Home » Eclipse Projects » Dali » persistence perspective not available
persistence perspective not available [message #433502] Tue, 17 January 2006 03:31 Go to next message
Max Giesbert is currently offline Max GiesbertFriend
Member
Hi there,
i am running eclipse-3.1.1-linux-gtk2-x86_64 on linux x86_64 with jdk
1.5.0._06-x86_64 with wtp-1.0 (also tried 0.7.1) and its pre-reqs. on top
comes dali-01-03-06. I used the -clean option after unzipping to the
eclipse folder.
sadly the persistence option doesn't show up anywhere. but the persistence
rdb plug-in and utility plug-in show up in eclipse plug-in info.
any suggestions? right now i am using jsr220orm which works fine but want
to switch to its successor asap.
thx
max
Re: persistence perspective not available [message #433504 is a reply to message #433502] Tue, 17 January 2006 15:16 Go to previous messageGo to next message
Neil Hauge is currently offline Neil HaugeFriend
Max,
I'll re-verify that the build is good and get back to you with some
suggestions.
Neil
"Max Giesbert" <giesbert@exactt.de> wrote in message
news:6985e1ae86c37c5dddd9403a6f5bc854$1@www.eclipse.org...
> Hi there,
> eclipse folder.
> thx
> max
Re: persistence perspective not available [message #433505 is a reply to message #433504] Tue, 17 January 2006 19:15 Go to previous messageGo to next message
Max,
I have verified that this build should work with your general
configuration. I think you will find that all 5 Dali plug-ins are
installed if you sort by Plug-in ID in the Plug-in Details. Our provider
names are not consistent at the moment, and this was likely the cause of
the confusion. This issue will be corrected in the next build.
I am thinking that your problem may be that in WTP 1.0 and greater, the
Persistence menu item on a Java project does not display in the J2EE
perspective. To work around this, simply switch to the Java Perspective
and Add Persistence... to the project. The Persistence perspective and
both Persistence views should be found in their respective locations (Open
Perspective, Show View).
Hopefully this info will get you going. First do verify that the 5 dali
plug-ins are indeed configured by sorting by Plug-in ID in the Plug-in
Details.
Neil
Neil Hauge wrote:
> Max,
> suggestions.
> Neil
>> Hi there,
>> eclipse folder.
>> thx
>> max
Re: persistence perspective not available [message #433506 is a reply to message #433505] Wed, 18 January 2006 00:30 Go to previous messageGo to next message
Member
Hi Neil,
thx for the response. still it is not working. i did another fresh
install. here is exactly what i did.
I installed by mergeing all the zip files together as follows and in the
given order:
eclipse-SDK-3.1.1-linux-gtk-x86_64
emf-sdo-xsd-SDK-2.1.1
GEF-SDK-3.1.1
JEM-SDK-1.1.0.1
wtp-wst-sdk-1.0
Dali_01-03-06
the i started eclipse with -clean option
use a fresh workspace
create new java project with 5.0 compiler compliance
still i can't add persintence to the project by right-clicking on the
project name. also the persintence option in the perspective menu doesn't
show up.
i still can only find two plug-ins in the plug-in details. when sorting by
id and looking under org.eclipse.dali then only the mentioned two items
show up. i didn't find any other dali stuff. do i have to look for
something else?
anyway all 5 plug-ins show up in the configuration details as seen below.
thx for further help
max
here the eclipse configuration details:
*** Date: Wed Jan 18 11:24:08 EST 2006
*** Platform Details:
*** System properties:
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20050929-0840
eclipse.commands=-os
linux
-ws
gtk
-arch
x86_64
-launcher
/home/max/programs/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
92001e
-clean
-vm
/usr/lib/jvm/java/jre/bin/java
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1137543771103
eclipse.vm=/usr/lib/jvm/java/jre/bin/java
eclipse.vmargs=-Xms40m
-Xmx256m
-jar
/home/max/programs/eclipse/startup.jar
eof=eof
file.encoding=UTF-8
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/home/max/programs/eclipse/startup.jar
java.class.version=49.0
java.endorsed.dirs=/usr/lib/jvm/jdk1.5.0_06/jre/lib/endorsed
java.ext.dirs=/usr/lib/jvm/jdk1.5.0_06/jre/lib/ext
java.home=/usr/lib/jvm/jdk1.5.0_06/jre
java.io.tmpdir=/tmp
java.library.path=/usr/lib/jvm/jdk1.5.0_06/jre/lib/amd64/ser ver:/usr/lib/jvm/jdk1.5.0_06/jre/lib/amd64:/usr/lib/jvm/jdk1 .5.0_06/jre/../lib/amd64
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=de
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.14-1.1656_FC4
org.osgi.framework.processor=amd64
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=amd64
os.name=Linux
osgi.arch=x86_64
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=/home/max/programs/eclipse/configuration/or g.eclipse.osgi/bundles
osgi.clean=true
osgi.configuration.area=file:/home/max/programs/eclipse/conf iguration/
osgi.framework=file:/home/max/programs/eclipse/plugins/org.e clipse.osgi_3.1.1.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.1.1
osgi.install.area=file:/home/max/programs/eclipse/
osgi.instance.area=file:/home/max/test/workspace/
osgi.instance.area.default=file:/home/max/workspace/
osgi.logfile=/home/max/test/workspace/.metadata/.log
osgi.manifest.cache=/home/max/programs/eclipse/configuration /org.eclipse.osgi/manifests
osgi.nl=de_DE
osgi.os=linux
osgi.splashLocation=/home/max/programs/eclipse/plugins/org.e clipse.platform_3.1.1/splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/home/max/programs/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=64
sun.boot.class.path=/usr/lib/jvm/jdk1.5.0_06/jre/lib/rt.jar: /usr/lib/jvm/jdk1.5.0_06/jre/lib/i18n.jar:/usr/lib/jvm/jdk1. 5.0_06/jre/lib/sunrsasign.jar:/usr/lib/jvm/jdk1.5.0_06/jre/l ib/jsse.jar:/usr/lib/jvm/jdk1.5.0_06/jre/lib/jce.jar:/usr/li b/jvm/jdk1.5.0_06/jre/lib/charsets.jar:/usr/lib/jvm/jdk1.5.0 _06/jre/classes
sun.boot.library.path=/usr/lib/jvm/jdk1.5.0_06/jre/lib/amd64
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=gnome
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=UTF-8
sun.management.compiler=HotSpot 64-Bit Server Compiler
sun.os.patch.level=unknown
user.country=DE
