Home » Eclipse Projects » Standard Widget Toolkit (SWT) » ICellModifier using
| ICellModifier using [message #435789] |
Tue, 04 May 2004 04:48  |
Originally posted by: john.rmts.donpac.ru
My task is to write simple editor for host list from LDAP Directory. I
can't understand how to use ICellModifier for TableViewer.
I wrote this (sorry for large code, but it's minimal: LdapHost class and
it's factories are excluded):
public class NetworkConsoleWindow extends ApplicationWindow {
private DirContext ctx;
public NetworkConsoleWindow() throws IOException,
FileNotFoundException, NamingException {
super(null);
Properties connProperties = new Properties();
connProperties.load(new FileInputStream("connection.properties"));
connProperties.getProperty("ldap.url");
Hashtable env = new Hashtable();
env.put(Context.INITIAL_CONTEXT_FACTORY,
"com.sun.jndi.ldap.LdapCtxFactory");
env.put(Context.OBJECT_FACTORIES,
"networkconsole.core.LdapHostObjectFactory");
env.put(Context.STATE_FACTORIES,
"networkconsole.core.LdapHostStateFactory");
env.put(Context.PROVIDER_URL, connProperties.getProperty("ldap.url")+"/"+
connProperties.getProperty("ldap.hosts.context"));
env.put(Context.SECURITY_PRINCIPAL,
connProperties.getProperty("ldap.user"));
env.put(Context.SECURITY_CREDENTIALS,
connProperties.getProperty("ldap.password"));
ctx = new InitialDirContext(env);
private void dispose() throws NamingException {
ctx.close();
protected Control createContents(Composite parent) {
getShell().setText("Network Console");
Table table = new Table (parent,
SWT.BORDER|SWT.SINGLE|SWT.FULL_SELECTION);
table.setHeaderVisible (true);
String [] columnNames = new String[] {
"Host Name",
"Allow NAT"
for (int i=0; i<columnNames.length; i++) {
TableColumn column = new TableColumn (table, SWT.LEFT);
column.setText(columnNames[i]);
TableViewer viewer = new TableViewer (table);
viewer.setContentProvider(new HostsContentProvider());
viewer.setLabelProvider(new HostsLabelProvider());
viewer.setUseHashlookup(true);
viewer.setColumnProperties(columnNames);
CellEditor[] editors = new CellEditor[columnNames.length];
editors[1] = new CheckboxCellEditor(table);
viewer.setCellEditors(editors);
viewer.setCellModifier(new HostsCellModifier(ctx));
viewer.setInput(ctx);
return table;
public static void main(String[] args) throws IOException,
NetworkConsoleWindow w = new NetworkConsoleWindow();
w.setBlockOnOpen(true);
w.open();
Display.getCurrent().dispose();
private class HostsContentProvider implements IStructuredContentProvider {
public Object[] getElements(Object inputElement) {
try {
if (inputElement instanceof InitialDirContext) {
NamingEnumeration enum =
((InitialDirContext)inputElement).listBindings("");
ArrayList v = new ArrayList();
while (enum.hasMore()) {
Object item = ((Binding)enum.nextElement()).getObject();
if (item instanceof LdapHost)
v.add(item);
return v.toArray();
else
return null;
catch (NamingException exception){
return null;
public void dispose() {}
public void inputChanged(Viewer arg0, Object arg1, Object arg2) {}
private class HostsLabelProvider extends LabelProvider implements
ITableLabelProvider {
public Image getColumnImage(Object arg0, int arg1) {
return null;
public String getColumnText(Object element, int columnIndex) {
if (element instanceof LdapHost) {
LdapHost host = (LdapHost)element;
switch (columnIndex) {
case 0: return host.name;
case 1: return (host.allowNat)?("Yes"):("No");
return "";
public class HostsCellModifier implements ICellModifier {
public HostsCellModifier(DirContext ctx) {
super();
this.ctx = ctx;
public boolean canModify(Object element, String property) {
if (property == "Allow NAT")
return true;
else
return false;
public Object getValue(Object element, String property) {
if (element instanceof LdapHost && property == "Allow NAT") {
return new Boolean(host.allowNat);
else
return null;
public void modify(Object element, String property, Object value) {
try {
LdapHost host_new = (LdapHost)ctx.lookup("cn="+host.name);
host.allowNat = ((Boolean)value).booleanValue();
ctx.rebind("cn="+host.name, host);
catch (NamingException exception) {
This code display host list in table, but I can't edit "Allow NAT"
column. What is wrong?
| Re: ICellModifier using [message #440232 is a reply to message #435789] |
Mon, 26 July 2004 19:02  |
Paul E. Keyser Messages: 878 Registered: July 2009 |
I'm not sure, but I think you should switch all cases of this code:
to read like this:
property.equals(ALLOW_NAT);
and define one static String somewhere convenient:
static final String ALLOW_NAT = "Allow NAT";
and use ALLOW_NAT also in your array of column-names.
HTH,
Paul
Eugene Prokopiev wrote:
> super(null);
> ctx.close();
> "Host Name",
> "Allow NAT"
> return table;
> w.open();
> try {
> Object item =
> v.add(item);
> return v.toArray();
> else
> return null;
> return null;
> return null;
> return "";
> super();
> this.ctx = ctx;
> return true;
> else
> return false;
> else
> return null;
> value) {
> try {
> LdapHost host_new =
Current Time: Sat May 25 00:43:26 EDT 2013
Powered by FUDForum. Page generated in 0.03459 seconds
