Home » Eclipse Projects » Dali » Not able to add persistence of create EJV 3.0 Entity in Eclipse
Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433568] Thu, 09 March 2006 21:48 Go to next message
Sam is currently offline SamFriend
Member
I am a newbie to EJB 3.0 and I am hoping to be able to use DALI for EJB
3.0 development. Here is what i have installed few times but I am having
the following issues:
1. Add Persistence by choosing project and going Persistence->Add
Persistence displays the following message :
"The chosen operation is not currently available.
2. Creating an EJB 3.0 Entity by choosing project and then
New->Other->Persistence->EJB 3.0 Entity fails and the following error is
displayed:
"The selected wizard could not be started.
Reason:
Plug-in org.eclipse.dali.ui was unable to load class
org.eclipse.dali.ui.wizards.NewEntityCreationWizard."
Here is what i have installed:
wtp-sdk-R-1.0.1-200602171228.zip
JEM-SDK-1.1.0.1.zip
GEF-SDK-3.1.1.zip
emf-sdo-runtime-2.1.2.zip
eclipse-SDK-3.1.2-win32.zip
Dali-M1-I1-20060213.zip
I am using JDK Compliance of 5.0 and JRE 1.5.0_02.
Please help.
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433570 is a reply to message #433568] Sat, 11 March 2006 19:30 Go to previous messageGo to next message
Tran Le is currently offline Tran LeFriend
These errors messages show when the plugins are not properly installed.
You may want to verify that all Dali jars are in your eclipse/plugins
directory.
All the other components look okay (i.e. wtp, emf,...)
-Tran
Sam wrote:
> Persistence displays the following message : "The chosen operation is
> displayed:
> "The selected wizard could not be started. Reason:
> JEM-SDK-1.1.0.1.zip
> GEF-SDK-3.1.1.zip
> Please help.
> Thanks
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433573 is a reply to message #433570] Mon, 13 March 2006 19:08 Go to previous messageGo to next message
Member
Hi tran,
Thanks a lot for the response.
In fact, I already had all the below Dali jar files in the
C:\eclipse\plugins directory but still keep getting same errors and I have
also started eclipse with -clean option just in case eclipse is not
picking up dali jar files.
org.eclipse.dali.core_1.0.0.jar
org.eclipse.dali.db.ddl_0.5.0.jar
org.eclipse.dali.db_1.0.0.jar
org.eclipse.dali.edit_1.0.0.jar
org.eclipse.dali.ui_1.0.0.jar
org.eclipse.dali.utility_1.0.0.jar
Any further ideas/thoughts would be highly appreciated.
Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433574 is a reply to message #433573] Mon, 13 March 2006 22:08 Go to previous messageGo to next message
Neil Hauge is currently offline Neil HaugeFriend
Hi Sam,
Can you go to Help->About Eclipse SDK and send in the configuration
details text. My guess is that the plug-ins aren't resolving for some
reason. It is probably a dependency problem of some sort.
Neil
Sam wrote:
> Hi tran,
> C:eclipseplugins directory but still keep getting same errors and I have
> Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433575 is a reply to message #433574] Tue, 14 March 2006 15:53 Go to previous messageGo to next message
Member
Hi Neil,
Sure, please see the configuration details as well as error log
information I got from Help->About Eclipse SDK.
Configuration details:
*** Date: Tue Mar 14 10:47:15 EST 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20060118-1600
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\eclipse5\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
828_58
-vm
C:\5620Sam\oracle\jre\1.4.2\bin\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1142351196561
eclipse.vm=C:\5620Sam\oracle\jre\1.4.2\bin\javaw.exe
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
C:\eclipse5\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse5\eclipse\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\5620Sam\oracle\jre\1.4.2\lib\endorsed
java.ext.dirs=C:\5620Sam\oracle\jre\1.4.2\lib\ext
java.home=C:\5620Sam\oracle\jre\1.4.2
java.io.tmpdir=C:\DOCUME~1\skazan\LOCALS~1\Temp\
java.library.path=C:\5620Sam\oracle\jre\1.4.2\bin;.;C:\WINDO WS\system32;C:\WINDOWS;C:\5620Sam\oracle\jre\1.4.2\bin\clien t;C:\5620Sam\oracle\jre\1.4.2\bin;C:\5620Sam\oracle\bin;C:\W INDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;c:\cygwi n\bin;C:\Program
Files\apache-ant-1.6.1\bin
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_03-b02
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_03
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_03-b02
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.4
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imag eio,javax.imageio.event,javax.imageio.metadata,javax.imageio .plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.n aming,javax.naming.directory,javax.naming.event,javax.naming .ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,j avax.print.attribute,javax.print.attribute.standard,javax.pr int.event,javax.rmi,javax.rmi.CORBA,javax.security.auth,java x.security.auth.callback,javax.security.auth.kerberos,javax. security.auth.login,javax.security.auth.spi,javax.security.a uth.x500,javax.security.cert,javax.sound.midi,javax.sound.mi di.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parser,javax.swing.text.rtf,javax.sw ing.tree,javax.swing.undo,javax.transaction,javax.transactio n.xa,javax.xml.parsers,javax.xml.transform,javax.xml.transfo rm.dom,javax.xml.transform.sax,javax.xml.transform.stream,or g.ietf.jgss,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_ 3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPack age,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org .omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org .omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg. DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.D ynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactory Package,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.P ortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPa ckage,org.omg.PortableServer,org.omg.PortableServer.CurrentP ackage,org.omg.PortableServer.POAManagerPackage,org.omg.Port ableServer.POAPackage,org.omg.PortableServer.portable,org.om g.PortableServer.ServantLocatorPackage,org.omg.SendingContex t,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax. ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=c:\eclipse5\eclipse\configuration\org.eclip se.osgi\bundles
osgi.configuration.area=file:/c:/eclipse5/eclipse/configurat ion/