user.dir=/home/max/encrypt
user.home=/home/max
user.language=de
user.name=max
user.timezone=Australia/Sydney
*** Features:
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.1) "Eclipse Modeling Framework (EMF) Programmers
Guide"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.1) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.source (2.1.1) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.1) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.1) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source"
org.eclipse.pde (3.1.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.1) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.1) "Eclipse Platform"
org.eclipse.platform.source (3.1.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.1) "Eclipse RCP"
org.eclipse.rcp.source (3.1.1) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.1) "Eclipse Project SDK"
org.eclipse.wst (1.0.0) "Web Standard Tools"
org.eclipse.wst.common_core.feature.source (1.0.0) "Web Standard Tools SDK
- Common Component"
org.eclipse.wst.common_ui.feature.source (1.0.0) "Web Standard Tools SDK -
Common Component"
org.eclipse.wst.rdb_adapters.feature.source (1.0.0) "Web Standard Tools
SDK - XML Component"
org.eclipse.wst.rdb_core.feature.source (1.0.0) "Web Standard Tools SDK -
XML Component"
org.eclipse.wst.rdb_ui.feature.source (1.0.0) "Web Standard Tools SDK -
XML Component"
org.eclipse.wst.server_core.feature.source (1.0.0) "Web Standard Tools SDK
- Common Component"
org.eclipse.wst.server_ui.feature.source (1.0.0) "Web Standard Tools SDK -
WST Server Component"
org.eclipse.wst.web_core.feature.source (1.0.0) "Web Standard Tools SDK -
Common Component"
org.eclipse.wst.web_ui.feature.source (1.0.0) "Web Standard Tools SDK -
WST Web Component"
org.eclipse.wst.ws_core.feature.source (1.0.0) "Web Standard Tools SDK -
Common Component"
org.eclipse.wst.ws_ui.feature.source (1.0.0) "Web Standard Tools SDK - WST
Web Component"
org.eclipse.wst.xml_core.feature.source (1.0.0) "Web Standard Tools SDK -
Common Component"
org.eclipse.wst.xml_ui.feature.source (1.0.0) "Web Standard Tools SDK -
WST XML Component"
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.1) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.1.1) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.2.1) "Axis121 Plug-in" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.7.0) "Xerces 2.7.0" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.1) "Ant UI" [Resolved]
org.eclipse.compare (3.1.1) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.0) "File Buffers" [Active]
org.eclipse.core.resources (3.1.0) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.linux (3.1.0) "Core Resource Management Linux
org.eclipse.core.runtime (3.1.1) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.dali.core (1.0.0) "Persistence Model" [Installed]
org.eclipse.dali.db (1.0.0) "Persistence Rdb Plug-in" [Resolved]
org.eclipse.dali.edit (1.0.0) "Dali Edit Support" [Installed]
org.eclipse.dali.ui (1.0.0) "Persistence Editor" [Installed]
org.eclipse.dali.utility (1.0.0) "Utility Plug-in" [Resolved]
org.eclipse.debug.core (3.1.0) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.1) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.1.1) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.1) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.0) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation"
[Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Active]
Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.1.0) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)" [Active]
Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO)
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.0) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.1) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
[Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.1.1) "Graphical Editing Framework
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.1) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.1.1) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.1.1) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit
runtime support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching
Support" [Active]
[Resolved]
org.eclipse.jdt.ui (3.1.1) "Java Development Tools UI" [Active]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Active]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.1) "JFace Text" [Active]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.1) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment"
[Resolved]
org.eclipse.pde.build (3.1.0) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Resolved]
org.eclipse.pde.doc.user (3.1.1) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment Runtime"
[Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.1) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.1) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.1) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.linux.gtk.x86_64 (3.1.1) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.linux.gtk.x86_64 (3.1.1) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.1) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.1.1) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86_64 (3.1.1) "Standard Widget Toolkit for GTK
2.0" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Resolved]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.1) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.0) "Console" [Resolved]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.workbench (3.1.1) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.1) "Text Editor Framework"
[Active]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.1) "Install/Update Core" [Resolved]
org.eclipse.update.core.linux (3.1.0) "Install/Update Core for Linux"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.wst (1.0.0) "Web Standard Tools" [Resolved]
org.eclipse.wst.command.env (1.0.0) "Environment Command Framework
(headless)" [Resolved]
org.eclipse.wst.command.env.core (1.0.0) "Environment Command Framework
(core)" [Resolved]
org.eclipse.wst.command.env.ui (1.0.0) "Environment Command Framework
