> restart or, even better, keep it from being created in the first place?
> Cheers,
> ~ Chris
Re: How to turn off PDE cache in .metadata/.plugins/org.eclipse.pde.core? [message #565197 is a reply to message #369] Thu, 10 April 2008 02:35 Go to previous message
Chris Aniszczyk is currently offline Chris Aniszczyk
~ Chris
Re: How to turn off PDE cache in .metadata/.plugins/org.eclipse.pde.core? [message #565602 is a reply to message #406] Mon, 14 April 2008 19:15 Go to previous message
Member
Chris,
Todd
> Cheers,
> ~ Chris
Previous Topic:Create Ant Build File should be available for OSGi projects too...
Next Topic:eclipse plugin deployment troubleshooting
Current Time: Sat May 18 14:01:18 EDT 2013
Powered by FUDForum. Page generated in 0.01814 seconds