osgi.framework=file:/c:/eclipse5/eclipse/plugins/org.eclipse .osgi_3.1.2.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.1.2
osgi.install.area=file:/c:/eclipse5/eclipse/
osgi.instance.area=file:/C:/Documents and Settings/skazan/workspace5/
osgi.instance.area.default=file:/C:/Documents and
Settings/skazan/workspace/
osgi.logfile=C:\Documents and Settings\skazan\workspace5\.metadata\.log
osgi.manifest.cache=c:\eclipse5\eclipse\configuration\org.ec lipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\eclipse5\eclipse\plugins\org.eclipse. platform_3.1.2\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\eclipse5\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\5620Sam\oracle\jre\1.4.2\lib\rt.jar;C :\5620Sam\oracle\jre\1.4.2\lib\i18n.jar;C:\5620Sam\oracle\jr e\1.4.2\lib\sunrsasign.jar;C:\5620Sam\oracle\jre\1.4.2\lib\j sse.jar;C:\5620Sam\oracle\jre\1.4.2\lib\jce.jar;C:\5620Sam\o racle\jre\1.4.2\lib\charsets.jar;C:\5620Sam\oracle\jre\1.4.2 \classes
sun.boot.library.path=C:\5620Sam\oracle\jre\1.4.2\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\eclipse5\eclipse
user.home=C:\Documents and Settings\skazan
user.language=en
user.name=skazan
user.timezone=America/New_York
user.variant=
*** Features:
org.eclipse.emf (2.1.2) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.2) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source"
org.eclipse.jst (1.0.1.v200602130105) "J2EE Standard Tools (JST)"
org.eclipse.jst.common_core.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Common Core Source"
org.eclipse.jst.enterprise_core.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Enterprise Core Source"
org.eclipse.jst.enterprise_ui.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Enterprise UI Source"
org.eclipse.jst.sdk (1.0.1.v200602130105) "J2EE Standard Tools (JST)"
org.eclipse.jst.server_adapters.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Server Adapters Source"
org.eclipse.jst.server_core.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Server Core Source"
org.eclipse.jst.server_ui.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Server UI Source"
org.eclipse.jst.web_core.feature.source (1.0.1.200602171631) "J2EE
Standard Tools - Web Core Source"
org.eclipse.jst.web_ui.feature.source (1.0.1.200602171631) "J2EE Standard
Tools - Web UI Source"
org.eclipse.pde (3.1.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.2) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.2) "Eclipse Platform"
org.eclipse.platform.source (3.1.2) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.2) "Eclipse RCP"
org.eclipse.rcp.source (3.1.2) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.2) "Eclipse Project SDK"
org.eclipse.wst (1.0.1.v200602130105) "Web Standard Tools (WST)"
org.eclipse.wst.common_core.feature.source (1.0.1.200602171545) "Web
org.eclipse.wst.common_ui.feature.source (1.0.1.200602171545) "Web
Standard Tools - Common UI"
org.eclipse.wst.rdb_adapters.feature.source (1.0.1.200602171545) "Web
Standard Tools SDK - RDB Component"
org.eclipse.wst.sdk (1.0.1.v200602130105) "Web Standard Tools (WST)"
org.eclipse.wst.server_core.feature.source (1.0.1.200602171545) "Web
org.eclipse.wst.server_ui.feature.source (1.0.1.200602171545) "Web
org.eclipse.wst.web_core.feature.source (1.0.1.200602171545) "Web Standard
org.eclipse.wst.web_ui.feature.source (1.0.1.200602171545) "Web Standard
org.eclipse.wst.ws_core.feature.source (1.0.1.200602171545) "Web Standard
Tools - Web Service Core Source"
org.eclipse.wst.ws_ui.feature.source (1.0.1.200602171545) "Web Standard
Tools - Web Service UI Source"
org.eclipse.wst.xml_core.feature.source (1.0.1.200602171545) "Web Standard
Tools - XML Core Source"
org.eclipse.wst.xml_ui.feature.source (1.0.1.200602171545) "Web Standard
Tools - XML UI Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.2.1.v200602062208) "Axis121 Plug-in" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0.v200602062000) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.7.0.v200602052214) "Xerces 2.7.0" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.2) "Ant UI" [Resolved]
org.eclipse.compare (3.1.1) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.2) "File Buffers" [Active]
org.eclipse.core.resources (3.1.2) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.2) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.dali.core (1.0.0) "Dali Core" [Resolved]
org.eclipse.dali.db (1.0.0) "pluginName" [Resolved]
org.eclipse.dali.db.ddl (0.5.0) "Dali DDL Plug-in (Temporary)" [Resolved]
org.eclipse.dali.edit (1.0.0) "Dali Edit" [Resolved]
org.eclipse.dali.ui (1.0.0) "Dali UI" [Resolved]
org.eclipse.dali.utility (1.0.0) "pluginName" [Resolved]
org.eclipse.debug.core (3.1.2) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.2) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.1.1) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.2) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.2) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation"
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Resolved]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Resolved]
org.eclipse.emf.ecore.change (2.1.2) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
[Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.2) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.2) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.1.1) "Graphical Editing Framework
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.2) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.1.2) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.1.2) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
[Resolved]
org.eclipse.jdt.ui (3.1.2) "Java Development Tools UI" [Active]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Resolved]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.2) "JFace Text" [Active]
org.eclipse.jst (1.0.1.v200602130115) "J2EE Standard Tools (JST)"
[Resolved]
org.eclipse.jst.common_core.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Common Core Source" [Resolved]
org.eclipse.jst.common.annotations.controller (1.0.1.v200602070050)
"Annotation Controller Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (1.0.1.v200602070050) "Annotation
Core Plug-in" [Resolved]
org.eclipse.jst.common.annotations.ui (1.0.1.v200602070050) "Annotations
UI Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (1.0.1.v200602070050) "Integration
Plug-in" [Installed]
org.eclipse.jst.common.navigator.java (1.0.1.v200602070050) "Navigator