(GUI)" [Resolved]
- Common Component" [Resolved]
org.eclipse.wst.common.emf (1.0.0) "EMF Utilities" [Active]
org.eclipse.wst.common.emfworkbench.integration (1.0.0) "EMF Workbench
Edit Plug-in" [Resolved]
org.eclipse.wst.common.environment (1.0.0) "Enviornment Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (1.0.0)
"org.eclipse.wst.common.frameworks" [Active]
org.eclipse.wst.common.frameworks.ui (1.0.0) "WTP UI Plug-in" [Resolved]
org.eclipse.wst.common.infopop (1.0.0) "Common WST infopops" [Resolved]
org.eclipse.wst.common.modulecore (1.0.0) "Modulecore Plug-in" [Resolved]
org.eclipse.wst.common.navigator.views (1.0.0) "Common Navigator View"
[Active]
org.eclipse.wst.common.navigator.workbench (1.0.0) "Navigator Workbench
Components" [Resolved]
org.eclipse.wst.common.project.facet.core (1.0.0) "Project Facet Core"
[Resolved]
org.eclipse.wst.common.project.facet.ui (1.0.0) "Project Facet UI"
[Resolved]
org.eclipse.wst.common.snippets (1.0.0) "Snippets View" [Resolved]
org.eclipse.wst.common.ui (1.0.0) "Eclipse Base UI extensions" [Resolved]
org.eclipse.wst.common.ui.properties (1.0.0) "Common Properties UI"
[Active]
org.eclipse.wst.common.uriresolver (1.0.0) "Common URI Resolver Framework"
[Resolved]
org.eclipse.wst.css.core (1.0.0) "Structured Source CSS Model" [Resolved]
org.eclipse.wst.css.ui (1.0.0) "SSE CSS Source Editor" [Resolved]
org.eclipse.wst.datatools.connection.ui.doc.user (1.0.0) "Data
documentation" [Resolved]
org.eclipse.wst.datatools.fe.ui.doc.user (1.0.0) "Data documentation"
[Resolved]
org.eclipse.wst.datatools.server.ui.doc.user (1.0.0) "Data server
org.eclipse.wst.doc.isv (1.0.0) "WST ISV Documentation" [Resolved]
org.eclipse.wst.doc.user (1.0.0) "master user doc toc" [Resolved]
org.eclipse.wst.dtd.core (1.0.0) "Structured Source DTD Core" [Resolved]
org.eclipse.wst.dtd.ui (1.0.0) "SSE DTD Source Editor" [Resolved]
org.eclipse.wst.dtd.ui.infopop (1.0.0) "DTD infopops" [Resolved]
org.eclipse.wst.dtdeditor.doc.user (1.0.0) "DTD Editor documentation"
[Resolved]
org.eclipse.wst.html.core (1.0.0) "Structured Source HTML Model" [Resolved]
org.eclipse.wst.html.standard.dtds (1.0.0) "Known DTDs" [Resolved]
org.eclipse.wst.html.ui (1.0.0) "HTML UI Source Editor" [Resolved]
org.eclipse.wst.html.ui.infopop (1.0.0) "HTML editor infopops" [Resolved]
org.eclipse.wst.internet.cache (1.0.0) "Cache URI Resolver Plug-in"
[Resolved]
org.eclipse.wst.internet.monitor.core (1.0.0) "Monitor" [Resolved]
org.eclipse.wst.internet.monitor.ui (1.0.0) "TCP/IP Monitor" [Resolved]
org.eclipse.wst.internet.proxy (1.0.0) "Internet Proxy Preferences"
[Active]
org.eclipse.wst.internet.proxy.infopop (1.0.0) "Internet Proxy Infopops"
[Resolved]
org.eclipse.wst.javascript.core (1.0.0) "Structured Source JavaScript
Model" [Resolved]
org.eclipse.wst.javascript.ui (1.0.0) "SSE JavaScript Source Editor"
[Resolved]
org.eclipse.wst.javascript.ui.infopop (1.0.0) "Javascript infopop"
[Resolved]
SDK - XML Component" [Resolved]
org.eclipse.wst.rdb.connection.ui (1.0.0) "RDB Connection.ui" [Resolved]
org.eclipse.wst.rdb.connection.ui.infopop (1.0.0) "New Connection wizard
org.eclipse.wst.rdb.core (1.0.0) "RDB Core" [Active]
org.eclipse.wst.rdb.core.ui (1.0.0) "Core UI plugin" [Active]
org.eclipse.wst.rdb.data.core (1.0.0) "Data Core Plugin" [Resolved]
org.eclipse.wst.rdb.data.ui (1.0.0) "Data UI Plugin" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.0) "DB2 UDB iSeries
Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (1.0.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.db2.zseries (1.0.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.derby (1.0.0) "IBM Cloudscape Database
Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (1.0.0) "Informix Database
org.eclipse.wst.rdb.dbdefinition.mysql (1.0.0) "DBDefinition Mysql
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (1.0.0) "Oracle Database
org.eclipse.wst.rdb.dbdefinition.sqlserver (1.0.0) "SQL Server Database
org.eclipse.wst.rdb.dbdefinition.sybase (1.0.0) "Sybase Database
org.eclipse.wst.rdb.derby (1.0.0) "RDB Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.derby.ui (1.0.0) "RDB Derby Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui (1.0.0) "FE Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.actions (1.0.0) "FE Ui Actions Plug-in"
[Resolved]
org.eclipse.wst.rdb.fe.ui.infopop (1.0.0) "Generate DDL wizard infopops"
[Resolved]
org.eclipse.wst.rdb.models.dbdefinition (1.0.0) "DBDefinition Model"
[Resolved]
org.eclipse.wst.rdb.models.sql (1.0.0) "SQLModel Plug-in" [Active]
org.eclipse.wst.rdb.models.sql.edit (1.0.0) "SQLModel Edit Plug-in"
[Resolved]
org.eclipse.wst.rdb.mysql (1.0.0) "RDB Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview (1.0.0) "Data Output Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview.infopop (1.0.0) "Data Output view infopops"
[Resolved]
org.eclipse.wst.rdb.server.extensions (1.0.0) "Server Explorer Extensions
Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (1.0.0) "Server Explorer plugin" [Active]
org.eclipse.wst.rdb.server.ui.infopop (1.0.0) "Server Explorer view
org.eclipse.wst.rdb.sqleditor (1.0.0) "SQL Source Editor Plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor.infopop (1.0.0) "SQL infopops" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (1.0.0) "Sqlscrapbook Plug-in" [Resolved]
WST Server Component" [Resolved]
org.eclipse.wst.server.core (1.0.0) "Server Core" [Active]
org.eclipse.wst.server.ui (1.0.0) "Server UI" [Active]
org.eclipse.wst.server.ui.doc.user (1.0.0) "Managing servers for Server
Tools documentation" [Resolved]
org.eclipse.wst.server.ui.infopop (7.0) "Server Tools infopops for Web
org.eclipse.wst.sqleditor.doc.user (1.0.0) "Plugin.name" [Resolved]
org.eclipse.wst.sse.core (1.0.0) "Structured Text Model" [Resolved]
org.eclipse.wst.sse.doc.user (1.0.0) "Structured text editor and snippets
org.eclipse.wst.sse.ui (1.0.0) "Structured Source Editor" [Resolved]
org.eclipse.wst.sse.ui.infopop (1.0.0) "SSE infopops" [Resolved]
org.eclipse.wst.validation (1.0.0) "Validation Framework" [Resolved]
org.eclipse.wst.validation.ui (1.0.0) "Validation Framework UI" [Resolved]
