Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Threading problem between swing/swt
Threading problem between swing/swt [message #440122] Fri, 23 July 2004 11:27 Go to next message
Originally posted by: sunay.yaldiz.gentleware.com
I have a strange problem on threading, at least I guess it is because of
threading. In an Eclipse action, I am calling a method which shows (for
saving of a project)swing gui for asking "are you sure to overwrite "
etc and a progress bar for showing the status of saving. After showing
the window, it does not let the interaction with the window. I can not
answer as "yes" or "no" for example.
I tried to put the method call which shows swing gui in
display.asynchExec thinking it could help, but no help.
Display.asyncExec (new Runnable () {
public void run () { //this method shows swing gui and
progressdialog
myProject.save(filepath);
By the way, the save method also uses threads itself.(not sure if it is
related..)
What can I do, I am struggling with it since yesterday, but could not
find any solution.
Any help is appreciated,
Sunay
Re: Threading problem between swing/swt [message #440123 is a reply to message #440122] Fri, 23 July 2004 12:48 Go to previous messageGo to next message
David Thomson is currently offline David ThomsonFriend
Member
Did you try putting it in a separate thread and running it *without*
Display.syncExec/Display.asyncExec? I have never tried running a Swing
GUI from SWT, but I have tried the other way around, and I always have
to put it in a separate thread or otherwise it will block the Swing
event thread from continuing. If you try that and it doesn't work, I'll
experiment myself and try to help.
David
Sunay Yaldiz wrote:
> Hello,
> method shows swing gui and progressdialog
> related..)
> find any solution.
> Thanks
> Sunay
Re: Threading problem between swing/swt [message #440124 is a reply to message #440123] Fri, 23 July 2004 14:59 Go to previous message
Your suggestion worked. Thank you very much.
Sunay
> David
> Sunay Yaldiz wrote:
>> Hello,
>> of threading. In an Eclipse action, I am calling a method which shows
>> (for saving of a project)swing gui for asking "are you sure to
>> overwrite " etc and a progress bar for showing the status of saving.
>> After showing the window, it does not let the interaction with the
>> window. I can not answer as "yes" or "no" for example.
>> myProject.save(filepath); }
>> is related..)
>> find any solution.
>> Thanks
>> Sunay
Previous Topic:standalone SWT versus RCP
Next Topic:Text widget with small button inside
Current Time: Wed May 23 01:39:58 GMT 2018
Powered by FUDForum. Page generated in 0.02131 seconds