Plug-in" [Resolved]
org.eclipse.jst.common.project.facet.core (1.0.1.v200602070050) "Project
Facet Core (Java Support)" [Resolved]
org.eclipse.jst.doc.isv (1.0.1.v1) "WST ISV Documentation" [Resolved]
org.eclipse.jst.ejb.doc.user (1.0.0.v200602140535) "EJB docs" [Resolved]
org.eclipse.jst.ejb.ui (1.0.1.v200602070050) "WTP EJB UI Plug-in"
[Installed]
org.eclipse.jst.enterprise_core.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Enterprise Core Source" [Resolved]
org.eclipse.jst.enterprise_ui.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Enterprise UI Source" [Resolved]
org.eclipse.jst.j2ee (1.0.1.v200602162141) "J2EE Component" [Installed]
org.eclipse.jst.j2ee.core (1.0.1.v200602070050) "J2EE Core Component"
[Resolved]
org.eclipse.jst.j2ee.doc.user (1.0.1.v200602140535) "J2EE tools
documentation" [Resolved]
org.eclipse.jst.j2ee.ejb (1.0.1.v200602070050) "EJB component Plug-in"
[Installed]
org.eclipse.jst.j2ee.ejb.annotation.model (1.0.0.v200602071827) "EJB
Annotation Model Plug-in" [Installed]
org.eclipse.jst.j2ee.ejb.annotations.emitter (1.0.0.v200602071827) "EJB
Emitter Plug-in" [Installed]
org.eclipse.jst.j2ee.ejb.annotations.ui (1.0.0.v200502162142) "EJB
Annotations Ui Plug-in" [Installed]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (1.0.0.v200602071827)
"Xdoclet Annotations Plug-in" [Installed]
org.eclipse.jst.j2ee.infopop (1.0.1.v200602151541) "J2EE tools infopops"
[Resolved]
org.eclipse.jst.j2ee.jca (1.0.1.v200602070050) "JCA Plug-in" [Installed]
org.eclipse.jst.j2ee.jca.ui (1.0.1.v200602070050) "WTP JCA UI Plug-in"
[Installed]
org.eclipse.jst.j2ee.navigator.ui (1.0.1.v200602070050) "J2EE Extensions
to Common Navigator" [Installed]
org.eclipse.jst.j2ee.ui (1.0.1.v200602070050) "WTP J2EE UI Plug-in"
[Installed]
org.eclipse.jst.j2ee.web (1.0.1.v200602070050) "Web Plug-in" [Installed]
org.eclipse.jst.j2ee.webservice (1.0.1.v200602070050) "Web Service
org.eclipse.jst.j2ee.webservice.ui (1.0.1.v200602070050) "WTP Webservice
UI Plug-in" [Installed]
org.eclipse.jst.j2ee.xdoclet.runtime (1.0.0.v200602111615) "XDocletRuntime
org.eclipse.jst.jsp.core (1.0.1.v2006021502002350) "Structured Source JSP
Model" [Resolved]
org.eclipse.jst.jsp.ui (1.0.1.v200602062130) "SSE JSP Source Editor"
[Resolved]
org.eclipse.jst.jsp.ui.infopop (1.0.0.v200602140535) "JSP tools infopops"
[Resolved]
org.eclipse.jst.server_adapters.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Server Adapters Source" [Resolved]
org.eclipse.jst.server_core.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Server Core Source" [Resolved]
org.eclipse.jst.server_ui.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Server UI Source" [Resolved]
org.eclipse.jst.server.core (1.0.0.v20060131b) "Java Server Support"
[Resolved]
org.eclipse.jst.server.generic.core (1.0.0.v200602112126) "Generic Server
Plugin" [Resolved]
org.eclipse.jst.server.generic.serverdefinitions (1.0.0.v20060131b)
"Oracle OC4J v10.1.3 DP4 Generic Server Definition Core Plug-in" [Resolved]
org.eclipse.jst.server.generic.ui (1.0.1.v200602131705) "Generic Server
Plugin UI" [Resolved]
org.eclipse.jst.server.tomcat.core (1.0.0.v20060213) "Apache Tomcat
Support" [Resolved]
org.eclipse.jst.server.tomcat.ui (1.0.0.v20060131b) "Apache Tomcat UI
Support" [Resolved]
org.eclipse.jst.server.ui (1.0.0.v20060131b) "Java Server UI Support"
[Resolved]
org.eclipse.jst.server.ui.doc.user (1.0.1.v200602140535) "Server Tools
documentation for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.ui.infopop (1.0.1.v200602140535) "Server Tools
infopops for J2EE Standard Tools" [Resolved]
org.eclipse.jst.server.websphere.core (1.0.0.v20060131b) "WebSphere
Generic Server Definition Core Plug-in" [Installed]
org.eclipse.jst.servlet.ui (1.0.1.v200602070050) "WTP Servlet UI Plug-in"
[Installed]
org.eclipse.jst.servlet.ui.infopop (1.0.1.v200602130315) "Servlet infopop"
[Resolved]
org.eclipse.jst.web_core.feature.source (1.0.1.v200602151554) "J2EE
Standard Tools - Web Core Source" [Resolved]
org.eclipse.jst.web_ui.feature.source (1.0.1.v200602151554) "J2EE Standard
Tools - Web UI Source" [Resolved]
org.eclipse.jst.ws (1.0.1.v200602061953) "Web Services" [Installed]
org.eclipse.jst.ws.axis.consumption.core (1.0.1.v200602062208) "Web
service Axis Consumption Core" [Installed]
org.eclipse.jst.ws.axis.consumption.ui (1.0.1.v200602062208) "Webservice
Axis Consumption UI" [Installed]
org.eclipse.jst.ws.axis.creation.ui (1.0.1.v200602062000) "Webservice Axis
Creation UI" [Installed]
org.eclipse.jst.ws.axis.infopop (1.0.0.v200602140535) "Web services Axis
UI" [Resolved]
org.eclipse.jst.ws.axis.ui.doc.user (1.0.1.v200602140535) "Axis Web
services documentation" [Resolved]
org.eclipse.jst.ws.consumption (1.0.1.v200602061953) "Web Services
Consumption" [Installed]
org.eclipse.jst.ws.consumption.infopop (1.0.0.v200602140535) "Web services
UI" [Resolved]
org.eclipse.jst.ws.consumption.ui (1.0.1.v200602061953) "Web Services
Consumption Graphical User Interface" [Installed]
org.eclipse.jst.ws.consumption.ui.doc.user (1.0.1.v200602140535) "Web
service consumption documentation" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (1.0.0.v200602062000) "Web Services
Creation EJB Graphical User Interface" [Installed]
org.eclipse.jst.ws.creation.ui (1.0.1.v200602061953) "Web Services
Creation Graphical User Interface" [Installed]
org.eclipse.jst.ws.doc.user (1.0.1.v200602140535) "Web Services UI"
[Resolved]
org.eclipse.jst.ws.infopop (1.0.0.v200602140535) "Web services UI"
[Resolved]
org.eclipse.jst.ws.uddiregistry (1.0.0.v200602062000) "Web Services
Universal Description Discovery and Integration Registry" [Installed]
org.eclipse.jst.ws.ui (1.0.0.v200602062000) "Web Services Graphical User
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.2) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
[Resolved]
org.eclipse.pde.build (3.1.2) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Resolved]
org.eclipse.pde.doc.user (3.1.2) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment Runtime"
[Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.2) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.2) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.2) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.2) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.2) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.2) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.2) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.2) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Resolved]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.2) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.2) "Console" [Resolved]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.2) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.2) "Text Editor Framework"
[Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.2) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.wst (1.0.1.v200602130115) "Web Standard Tools (WST)" [Resolved]
org.eclipse.wst.command.env (1.0.1.v200602062000) "Environment Command
Framework (headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.1.v200602062000) "Environment
Command Framework (core)" [Resolved]
org.eclipse.wst.command.env.ui (1.0.1.v200602062000) "Environment Command
Framework (GUI)" [Resolved]
org.eclipse.wst.common_core.feature.source (1.0.1.v200602151554) "Web
org.eclipse.wst.common_ui.feature.source (1.0.1.v200602151554) "Web
Standard Tools - Common UI" [Resolved]
org.eclipse.wst.common.emf (1.0.1.v200602070050) "EMF Utilities" [Resolved]
org.eclipse.wst.common.emfworkbench.integration (1.0.1.v200602070050) "EMF
Workbench Edit Plug-in" [Installed]
org.eclipse.wst.common.environment (1.0.0.v200602151541) "Enviornment
Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.0.1.v200602070050)
"org.eclipse.wst.common.frameworks" [Resolved]
org.eclipse.wst.common.frameworks.ui (1.0.1.v200602070050) "WTP UI
Plug-in" [Resolved]
org.eclipse.wst.common.infopop (1.0.0.v200602140544) "Common WST infopops"
[Resolved]
org.eclipse.wst.common.modulecore (1.0.1.v200602162141) "Modulecore
org.eclipse.wst.common.navigator.views (1.0.1.v200602070050) "Common
Navigator View" [Resolved]
org.eclipse.wst.common.navigator.workbench (1.0.1.v200602070050)
"Navigator Workbench Components" [Resolved]
org.eclipse.wst.common.project.facet.core (1.0.1.v200602070050) "Project
Facet Core" [Resolved]
org.eclipse.wst.common.project.facet.ui (1.0.1.v200602070050) "Project
Facet UI" [Resolved]
org.eclipse.wst.common.snippets (1.0.0.v200602062130) "Snippets View"
[Resolved]
org.eclipse.wst.common.ui (1.0.0.v200602061610) "Eclipse Base UI
extensions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.0.v200602061610) "Common
Properties UI" [Resolved]
org.eclipse.wst.common.uriresolver (1.0.1.v200601310800) "Common URI
Resolver Framework" [Resolved]
org.eclipse.wst.css.core (1.0.0.v200602062135) "Structured Source CSS
Model" [Resolved]
org.eclipse.wst.css.ui (1.0.0.v200602062135) "SSE CSS Source Editor"
[Resolved]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.1.v200602130315)
"Data documentation" [Resolved]
org.eclipse.wst.datatools.data.ui.doc.user (1.0.1.v200602130315) "Data
tools data user interface documentation" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.1.v200602130315) "Data
org.eclipse.wst.datatools.server.ui.doc.user (1.0.1.v200602151541)
"Database Explorer documentation" [Resolved]
org.eclipse.wst.doc.isv (1.0.1.v1) "WST ISV Documentation" [Resolved]
org.eclipse.wst.doc.user (1.0.1.v200602130315) "Master User Doc TOC"
[Resolved]
org.eclipse.wst.dtd.core (1.0.1.v200602041933) "Structured Source DTD
Core" [Resolved]
org.eclipse.wst.dtd.ui (1.0.1.v200602041933) "SSE DTD Source Editor"
[Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.1.v200602140544) "DTD Editor infopops"
[Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.1.v200602130310) "DTD Editor
org.eclipse.wst.html.core (1.0.0.v200602062135) "Structured Source HTML
Model" [Resolved]
org.eclipse.wst.html.standard.dtds (1.0.0.v200602130315) "Known DTDs"
[Resolved]
org.eclipse.wst.html.ui (1.0.0.v200602062135) "HTML UI Source Editor"
[Resolved]
org.eclipse.wst.html.ui.infopop (1.0.0.v200602140544) "HTML editor
infopops" [Resolved]
org.eclipse.wst.internet.cache (1.0.0.v200602131700) "Cache URI Resolver
Plug-in" [Resolved]
org.eclipse.wst.internet.monitor.core (1.0.0.v20060131b) "Monitor"
[Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.0.v20060131b) "TCP/IP Monitor"
[Resolved]
org.eclipse.wst.internet.proxy (1.0.0.v200602061953) "Internet Proxy
Preferences" [Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0.v200602140544) "Internet
Proxy Infopops" [Resolved]
org.eclipse.wst.javascript.core (1.0.0.v200602062135) "Structured Source
JavaScript Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.0.v200602062135) "SSE JavaScript Source
Editor" [Resolved]
org.eclipse.wst.javascript.ui.infopop (1.0.0.v200602140544) "Javascript
infopop" [Resolved]
org.eclipse.wst.rdb_adapters.feature.source (1.0.1.v200602130145) "Web
Standard Tools SDK - RDB Component" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.0.v200602061859) "RDB
Connection.ui" [Resolved]
org.eclipse.wst.rdb.connection.ui.infopop (1.0.0.v200602140544) "New
Connection wizard infopops" [Resolved]
org.eclipse.wst.rdb.core (1.0.1.v200602061859) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (1.0.0.v200602061859) "Core UI plugin"
[Resolved]
org.eclipse.wst.rdb.data.core (1.0.0.v200602061859) "Data Core Plugin"
[Resolved]
org.eclipse.wst.rdb.data.ui (1.0.0.v200602061859) "Data UI Plugin"
[Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.1.v200602061923) "DB2
UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.1.v200602061923) "DB2 UDB
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.1.v200602061923) "DB2
UDB Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.derby (1.0.1.v200602061859) "IBM
Cloudscape Database Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.0.v200602061859) "Informix
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.0.v200602061859) "DBDefinition
Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.0.v200602061859) "Oracle
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.1.v200602061859) "SQL
Server Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.1.v200602061859) "Sybase
org.eclipse.wst.rdb.derby (1.0.1.v200602061859) "RDB Derby Plug-in"
[Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.0.v200602061859) "RDB Derby Ui Plug-in"
[Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.1.v200602061859) "FE Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.actions (1.0.0.v200602061859) "FE Ui Actions
Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0.v200602140544) "Generate DDL
org.eclipse.wst.rdb.models.dbdefinition (1.0.1.v200602061859)
"DBDefinition Model" [Resolved]
org.eclipse.wst.rdb.models.sql (1.0.1.v200602061859) "SQLModel Plug-in"
