Home » Eclipse Projects » Standard Widget Toolkit (SWT) » What JARs are required to run a JFace App?
What JARs are required to run a JFace App? [message #433539] Sat, 10 April 2004 06:52 Go to next message
Pete is currently offline PeteFriend
I am just a newbie to SWT/Jface, I am using the latest Eclipse 3.0 M8,
from this: http://www-106.ibm.com/developerworks/library/os-ecgui1/
It said that I have to include the following JARs :
C:\eclipse-2.1.0\plugins\org.eclipse.jface_2.1.0\jface.jar
C:\eclipse-2.1.0\plugins\org.eclipse.runtime_2.1.0\runtime.j ar
C:\eclipse-2.1.0\plugins\org.eclipse.swt.win32_2.1.0\ws\win3 2\swt.jar
C:\eclipse-2.1.0\plugins\org.eclipse.ui.workbench_2.1.0\work bench.jar
C:\eclipse-2.1.0\plugins\org.eclipse.core.runtime_2.1.0\runt ime.jar
But I am using Eclipse 3.0 , I cannot find this
So I have only included the rest of the JARs, the app can compile and
run, but the Menu cannot be showed.
Anyone can help?
Re: What JARs are required to run a JFace App? [message #433545 is a reply to message #433539] Sat, 10 April 2004 12:48 Go to previous messageGo to next message
Mike Lischke is currently offline Mike LischkeFriend
Member
Well, you should have a bit more imagination. 3M8 is a beta so you cannot
expect that references for the release version of Eclipse fit also the
unofficial version. If you don't find org.eclipse.core.runtime_2.... but
instead org.eclipse.core.runtime_3... then it seems quite obvious to use
the latter. The same holds for the other packages.
Mike
www.soft-gems.net
Re: What JARs are required to run a JFace App? [message #433549 is a reply to message #433545] Sat, 10 April 2004 13:06 Go to previous message
Hi Mike,
I have found :
org.eclipse.core.runtime_3.0.0\runtime.jar
but not this :
org.eclipse.runtime_3.0.0\runtime.jar
I believe that should be "2" runtime.jar needed as said in the IBM'
tutorial ? Isn't ?
Pete
> cannot expect that references for the release version of Eclipse fit
> also the unofficial version. If you don't find
> org.eclipse.core.runtime_2.... but instead org.eclipse.core.runtime_3...
> then it seems quite obvious to use the latter. The same holds for the
> other packages.
> Mike
Previous Topic:gap in table item
Next Topic:Removing the vertical scrollbar from the Browser
Current Time: Sat Jun 23 23:59:37 GMT 2018
Powered by FUDForum. Page generated in 0.02489 seconds