org.eclipse.wst.web (1.0.0) "Simple Web Plug-in" [Resolved]
WST Web Component" [Resolved]
org.eclipse.wst.web.ui (1.0.0) "Simple Web UI Plug-in" [Resolved]
org.eclipse.wst.webtools.doc.user (1.0.0) "Web tools documentation"
[Resolved]
org.eclipse.wst.ws (1.0.0) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (1.0.0) "Web Services Explorer" [Resolved]
org.eclipse.wst.ws.infopop (1.0.0) "Web services UI" [Resolved]
org.eclipse.wst.ws.parser (1.0.0) "Web Services Description Parser"
[Resolved]
org.eclipse.wst.ws.ui (1.0.0) "Web Services UI" [Resolved]
org.eclipse.wst.wsdl (1.0.0) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (1.0.0) "WSDL Editor" [Resolved]
org.eclipse.wst.wsdl.ui.doc.user (1.0.0) "WSDL Editor Documentation"
[Resolved]
org.eclipse.wst.wsdl.validation (1.0.0) "WSDL Validator" [Resolved]
org.eclipse.wst.wsi (1.0.0) "WSI Conformance Tools" [Resolved]
org.eclipse.wst.wsi.ui (1.0.0) "Soap Monitor" [Resolved]
org.eclipse.wst.wsi.ui.doc.user (1.0.0) "WS Documentation" [Resolved]
WST XML Component" [Resolved]
org.eclipse.wst.xml.core (1.0.0) "Structured Source XML Model" [Resolved]
org.eclipse.wst.xml.ui (1.0.0) "XML UI Plugin" [Resolved]
org.eclipse.wst.xml.ui.infopop (1.0.0) "XML infopops" [Resolved]
org.eclipse.wst.xmleditor.doc.user (1.0.0) "XML editor" [Resolved]
org.eclipse.wst.xsd.core (1.0.0) "XSD Core Plugin" [Resolved]
org.eclipse.wst.xsd.ui (1.0.0) "XML Schema Editor" [Resolved]
org.eclipse.wst.xsdeditor.doc.user (1.0.0) "XML schema editor" [Resolved]
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)" [Resolved]
Guide" [Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
[Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.uddi4j (2.0.3) "UDDI4J 2.0.3" [Resolved]
org.wsdl4j (1.4.0) "WSDL4J 1.4" [Resolved]
system.bundle (3.1.1) "OSGi System Bundle" [Active]
*** User Preferences:
#Wed Jan 18 11:24:08 EST 2006
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Mo nospace|10|0|GTK|1|;
@org.eclipse.wst.server.core=1.0.0
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=8
/instance/org.eclipse.ui/showIntro=false
@org.eclipse.ui=3.1.1
/instance/org.eclipse.ui.ide/platformState=276
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\n<web-browsers current\="0">\n<system/>\n<external
location\="/usr/bin/mozilla" name\="Mozilla"/>\n</web-browsers>
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=true
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\n<vm
id\="0" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jdk1.5.0_06"
path\="/usr/lib/jvm/jdk1.5.0_06"/>\n</vmType>\n</vmSettings >\n
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
@org.eclipse.ui.browser=3.1.1
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
@org.eclipse.core.resources=3.1.0
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
@org.eclipse.ui.ide=3.1.1
@org.eclipse.jdt.ui=3.1.1
/instance/org.eclipse.wst.server.core/module-start-timeout=3 00000
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=/home/ma x/test/workspace
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.ui.ide/quickStart=true
file_export_version=3.0
@org.eclipse.jdt.launching=3.1.0
@org.eclipse.jdt.core=3.1.1
*** Current Install Configuration:
Install configuration:
Last changed on 18.01.2006
file:/home/max/programs/eclipse/configuration/org.eclipse.up date/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.wst.web_core.feature.source, Version: 1.0.0
ID: org.eclipse.wst.common_userdoc.feature, Version: 1.0.0
ID: org.eclipse.jdt.source, Version: 3.1.1
ID: org.eclipse.wst.common_sdk.feature, Version: 1.0.0
ID: org.eclipse.emf.ecore.sdo.source, Version: 2.1.1
ID: org.eclipse.wst.web_ui.feature, Version: 1.0.0
ID: org.eclipse.wst.sdk, Version: 1.0.0
ID: org.eclipse.rcp.source, Version: 3.1.1
ID: org.eclipse.wst.server_userdoc.feature, Version: 1.0.0
ID: org.eclipse.wst.common_ui.feature, Version: 1.0.0
ID: org.eclipse.platform, Version: 3.1.1
ID: org.eclipse.wst.rdb_core.feature, Version: 1.0.0
ID: org.eclipse.emf.source, Version: 2.1.1
ID: org.eclipse.wst.web_userdoc.feature, Version: 1.0.0
ID: org.eclipse.jdt, Version: 3.1.1
ID: org.eclipse.wst.ws_core.feature, Version: 1.0.0
ID: org.eclipse.wst.ws_ui.feature, Version: 1.0.0
ID: org.eclipse.wst.server_ui.feature.source, Version: 1.0.0
ID: org.eclipse.wst.server_core.feature, Version: 1.0.0
ID: org.eclipse.wst.ws_userdoc.feature, Version: 1.0.0
ID: org.eclipse.emf, Version: 2.1.1
ID: org.eclipse.wst.rdb_core.feature.source, Version: 1.0.0
ID: org.wsdl4j.feature, Version: 1.4.0
ID: org.eclipse.wst.server_sdk.feature, Version: 1.0.0
ID: org.eclipse.xsd.source, Version: 2.1.1
ID: org.eclipse.wst.rdb_adapters.feature.source, Version: 1.0.0
ID: org.eclipse.pde, Version: 3.1.1
ID: org.eclipse.xsd, Version: 2.1.1
ID: org.eclipse.emf.doc, Version: 2.1.1
ID: org.eclipse.jem.sdk, Version: 1.1.0.1
ID: org.eclipse.wst.xml_core.feature.source, Version: 1.0.0
ID: org.eclipse.wst.xml_ui.feature.source, Version: 1.0.0
ID: org.apache.xerces.feature, Version: 2.7.0
ID: org.eclipse.wst.rdb_ui.feature.source, Version: 1.0.0
ID: org.eclipse.wst.rdb_sdk.feature, Version: 1.0.0
ID: org.eclipse.wst.server_core.feature.source, Version: 1.0.0
ID: org.eclipse.pde.source, Version: 3.1.1
ID: org.eclipse.sdk, Version: 3.1.1
ID: org.eclipse.wst.web_core.feature, Version: 1.0.0
ID: org.eclipse.wst.xml_ui.feature, Version: 1.0.0
ID: org.eclipse.wst.doc.isv.feature, Version: 1.0.0
ID: org.eclipse.wst.ws_ui.feature.source, Version: 1.0.0
ID: org.eclipse.wst.rdb_adapters.feature, Version: 1.0.0
ID: org.eclipse.emf.ecore.sdo.doc, Version: 2.1.1
ID: org.apache.wsil4j.feature, Version: 1.0.0
ID: org.eclipse.wst.ws_sdk.feature, Version: 1.0.0
ID: org.eclipse.wst.server_ui.feature, Version: 1.0.0
ID: org.eclipse.wst.common_ui.feature.source, Version: 1.0.0
ID: org.eclipse.wst.xml_core.feature, Version: 1.0.0
ID: org.eclipse.gef.source, Version: 3.1.1
ID: org.eclipse.wst.xml_userdoc.feature, Version: 1.0.0
ID: org.eclipse.wst.common_core.feature, Version: 1.0.0
ID: org.eclipse.wst.rdb_userdoc.feature, Version: 1.0.0
ID: org.eclipse.jem, Version: 1.1.0.1
ID: org.eclipse.gef, Version: 3.1.1