[Resolved]
org.eclipse.wst.rdb.models.sql.edit (1.0.0.v200602061859) "SQLModel Edit
Plug-in" [Resolved]
org.eclipse.wst.rdb.mysql (1.0.1.v200602061859) "RDB Mysql Plug-in"
[Resolved]
org.eclipse.wst.rdb.outputview (1.0.1.v200602061859) "Data Output Plug-in"
[Resolved]
org.eclipse.wst.rdb.outputview.infopop (1.0.0.v200602140544) "Data Output
view infopops" [Resolved]
org.eclipse.wst.rdb.server.extensions (1.0.1.v200602061859) "Server
Explorer Extensions Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.0.v200602061859) "Server Explorer
plugin" [Resolved]
org.eclipse.wst.rdb.server.ui.infopop (1.0.0.v200602140544) "Server
Explorer view infopops" [Resolved]
org.eclipse.wst.rdb.sqleditor (1.0.0.v200602061859) "SQL Source Editor
Plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0.v200602140544) "SQL infopops"
[Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.0.v200602061859) "Sqlscrapbook
Plug-in" [Resolved]
org.eclipse.wst.server_core.feature.source (1.0.1.v200602151554) "Web
org.eclipse.wst.server_ui.feature.source (1.0.1.v200602151554) "Web
org.eclipse.wst.server.core (1.0.0.v20060213) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.0.v20060216) "Server UI" [Active]
org.eclipse.wst.server.ui.doc.user (1.0.1.v200602130315) "Server Tools
documentation for Web Standard Tools" [Resolved]
org.eclipse.wst.server.ui.infopop (1.0.1.v200602140544) "Server Tools
infopops for Web Standard Tools" [Resolved]
org.eclipse.wst.sqleditor.doc.user (1.0.0.v200602140544) "Plugin.name"
[Resolved]
org.eclipse.wst.sse.core (1.0.0.v200602041933) "Structured Text Model"
[Resolved]
org.eclipse.wst.sse.doc.user (1.0.0.v200602130310) "Structured text editor
and snippets documentation" [Resolved]
org.eclipse.wst.sse.ui (1.0.1.v200602041933) "Structured Source Editor"
[Resolved]
org.eclipse.wst.sse.ui.infopop (1.0.1.v200602140544) "SSE infopops"
[Resolved]
org.eclipse.wst.validation (1.0.1.v200602070050) "Validation Framework"
[Resolved]
org.eclipse.wst.validation.ui (1.0.1.v200602070050) "Validation Framework
UI" [Resolved]
org.eclipse.wst.web (1.0.1.v200602070050) "Simple Web Plug-in" [Installed]
org.eclipse.wst.web_core.feature.source (1.0.1.v200602151554) "Web
org.eclipse.wst.web_ui.feature.source (1.0.1.v200602151554) "Web Standard
org.eclipse.wst.web.ui (1.0.1.v200602070050) "Simple Web UI Plug-in"
[Installed]
org.eclipse.wst.web.ui.infopop (1.0.1.v200602130315) "Static Web infopop"
[Resolved]
org.eclipse.wst.webtools.doc.user (1.0.1.v200602130315) "Web tools
org.eclipse.wst.ws (1.0.0.v200602061953) "Web Services" [Installed]
org.eclipse.wst.ws_core.feature.source (1.0.1.v200602151554) "Web Standard
Tools - Web Service Core Source" [Resolved]
org.eclipse.wst.ws_ui.feature.source (1.0.1.v200602151554) "Web Standard
Tools - Web Service UI Source" [Resolved]
org.eclipse.wst.ws.explorer (1.0.1.v200602061953) "Web Services Explorer"
[Installed]
org.eclipse.wst.ws.infopop (1.0.1.v200602151541) "Web Services UI"
[Resolved]
org.eclipse.wst.ws.parser (1.0.0.v200602062000) "Web Services Description
Parser" [Installed]
org.eclipse.wst.ws.ui (1.0.0.v200602062000) "Web Services UI" [Installed]
org.eclipse.wst.wsdl (1.0.0.v200602061610) "WSDL Model" [Installed]
org.eclipse.wst.wsdl.ui (1.0.1.v200602061610) "WSDL Editor" [Installed]
org.eclipse.wst.wsdl.ui.doc.user (1.0.1.v200602140544) "WSDL Editor
org.eclipse.wst.wsdl.validation (1.0.1.v200602030355) "WSDL Validator"
[Resolved]
org.eclipse.wst.wsi (1.0.1.v200602030355) "WSI Conformance Tools"
[Installed]
org.eclipse.wst.wsi.ui (1.0.0.v200601280245) "Soap Monitor" [Installed]
org.eclipse.wst.wsi.ui.doc.user (1.0.1.v200602140544) "WS-I Validation
org.eclipse.wst.xml_core.feature.source (1.0.1.v200602151554) "Web
Standard Tools - XML Core Source" [Resolved]
org.eclipse.wst.xml_ui.feature.source (1.0.1.v200602151554) "Web Standard
Tools - XML UI Source" [Resolved]
org.eclipse.wst.xml.core (1.0.0.v200602050425) "Structured Source XML
Model" [Resolved]
org.eclipse.wst.xml.ui (1.0.1.v200602041933) "XML UI Plugin" [Resolved]
org.eclipse.wst.xml.ui.infopop (1.0.1.v200602140544) "XML infopops"
[Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.1.v200602130310) "XML editor"
[Resolved]
org.eclipse.wst.xsd.core (1.0.1.v200602060215) "XSD Core Plugin"
[Installed]
org.eclipse.wst.xsd.ui (1.0.0.v200602061610) "XML Schema Editor"
[Installed]
org.eclipse.wst.xsdeditor.doc.user (1.0.0.v200602130310) "XML schema
editor" [Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.uddi4j (2.0.4.v200602062000) "UDDI4J 2.0.4" [Resolved]
org.wsdl4j (1.4.0.v200602131706) "WSDL4J 1.4" [Resolved]
system.bundle (3.1.2) "OSGi System Bundle" [Active]
*** User Preferences:
#Tue Mar 14 10:47:16 EST 2006
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Program
Files/Java/jre1.5.0_02/lib/rt.jar
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.ui.ide/quickStart=true
/instance/org.eclipse.ui.ide/platformState=332
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
file_export_version=3.0
@org.eclipse.jdt.ui=3.1.2
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=c\:/eclipse5/eclipse
@org.eclipse.jdt.launching=3.1.0
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.ui/showIntro=false
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.jdt.core=3.1.2
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=C\:\\Doc uments and
Settings\\skazan\\workspace5
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=true
@org.eclipse.ui.ide=3.1.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.core.resources=3.1.2
@org.eclipse.ui=3.1.2
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1141939595046 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="1141939595046" name\="JRE" path\="C\:\\Program
Files\\Java\\jre1.5.0_02"
javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"/>\r\n</vmType>\r\n</vmSettings>\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=c\:/eclipse5/eclipse/plugins/org.junit_ 3.8.1
/instance/org.eclipse.wst.server.core/module-start-timeout=3 00000
@org.eclipse.ui.editors=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=8
@org.eclipse.wst.server.core=1.0.0.v20060213
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
*** Current Install Configuration:
Install configuration:
Last changed on Mar 9, 2006
file:/c:/eclipse5/eclipse/configuration/org.eclipse.update/p latform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.wst.web_core.feature.source, Version: 1.0.1.200602171545
