Home » Eclipse Projects » Standard Widget Toolkit (SWT) » swing/awt threading question
swing/awt threading question [message #440009] Tue, 20 July 2004 16:04 Go to next message
David Scott is currently offline David ScottFriend
i am writing a ViewPart for the eclipse Workbench using a simple JList
swing component inside swt. the ViewPart registers itself as an
ISelectionProvider using an adapter for the ListSelectionModel in the
JList. The ViewPart is providing IAdaptable(s) for the Property view and
the Outline view which are both still swt components. When the
ListSelectionModel fires the Property view is notified by the adapter
and it got an SWTException indicating a threading error - so in the
ISelectionProvider adapter i put the notification inside a
Display.getDefault().asyncExec(). ok, so this left me wondering when i
get calls coming from swt components - do i need to wrap them in
EventQueue.invokeLater()?
thanks-
Re: swing/awt threading question [message #440039 is a reply to message #440009] Wed, 21 July 2004 16:38 Go to previous message
Steve Northover is currently offline Steve NorthoverFriend
Yes. Swing widgets are single threaded and should only be called from the
event dispatch thread.
"David Scott" <user@example.net> wrote in message
news:cdjfnp$rc8$1@eclipse.org...
> thanks-
Previous Topic:Coolbar repaint on application regaining focus (Win2K)
Next Topic:Table header color
Current Time: Fri May 25 01:42:14 GMT 2018
Powered by FUDForum. Page generated in 0.01368 seconds