ID: org.eclipse.wst.common_core.feature.source, Version: 1.0.0
ID: org.eclipse.wst.rdb_ui.feature, Version: 1.0.0
ID: org.eclipse.jem.source, Version: 1.1.0.1
ID: org.uddi4j.feature, Version: 2.0.3
ID: org.eclipse.platform.source, Version: 3.1.1
ID: org.eclipse.rcp, Version: 3.1.1
ID: org.eclipse.emf.sdk, Version: 2.1.1
ID: org.apache.axis.feature, Version: 1.2.1
ID: org.eclipse.xsd.doc, Version: 2.1.1
ID: org.eclipse.wst.xml_sdk.feature, Version: 1.0.0
ID: org.eclipse.wst.ws_core.feature.source, Version: 1.0.0
ID: org.eclipse.emf.ecore.sdo, Version: 2.1.1
ID: org.eclipse.wst.web_sdk.feature, Version: 1.0.0
ID: org.eclipse.wst, Version: 1.0.0
ID: org.eclipse.wst.web_ui.feature.source, Version: 1.0.0
Configured plug-ins:
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.serv er.ui.infopop_7.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.pde.ui_3 .1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.sse. ui.infopop_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml.ui_2.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.ltk.ui.r efactoring_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.ecor e.sdo.source_2.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.jem.sour ce_1.1.0.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.views _3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.osgi_3.1 .1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.pde.buil d_3.1.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. derby_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.apache.ant_1.6.5 /
file:/home/max/programs/eclipse/plugins/org.eclipse.rcp.sour ce.linux.gtk.x86_64_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. core.ui_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.exter naltools_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.html .ui.infopop_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.java script.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. derby.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.compare_ 3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.edito rs_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.serv er.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.xsd.edit _2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xsd. core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.apache.axis_1.2. 1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.serv er_ui.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.junit_3.8.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. sqleditor.infopop_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jem_1.1. 0.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.ecor e.editor_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jem.ui_1 .1.0.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.wsi. ui.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.team.cor e_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm and.env.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb_ core.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. dbdefinition.sqlserver_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.dtd. ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. outputview_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.forms _3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.vali dation_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.ws_c ore.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.edit .ui_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. dbdefinition.oracle_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.web_ 1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.ecor e.xmi_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.code gen.ecore.ui_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.help.bas e_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xml. core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. sqleditor_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.pde.sour ce_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xml_ ui.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.project.facet.core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.debug.co re_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.help.web app_3.1.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. mysql_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.mapp ing_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.web_ core.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. sqlscrapbook_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb_ ui.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.impo rter_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jem.sdk_ 1.1.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.ant.ui_3 .1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.inte rnet.monitor.core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xsd. ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.ui_3 .1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm and.env.core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.frameworks.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.serv er_core.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.workb ench.compatibility_3.1.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.help.ui_ 3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.help_3.1 .0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.xsd.ecor e.importer_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.sse. core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. server.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.doc. user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. fe.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. outputview.infopop_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.team.cvs .ui_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.uriresolver_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.doc. user_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.comm on_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.impo rter.ecore_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.pde.core _3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. models.sql_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.team.cvs .ssh2_3.1.