Home » Eclipse Projects » Equinox » RCP Splash Screen
RCP Splash Screen [message #43759] Mon, 28 June 2004 03:48 Go to next message
Sermet Yucel is currently offline Sermet YucelFriend
I am writing an RCP application. I launch it using :
D:\OpenfoldPlugin\eclipse.exe -application
com.openfold.core.OpenfoldApplication -vm c:\j2sdk1.4.2\jre\bin\javaw
-vmargs -Dosgi.splashPath=platform:/base/plugins/com.openfold.core
This works fine. It starts with my splash screen, application, and
pespective.
I would like to pass splash path argument when I run the application
within the Eclipse as Run-time Workbench. I put
as a VM argument. It starts without a splash screen. Is this supposed to
work?
Thanks..
Re: RCP Splash Screen [message #44095 is a reply to message #43759] Mon, 28 June 2004 19:59 Go to previous message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
Just for kicks, launch your runtime workbench config and in the debugger
select your process and right click Properties. The command line should be
there. Does it look funny? (anything else related to splash on there)
Also, you don't say where your plugin is. Is it in the workspace? In the
target platform?
Jeff
"Sermet Yucel" <sermety@certusoft.com> wrote in message
news:cbo4e2$a0$1@eclipse.org...
> pespective.
> work?
> Thanks..
Previous Topic:Product
Next Topic:Problem with Classloader switch and narrow Object
Current Time: Sat May 26 16:04:24 GMT 2018
Powered by FUDForum. Page generated in 0.02166 seconds