ID: org.eclipse.wst.common_userdoc.feature, Version: 1.0.1.v200602130300
1.0.1.200602171631
ID: org.eclipse.jdt.source, Version: 3.1.2
ID: org.eclipse.wst.common_sdk.feature, Version: 1.0.1.v200602130300
ID: org.eclipse.jst.web_ui.feature.source, Version: 1.0.1.200602171631
ID: org.eclipse.wst.web_ui.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst, Version: 1.0.1.v200602130105
ID: org.eclipse.rcp.source, Version: 3.1.2
ID: org.eclipse.wst.server_userdoc.feature, Version: 1.0.1.v200602130300
ID: org.eclipse.jst.web_ui.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.common_ui.feature, Version: 1.0.1.v200602151554
1.0.1.200602171631
ID: org.eclipse.platform, Version: 3.1.2
ID: org.eclipse.wst.rdb_core.feature, Version: 1.0.1.v200602130145
ID: org.eclipse.jst.server_ui.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.web_userdoc.feature, Version: 1.0.1.v200602130215
1.0.1.200602171631
1.0.1.v200602131710
ID: org.eclipse.jdt, Version: 3.1.2
ID: org.eclipse.wst.ws_core.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.jst.server_ui.feature.source, Version: 1.0.1.200602171631
ID: org.eclipse.jst.web_userdoc.feature, Version: 1.0.1.v200602130345
ID: org.eclipse.wst.ws_ui.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.server_ui.feature.source, Version: 1.0.1.200602171545
ID: org.eclipse.wst.server_core.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.ws_userdoc.feature, Version: 1.0.1.v200602130310
ID: org.eclipse.emf, Version: 2.1.2
ID: org.eclipse.jst.server_core.feature, Version: 1.0.1.v200602151554
ID: org.wsdl4j.feature, Version: 1.4.0.v200602130710
ID: org.eclipse.wst.server_sdk.feature, Version: 1.0.1.v200602130300
1.0.1.200602171545
ID: org.eclipse.pde, Version: 3.1.2
ID: org.eclipse.jem.sdk, Version: 1.1.0.1
ID: org.eclipse.jst.server_adapters.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.xml_core.feature.source, Version: 1.0.1.200602171545
ID: org.eclipse.wst.xml_ui.feature.source, Version: 1.0.1.200602171545
ID: org.eclipse.jst.web_sdk.feature, Version: 1.0.1.v200602130345
ID: org.eclipse.jst, Version: 1.0.1.v200602130105
ID: org.eclipse.jst.web_core.feature.source, Version: 1.0.1.200602171631
ID: org.apache.xerces.feature, Version: 2.7.0.v200602052216
ID: org.eclipse.wst.rdb_sdk.feature, Version: 1.0.1.v200602130145
1.0.1.200602171545
ID: org.eclipse.jst.doc.isv.feature, Version: 1.0.1.v200602160648
ID: org.eclipse.sdk, Version: 3.1.2
ID: org.eclipse.pde.source, Version: 3.1.2
ID: org.eclipse.jst.web_core.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.xml_ui.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.web_core.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.doc.isv.feature, Version: 1.0.1.v200602160648
ID: org.eclipse.jst.server_userdoc.feature, Version: 1.0.1.v200602130400
ID: org.eclipse.wst.ws_ui.feature.source, Version: 1.0.1.200602171545
ID: org.eclipse.wst.rdb_adapters.feature, Version: 1.0.1.v200602130145
ID: org.apache.wsil4j.feature, Version: 1.0.0.v200602130710
ID: org.eclipse.wst.ws_sdk.feature, Version: 1.0.1.v200602130310
ID: org.eclipse.jst.enterprise_ui.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.server_ui.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.common_ui.feature.source, Version: 1.0.1.200602171545
ID: org.eclipse.wst.xml_core.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.gef.source, Version: 3.1.1
ID: org.eclipse.wst.xml_userdoc.feature, Version: 1.0.1.v200602130145
ID: org.eclipse.wst.common_core.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.wst.rdb_userdoc.feature, Version: 1.0.1.v200602130145
ID: org.eclipse.jem, Version: 1.1.0.1
ID: org.eclipse.jst.enterprise_sdk.feature, Version: 1.0.1.v200602131710
ID: org.eclipse.jst.common_core.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.gef, Version: 3.1.1
ID: org.eclipse.jst.server_sdk.feature, Version: 1.0.1.v200602130400
1.0.1.200602171545
ID: org.eclipse.wst.rdb_ui.feature, Version: 1.0.1.v200602130145
ID: org.uddi4j.feature, Version: 2.0.3.v200602130710
ID: org.eclipse.jem.source, Version: 1.1.0.1
ID: org.eclipse.jst.enterprise_core.feature, Version: 1.0.1.v200602151554
ID: org.eclipse.rcp, Version: 3.1.2
ID: org.eclipse.platform.source, Version: 3.1.2
ID: org.apache.axis.feature, Version: 1.2.1.v200602130710
ID: org.eclipse.wst.xml_sdk.feature, Version: 1.0.1.v200602130145
ID: org.eclipse.jst.common_sdk.feature, Version: 1.0.1.v200602131710
1.0.1.200602171631
ID: org.eclipse.wst.ws_core.feature.source, Version: 1.0.1.200602171545
ID: org.eclipse.wst.web_sdk.feature, Version: 1.0.1.v200602131325
ID: org.eclipse.emf.ecore.sdo, Version: 2.1.1
1.0.1.200602171631
ID: org.eclipse.wst.web_ui.feature.source, Version: 1.0.1.200602171545
Configured plug-ins:
file:/c:/eclipse5/eclipse/plugins/com.ibm.etools.emf.event_3 .0.0.1/
file:/c:/eclipse5/eclipse/plugins/org.apache.ant_1.6.5/
file:/c:/eclipse5/eclipse/plugins/org.apache.axis_1.2.1.v200 602062208/
file:/c:/eclipse5/eclipse/plugins/org.apache.lucene_1.4.3/
file:/c:/eclipse5/eclipse/plugins/org.apache.wsil4j_1.0.0.v2 00602062000/
file:/c:/eclipse5/eclipse/plugins/org.apache.xerces_2.7.0.v2 00602052214/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.ant.core_3.1.1 .jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.ant.ui_3.1.2.j ar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.compare_3.1.1. jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.boot_3.1. 0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.commands_ 3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.expressio ns_3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.filebuffe rs_3.1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.resources .compatibility_3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.resources .win32_3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.resources _3.1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.runtime.c ompatibility_3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.runtime_3 .1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.core.variables _3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.dali.core_1.0. 0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.dali.db.ddl_0. 5.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.dali.db_1.0.0. jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.dali.edit_1.0. 0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.dali.ui_1.0.0. jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.dali.utility_1 .0.