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.jem.work bench_1.1.0.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.tomcat_4 .1.30.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.data tools.connection.ui.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.wsdl .ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.dali.ui_ 1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.rcp.sour ce_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.inte rnet.monitor.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.sqle ditor.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.ecor e.sdo_2.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.emfworkbench.integration_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.impo rter.rose_2.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.ecor e.sdo.editor_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.ecor e.sdo.doc_2.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. dbdefinition.sybase_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf_2.1. 1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.sse. doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.web. ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm and.env_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.xsd.edit or_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.ws.e xplorer_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.css. ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.navigator.workbench_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.brows er_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.ws.p arser_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.core.res ources_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.core.fil ebuffers_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.ws_1 .0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xsde ditor.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.serv er.ui.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. models.dbdefinition_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xmle ditor.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.prese ntations.r21_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. connection.ui.infopop_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.team.cvs .core_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.sdk_3.1. 1/
file:/home/max/programs/eclipse/plugins/org.eclipse.gef.sour ce_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.ui.properties_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.workb ench.texteditor_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.html .standard.dtds_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on_core.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.pde.juni t.runtime_3.1.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.debu g_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.doc_ 2.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.jem.prox y_1.1.0.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.java script.core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.data tools.fe.ui.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.environment_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.platform _3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.core.var iables_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.cheat sheets_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.ws.i nfopop_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.dali.cor e_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jface_3. 1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore.editor_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.draw2d.d oc.isv_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.core.res ources.compatibility_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jem.util _1.1.0.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.platform .source.linux.gtk.x86_64_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.swt_3.1. 0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.xsd_2.1. 1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2xml_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.core.com mands_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.comm onj.sdo_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.dtde ditor.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jface.te xt_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.pde_3.1. 0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.mapp ing.xsd2ecore_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.ecor e.change_2.1.0.jar
file:/home/max/programs/eclipse/plugins/com.ibm.etools.emf.e vent_3.0.0.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.ui_3.1.1 .jar
file:/home/max/programs/eclipse/plugins/org.eclipse.ui.conso le_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.update.s cheduler_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. dbdefinition.db2.zseries_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.platform .source_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. dbdefinition.mysql_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.webt ools.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.web_ ui.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.gef.doc. isv_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.infopop_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. server.extensions_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.vali dation.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.ant.core _3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.apache.lucene_1. 4.3/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.debu g.ui_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.dali.db_ 1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.frameworks_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.swt.gtk. linux.x86_64_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.xsd.sour ce_2.