Home » Eclipse Projects » Rich Client Platform (RCP) » How to add environment variable to config.ini
How to add environment variable to config.ini [message #435717] Mon, 22 August 2005 15:34 Go to next message
Tong Fin is currently offline Tong FinFriend
I would like to add an environment variable, for example
HOME_LIB=c:\mylib, to config.ini. This environment variable will be set
before my RCP is running.
What is the format of the statement to be in config.ini ?
Tong
Re: How to add environment variable to config.ini [message #435763 is a reply to message #435717] Tue, 23 August 2005 11:44 Go to previous messageGo to next message
Pascal Rapicault is currently offline Pascal RapicaultFriend
You can not set environment variable in a config.ini.
However all the properties set in this file are available in
System.getProperties().
Note that java 1.4 do not give access to the environment variable.
HTH
PaScaL
Tong Fin wrote:
> Tong
Re: How to add environment variable to config.ini [message #435771 is a reply to message #435763] Tue, 23 August 2005 13:12 Go to previous messageGo to next message
My RCP application uses DLLs that need some environment variables to be
set.
Where can I set (or specify in some file ?) these env. variables so that
they will be set before the Java VM is running ?
It is OK also if I can pass the settings as the arguments of Java VM.
Tong
> HTH
> PaScaL
> Tong Fin wrote:
>> HOME_LIB=c:mylib, to config.ini. This environment variable will be set
>> Thanks,
>> Tong
Re: How to add environment variable to config.ini [message #435805 is a reply to message #435771] Wed, 24 August 2005 00:55 Go to previous message
In the <exe>.ini you can specify VM args, however this will require you
to use an installer to generate the proper entry in the file to indicate
the location of the dll.
If you are delivering the dlls and they are loaded from plugin code, I
would recommend you to deliver them in a plugin (for examples see the
swt plugins and fragments).
PaScaL
> set.
> Tong
>> HTH
>> PaScaL
>> Tong Fin wrote:
>>> Hi,
>>> set before my RCP is running.
>>> Thanks,
>>> Tong
Previous Topic:documentation for Bundle-NativeCodeos
Next Topic:org.eclipse.compare refactoring in eclipse 3.2 ??
Current Time: Fri Apr 27 01:12:54 GMT 2018
Powered by FUDForum. Page generated in 0.02035 seconds