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.debug.core_3.1 .2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.debug.ui_3.1.2 .jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.draw2d.doc.isv _3.1.1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.draw2d_3.1.1.j ar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ant_2.1.0. jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.codegen.ec ore.ui_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.codegen.ec ore_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.codegen.ui _2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.codegen_2. 1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.common.ui_ 2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.commonj.sd o_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.common_2.1 .0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore.chan ge.edit_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore.chan ge_2.1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore.edit or_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore.edit _2.1.1.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore.sdo. editor_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore.sdo. edit_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore.sdo_ 2.1.1.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore.xmi_ 2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.ecore_2.1. 0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.edit.ui_2. 1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.edit_2.1.1 .jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.importer.e core_2.1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.importer.j ava_2.1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.importer.r ose_2.1.1.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.importer_2 .1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.mapping.ec ore2ecore.editor_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.mapping.ec ore2ecore_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.mapping.ec ore2xml.ui_2.1.1.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.mapping.ec ore2xml_2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.mapping.ui _2.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf.mapping_2. 1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.emf_2.1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.gef.doc.isv_3. 1.1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.gef.source_3.1 .1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.gef_3.1.1.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.help.appserver _3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.help.base_3.1. 0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.help.ui_3.1.1. jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.help.webapp_3. 1.0/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.help_3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.core_3.1.2 .jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.debug.ui_3 .1.2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.debug_3.1. 1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.doc.isv_3. 1.2/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.doc.user_3 .1.1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.junit.runt ime_3.1.0/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.junit_3.1. 1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.launching_ 3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.source_3.1 .2/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt.ui_3.1.2.j ar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jdt_3.1.0.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jem.beaninfo_1 .1.0.1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jem.proxy_1.1. 0.1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jem.sdk_1.1.0/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jem.source_1.1 .0.1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jem.ui_1.1.0.1 /
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jem.util_1.1.0 .1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jem.workbench_ 1.1.0.1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jem_1.1.0.1/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jface.text_3.1 .2.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jface_3.1.1.ja r
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.common.ann otations.controller_1.0.1.v200602070050.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.common.ann otations.core_1.0.1.v200602070050.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.common.ann otations.ui_1.0.1.v200602070050.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.common.fra meworks_1.0.1.v200602070050.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.common.nav igator.java_1.0.1.v200602070050.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.common.pro ject.facet.core_1.0.1.v200602070050.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.common_cor e.feature.source_1.0.1.v200602151554/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.doc.isv_1. 0.1.v1.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.ejb.doc.us er_1.0.0.v200602140535.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.ejb.ui_1.0 .1.v200602070050.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.enterprise _core.feature.source_1.0.1.v200602151554/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.enterprise _ui.feature.source_1.0.1.v200602151554/
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.j2ee.core_ 1.0.1.v200602070050.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.j2ee.doc.u ser_1.0.1.v200602140535.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.j2ee.ejb.a nnotation.model_1.0.0.v200602071827.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.j2ee.ejb.a nnotations.emitter_1.0.0.v200602071827.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.j2ee.ejb.a nnotations.ui_1.0.0.v200502162142.jar
file:/c:/eclipse5/eclipse/plugins/org.eclipse.jst.j2ee.ejb.a nnotations.xdoclet_1.0.0.v200602071827.jar
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433576 is a reply to message #433575] Wed, 15 March 2006 15:26 Go to previous messageGo to next message
The problem is that there is a class version incompatibility with the Dali
plugin and your Eclipse JDK. If you start Eclipse with a 1.5 JDK, this
problem should be resolved.