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.inte rnet.cache_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.core _3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.draw2d_3 .1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.wsi_ 1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.data tools.server.ui.doc.user_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.core.exp ressions_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.inte rnet.proxy_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.rcp_3.1. 0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.osgi.ser vices_3.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.laun ching_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.mapp ing.ecore2ecore_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. dbdefinition.db2.iseries_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.dali.edi t_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.snippets_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jem.bean info_1.1.0.1/
file:/home/max/programs/eclipse/plugins/org.wsdl4j_1.4.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.ws_u i.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.wsdl _1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.sse. ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.search_3 .1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.html .ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.ecor e_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.doc. isv_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xml. ui.infopop_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt_3.1. 0.jar
file:/home/max/programs/eclipse/plugins/org.apache.wsil4j_1. 0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. dbdefinition.informix_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.wsi. ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.serv er.core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.sour ce_2.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.update.c ore.linux_3.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.wsdl .validation_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xml_ core.feature.source_1.0.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.code gen_2.1.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.platform .doc.isv_3.1.1/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.xml. ui_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.comm on.modulecore_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.dali.uti lity_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.juni t.runtime_3.1.0/
file:/home/max/programs/eclipse/plugins/org.eclipse.wst.rdb. data.core_1.0.0.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.emf.impo rter.java_2.1.1.jar
file:/home/max/programs/eclipse/plugins/org.eclipse.jdt.juni t_3.1.1/
fil
Re: persistence perspective not available [message #433507 is a reply to message #433506] Wed, 18 January 2006 12:08 Go to previous messageGo to next message
Dirk le Roux is currently offline Dirk le RouxFriend
Hi Max,
I see you start eclipse with the vm set to /usr/lib/jvm/java/jre/bin/java,
is that a 1.5 vm? The Dali plugin requires JDK 1.5. If
/usr/lib/jvm/java/jre/bin/java is not a 1.5 vm please start eclipse with
JDK1.5 using the -vm arg.
eg: ./eclipse -vm /usr/local/jdk1.5.0_02/bin/java
Dirk le Roux
Re: persistence perspective not available [message #433508 is a reply to message #433506] Wed, 18 January 2006 22:09 Go to previous messageGo to next message
It seems that the 3 plug-ins you are missing are not being resolved by
Eclipse, which would indicate that those plug-ins' dependencies are not
being met. I'm not sure how this could be at the moment, but I will look
into this further and try to figure out what might be wrong.
Neil
Re: persistence perspective not available [message #433509 is a reply to message #433507] Wed, 18 January 2006 23:55 Go to previous messageGo to next message
Member
Hi Dirk,
as seen in the configuration details:
thx anyway
max
Dirk le Roux wrote:
> Hi Max,
> /usr/lib/jvm/java/jre/bin/java, is that a 1.5 vm? The Dali plugin
> requires JDK 1.5. If /usr/lib/jvm/java/jre/bin/java is not a 1.5 vm
> please start eclipse with JDK1.5 using the -vm arg.
> Dirk le Roux
Re: persistence perspective not available [message #433510 is a reply to message #433508] Thu, 19 January 2006 02:41 Go to previous messageGo to next message
Member
Hi Neil,
i just did the exact same thing under windows and i end up with the same
results. are you using the exact same packages as i do?
again:
eclipse-SDK-3.1.1- (linux64 oder win32)
GEF-SDK-3.1.1
JEM-SDK-1.1.0.1
wtp-wst-sdk-1.0
Dali_01-03-06
thx
max
> look into this further and try to figure out what might be wrong.
> Neil
Re: persistence perspective not available [message #433511 is a reply to message #433510] Thu, 19 January 2006 17:08 Go to previous messageGo to next message
Max, I finally figured out what the problem was, and of course it was
sitting right in front of me. You have the wtp-wst-sdk installed, but you
are missing the wtp-jst. It looks like you downloaded the wst specific
install, where you need to download and install the full wtp-sdk-1.0.zip
which includes both components. This should solve the problem.
The current install is here
http://download.eclipse.org/webtools/downloads/drops/R-1.0-2 00512210855/.
Neil
Max Giesbert wrote:
> Hi Neil,
> again:
> GEF-SDK-3.1.1
> JEM-SDK-1.1.0.1
> wtp-wst-sdk-1.0
> Dali_01-03-06
> thx
> max
>> Neil
Re: persistence perspective not available [message #433512 is a reply to message #433511] Thu, 19 January 2006 23:54 Go to previous message
Member
Hi Neil,
thx a lot. i am really sorry for the confusion. this might have come
from switching over from the jsr220orm project which only needs the
wtp-wst-sdk-1.0.
maybe you should point out the exact package with the install instructions.
cheers
max
> you are missing the wtp-jst. It looks like you downloaded the wst
> specific install, where you need to download and install the full
> wtp-sdk-1.0.zip which includes both components. This should solve the
> problem.
