Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Menu Images Problem
Menu Images Problem [message #437199] Tue, 01 June 2004 00:34 Go to next message
Originally posted by: raf_k.sympatico.ca
Menu Images set using the setImage() method aren't rendered correctly with
respect to transparency. I'm using a gif "save_edit.gif" from the icon
directory of the Eclipse release, so it should work.
I'm running Windows XP, and I have tried everything from manually setting
the transparency by defining the transparent pixel's RGB. I've been
pulling my hairs out all day trying to figure it out.
Thank you for any suggestions in advance.
-Raf
Re: Menu Images Problem [message #437236 is a reply to message #437199] Tue, 01 June 2004 14:18 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
WORKSFORME.
public static void main (String [] args) {
Display display = new Display ();
Image image = new Image (display, _Scrapbook.class.getResourceAsStream
("save_edit.gif"));
Shell shell = new Shell (display);
Menu menuBar = new Menu (shell, SWT.BAR);
shell.setMenuBar (menuBar);
MenuItem fileItem = new MenuItem (menuBar, SWT.CASCADE);
fileItem.setText ("File");
Menu fileMenu = new Menu (shell, SWT.DROP_DOWN);
fileItem.setMenu (fileMenu);
MenuItem saveItem = new MenuItem (fileMenu, SWT.PUSH);
saveItem.setText ("Save");
saveItem.setImage (image);
shell.open ();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
image.dispose ();
display.dispose ();
"Raf Kaplon" <raf_k@sympatico.ca> wrote in message
news:c9giuh$71v$1@eclipse.org...
> -Raf
Re: Menu Images Problem [message #437242 is a reply to message #437236] Tue, 01 June 2004 18:12 Go to previous messageGo to next message
Hi Steve,
I tried your exact code and still wasn't able to get transparency to work.
Could it be a project setup issue? I'm running windows XP, I have no idea
if that would be a factor either.
Steve Northover wrote:
> WORKSFORME.
> ("save_edit.gif"));
> shell.open ();
> image.dispose ();
> display.dispose ();
> > -Raf
Re: Menu Images Problem [message #437365 is a reply to message #437242] Thu, 03 June 2004 12:45 Go to previous message
Can you post a screen shot of what you are seeing?
news:c9igus$dvo$1@eclipse.org...
> Hi Steve,
> > WORKSFORME.
> > ("save_edit.gif"));
> > shell.open ();
> > image.dispose ();
> > display.dispose ();
with
setting
> > > -Raf
Previous Topic:where are settings for plugins stored
Next Topic:How to prevent a multiline text to accept tabs?
Current Time: Tue May 22 23:48:58 GMT 2018
Powered by FUDForum. Page generated in 0.02163 seconds
