Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Blank space after widget is not visible.
Blank space after widget is not visible. [message #435287] Mon, 26 April 2004 18:38 Go to next message
Originally posted by: meerab.yahoo.com
I am using GridLayout to display a form. The form makes some widget
controls "visible" and "invisible" based on user input.
I am observing that form is showing blank space for the controls that are
not visible. I am not able to get rid of the empty space. Has anyone faced
this issue? How to get rid of the blank space when the control is no
longer visible?
Pseudo code is..
// Add bannana
Text bannana = new Text(parent, SWT.Border);
bannana.setLayoutData( new GridData());
// Add mango
Text mango = new Text(parent, SWT.Border);
mango.setLayoutData( new GridData());
//... Some where down in the code..
if(userchoice == magno) {
bannana.setVisible(false);
mango.setVisible(true);
parent.pack(true);
}else {
bannana.setVisible(true);
mango.setVisible(false);
parent.pack(true);
** I see a blank link in the form display showing empty space for the
widget that has visibility "false" ***
Thanks for your help!!
-Meera
Re: Blank space after widget is not visible. [message #439367 is a reply to message #435287] Mon, 12 July 2004 12:51 Go to previous messageGo to next message
Kneubuehl Thomas is currently offline Kneubuehl ThomasFriend
Meera wrote:
> Hello,
> longer visible?
> Pseudo code is..
> // Add bannana
> // Add mango
> parent.pack(true);
> }else {
> parent.pack(true);
> -Meera
I face the same problem.
One solution would be to write a own Layout manager and check if the
widget is visible or not. If not visible do not place the widget.
I'm not 100% satisfied with this method, probably someone else knows more...
Tom
Re: Blank space after widget is not visible. [message #439434 is a reply to message #439367] Mon, 12 July 2004 17:54 Go to previous message
Steve Northover is currently offline Steve NorthoverFriend
https://bugs.eclipse.org/bugs/show_bug.cgi?id=49426
"Tom Kneubuehl" <kneubuehlt@post.ch> wrote in message
news:40f28952$1@news.post.ch...
> Meera wrote:
> > Hello,
are
faced
> > longer visible?
> > Pseudo code is..
> > // Add bannana
> > // Add mango
> > parent.pack(true);
> > }else {
> > parent.pack(true);
> > -Meera
more...
> Tom
Previous Topic:what's GP in the article: " SWT: The Standard Widget Toolkit - Part 1"
Next Topic:Event Handing
Current Time: Tue Feb 20 10:28:52 GMT 2018
Powered by FUDForum. Page generated in 0.01564 seconds
