Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Draw over Activex
Draw over Activex [message #437644] Wed, 09 June 2004 08:30 Go to next message
Daniele Gariboldi is currently offline Daniele GariboldiFriend
I need to draw an image inside an activex (not mine), embedded in a SWT
OleFrame.
Is it possible to use its OleFrame graphic context ?
I tried to write something in a short time: no error but nothing on the
screen appeared.
Is it possible at all?
Has anybody tried it before ?
I have read of somebody who did it using GDI, so it should be possible.
And if I do it, is then possible to use GEF ?
Thanks.
Re: Draw over Activex [message #437728 is a reply to message #437644] Wed, 09 June 2004 17:39 Go to previous messageGo to next message
Veronika Irvine is currently offline Veronika IrvineFriend
The GC would have to be created on the handle of the widget you are trying
to draw on. The active X control can be made up of one or widgets - none of
which are visible through SWT. OleFrame and OleControlSite are only
wrappers around the activeX Control. Consider them to be the same as a
Composite in which you have created child widgets. Drawing on the parent
will not draw over the children.
"Daniele Gariboldi" <garidan@tele2.it> wrote in message
news:ca6hrj$j6n$1@eclipse.org...
> OleFrame.
> screen appeared.
> Thanks.
Re: Draw over Activex [message #437965 is a reply to message #437728] Mon, 14 June 2004 13:02 Go to previous message
OK,
thank you for your clear answer.
I'll try to explore this activex structure , otherwise I'll choose another
way.
> > OleFrame.
> > screen appeared.
> > Thanks.
Previous Topic:Help: Table dnd with cell colors
Next Topic:Multiline Text in a List
Current Time: Sat Apr 21 16:15:22 GMT 2018
Powered by FUDForum. Page generated in 0.01945 seconds