We will be posting the M1 (iteration 2) build in the next couple of days,
and this JDK requirement will no longer exist. You will then be able to
run our plug-in with 1.4 or 1.5 JDK.
Neil
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433582 is a reply to message #433576] Sun, 19 March 2006 19:27 Go to previous messageGo to next message
Member
Hi Neil,
I have dowloaded the 1.4 JDK and have set JAVA_HOME to point to the jdk
home directory and have the eclipse pointing to 1.4 jre but still no luck
and i keep getting same problem.
Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433584 is a reply to message #433582] Mon, 20 March 2006 18:22 Go to previous messageGo to next message
Sam,
The new M1 release will definitively work with 1.4 JDK. Make sure you
remove previous versions of Dali plugins from your plugin directory as
the jar names have changed.
http://www.eclipse.org/dali/downloads.html
-Tran
Sam wrote:
> Hi Neil,
> luck and i keep getting same problem.
> Thanks
> Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #433586 is a reply to message #433582] Mon, 20 March 2006 23:36 Go to previous message
Member
Tran Le And Neil and all who responded,
thanks a lot, now it worked after I replaced Dali jar files according to
Tran.
Very appreciated and countless thanks
Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #575871 is a reply to message #433568] Sat, 11 March 2006 19:30 Go to previous message
directory.
-Tran
Sam wrote:
> displayed:
> JEM-SDK-1.1.0.1.zip
> GEF-SDK-3.1.1.zip
> Please help.
> Thanks
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #575955 is a reply to message #433570] Mon, 13 March 2006 19:08 Go to previous message
Member
Hi tran,
Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #575972 is a reply to message #433573] Mon, 13 March 2006 22:08 Go to previous message
Hi Sam,
Neil
Sam wrote:
> Hi tran,
> Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #576002 is a reply to message #433574] Tue, 14 March 2006 15:53 Go to previous message
Member
Hi Neil,
win32
-ws
win32
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
828_58
-vm
-Xmx256m
-jar
eof=eof
file.separator=\
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.nl=en_US
osgi.os=win32
osgi.ws=win32
path.separator=;
user.country=US
user.language=en
user.name=skazan
user.variant=
*** Features:
Resources"
Resources"
Resources"
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Editor" [Resolved]
[Resolved]
[Resolved]
Editor" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Support" [Active]
[Resolved]
[Resolved]
[Resolved]
Plug-in" [Resolved]
[Installed]
[Resolved]
[Installed]
[Resolved]
[Installed]
[Installed]
Model" [Resolved]
[Resolved]
[Resolved]
[Resolved]
Plugin" [Resolved]
Support" [Resolved]
Support" [Resolved]
[Resolved]
[Installed]
[Resolved]
UI" [Resolved]
UI" [Resolved]
[Resolved]
[Resolved]
[Resolved]
Support" [Resolved]
[Resolved]
[Resolved]
Guide" [Resolved]
[Resolved]
[Resolved]
Windows" [Resolved]
[Resolved]
[Resolved]
[Active]
[Active]
[Resolved]
Plug-in" [Resolved]
Plug-in" [Resolved]
[Resolved]
[Resolved]
Model" [Resolved]
[Resolved]
[Resolved]
Core" [Resolved]
[Resolved]
[Resolved]
Model" [Resolved]
[Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
[Resolved]
Editor" [Resolved]
infopop" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
[Resolved]
plugin" [Resolved]
Plugin" [Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
UI" [Resolved]
[Installed]
[Resolved]
[Installed]
[Resolved]
Parser" [Installed]
[Resolved]
[Installed]
Model" [Resolved]
[Resolved]
[Resolved]
[Installed]
[Installed]
editor" [Resolved]
Configured sites:
platform:/base/
1.0.1.200602171631
1.0.1.200602171631
1.0.1.200602171631
1.0.1.v200602131710
1.0.1.200602171545
1.0.1.200602171545
1.0.1.200602171545
1.0.1.200602171631
1.0.1.200602171631
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #576032 is a reply to message #433575] Wed, 15 March 2006 15:26 Go to previous message
Neil
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #576117 is a reply to message #433576] Sun, 19 March 2006 19:27 Go to previous message
Member
Hi Neil,
Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #576137 is a reply to message #433582] Mon, 20 March 2006 18:22 Go to previous message
Sam,
-Tran
Sam wrote:
> Hi Neil,
> Thanks
> Sam
Re: Not able to add persistence of create EJV 3.0 Entity in Eclipse [message #576170 is a reply to message #433582] Mon, 20 March 2006 23:36 Go to previous message
Member
Tran.
Sam
Previous Topic:Dali in a WTP build?
Next Topic:postgresql not supported?
Current Time: Wed May 23 09:26:20 GMT 2018
Powered by FUDForum. Page generated in 0.03293 seconds