> Neil
> Max Giesbert wrote:
>> Hi Neil,
>> same results. are you using the exact same packages as i do?
>> again:
>> GEF-SDK-3.1.1
>> JEM-SDK-1.1.0.1
>> wtp-wst-sdk-1.0
>> Dali_01-03-06
>> thx
>> max
>>> by Eclipse, which would indicate that those plug-ins' dependencies
>>> are not being met. I'm not sure how this could be at the moment, but
>>> I will look into this further and try to figure out what might be wrong.
>>> Neil
Re: persistence perspective not available [message #570789 is a reply to message #433502] Tue, 17 January 2006 15:16 Go to previous message
Max,
suggestions.
Neil
> Hi there,
> eclipse folder.
> thx
> max
Re: persistence perspective not available [message #570814 is a reply to message #433504] Tue, 17 January 2006 19:15 Go to previous message
Max,
Details.
Neil
Neil Hauge wrote:
> Max,
> suggestions.
> Neil
>> Hi there,
>> eclipse folder.
>> thx
>> max
Re: persistence perspective not available [message #570842 is a reply to message #433505] Wed, 18 January 2006 00:30 Go to previous message
Member
Hi Neil,
given order:
GEF-SDK-3.1.1
JEM-SDK-1.1.0.1
wtp-wst-sdk-1.0
Dali_01-03-06
show up.
something else?
max
linux
-ws
gtk
-arch
x86_64
-launcher
-name
Eclipse
-showsplash
600
-exitdata
92001e
-clean
-vm
-Xmx256m
-jar
eof=eof
file.encoding=UTF-8
file.separator=/
java.io.tmpdir=/tmp
line.separator=
os.arch=amd64
os.name=Linux
osgi.arch=x86_64
osgi.clean=true
osgi.nl=de_DE
osgi.os=linux
osgi.ws=gtk
path.separator=:
sun.cpu.isalist=
sun.desktop=gnome
user.country=DE
user.home=/home/max
user.language=de
user.name=max
*** Features:
Guide"
Programmers Guide"
Source"
Resources"
Resources"
Resources"
- Common Component"
Common Component"
XML Component"
XML Component"
- Common Component"
Common Component"
WST Web Component"
Common Component"
Web Component"
Common Component"
WST XML Component"
Guide"
[Resolved]
[Resolved]
[Resolved]
Guide" [Resolved]
[Resolved]
Editor" [Resolved]
Source" [Resolved]
[Resolved]
[Resolved]
Editor" [Resolved]
[Resolved]
Editor" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Support" [Active]
[Resolved]
[Resolved]
[Resolved]
Support" [Resolved]
[Resolved]
[Resolved]
Guide" [Resolved]
[Resolved]
[Resolved]
2.0" [Resolved]
[Resolved]
[Resolved]
[Active]
[Active]
[Resolved]
(core)" [Resolved]
(GUI)" [Resolved]
[Active]
[Resolved]
[Resolved]
[Active]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Active]
[Resolved]
Model" [Resolved]
[Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
[Resolved]
Plug-in" [Resolved]
[Resolved]
[Resolved]
[Resolved]
Guide" [Resolved]
[Resolved]
[Resolved]
name\="jdk1.5.0_06"
Configured sites:
platform:/base/
fil
Re: persistence perspective not available [message #570875 is a reply to message #433506] Wed, 18 January 2006 12:08 Go to previous message
Hi Max,
Dirk le Roux
Re: persistence perspective not available [message #570908 is a reply to message #433506] Wed, 18 January 2006 22:09 Go to previous message
Neil
Re: persistence perspective not available [message #570935 is a reply to message #433507] Wed, 18 January 2006 23:55 Go to previous message
Member
Hi Dirk,
thx anyway
max
Dirk le Roux wrote:
> Hi Max,
> Dirk le Roux
Re: persistence perspective not available [message #570947 is a reply to message #433508] Thu, 19 January 2006 02:41 Go to previous message
Member
Hi Neil,
again:
GEF-SDK-3.1.1
JEM-SDK-1.1.0.1
wtp-wst-sdk-1.0
Dali_01-03-06
thx
max
> Neil
Re: persistence perspective not available [message #570961 is a reply to message #433510] Thu, 19 January 2006 17:08 Go to previous message
Neil
Max Giesbert wrote:
> Hi Neil,
> again:
> GEF-SDK-3.1.1
> JEM-SDK-1.1.0.1
> wtp-wst-sdk-1.0
> Dali_01-03-06
> thx
> max
>> Neil
Re: persistence perspective not available [message #570976 is a reply to message #433511] Thu, 19 January 2006 23:54 Go to previous message
Max Giesbert is currently offline Max GiesbertFriend
Member
Hi Neil,
wtp-wst-sdk-1.0.
cheers
max
> problem.
> Neil
> Max Giesbert wrote:
>> Hi Neil,
>> again:
>> GEF-SDK-3.1.1
>> JEM-SDK-1.1.0.1
>> wtp-wst-sdk-1.0
>> Dali_01-03-06
>> thx
>> max
>>> Neil
Previous Topic:@GeneratedValue annotation
Next Topic:JSR220-ORM Project Merges with Dali
Current Time: Tue Jan 23 08:26:33 GMT 2018
Powered by FUDForum. Page generated in 0.03405 seconds
