Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problems with Text control
Problems with Text control [message #432867] Tue, 30 March 2004 12:04 Go to next message
Robert Bacs is currently offline Robert BacsFriend
I want to create a multiline Text control using the native Text widget.
The problem with the above snippet is that I cannot introduce more than 7
lines of text.
Well, in the examples provided by Eclipse (ControlExample) the Text control
created with SWT.MULTI it has'nt this limitation.
What is wrong in my snippet ?
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.*;
import org.eclipse.swt.widgets.*;
* @author Robert Bacs
public class XTableTest {
public static void main(String []args){
final Display display = new Display();
final Shell shell = new Shell(display);
shell.setLayout(new GridLayout());
Group textGroup = new Group (shell, SWT.NULL);
textGroup.setLayout (new GridLayout ());
textGroup.setLayoutData (new GridData (GridData.GRAB_HORIZONTAL |
GridData.HORIZONTAL_ALIGN_FILL | GridData.VERTICAL_ALIGN_FILL));
textGroup.setText ("Text");
Text text = new Text(textGroup, SWT.MULTI);
int size = 100;
GridData gridData = new GridData ();
gridData.widthHint = size;
gridData.heightHint = size;
text.setLayoutData(gridData);
text.setText("Multiline\nText\ncontrol");
shell.pack();
shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Re: Problems with Text control [message #432935 is a reply to message #432867] Tue, 30 March 2004 14:16 Go to previous messageGo to next message
Steve Northover is currently offline Steve NorthoverFriend
1) Give it a vertical scroll bar using SWT.V_SCROLL (in SWT 2.1.x)
2) The problem has already been worked around in SWT 3.0 (SWT.V_SCROLL
should not be necessary but it's not harmful).
"Robert Bacs" <boby@zerosoft.ro> wrote in message
news:c4bms6$9qe$1@eclipse.org...
> lines of text.
control
> int size = 100;
> shell.pack();
> shell.open();
> display.dispose ();
Re: Problems with Text control [message #432944 is a reply to message #432935] Tue, 30 March 2004 15:30 Go to previous messageGo to next message
Yes, I know that, but in the ControlExample it's working without
SWT.V_SCROLL and I'm runninng with the same SWT version both example
(ControlExample and my snippet).
What is the difference between my snippet and the example provided by
ControlExample ?
Because, I do not see any !
Boby
"Steve Northover" <steve_northover@ca.ibm.com> wrote in message
news:c4bv5u$lh4$1@eclipse.org...
> > Hi,
7
> > lines of text.
> control
> > int size = 100;
> > shell.pack();
> > shell.open();
> > display.dispose ();
Re: Problems with Text control [message #433000 is a reply to message #432944] Wed, 31 March 2004 13:46 Go to previous message
I found the difference: in the Java build path I have two version of swt.jar
Boby
news:c4c2ua$r78$1@eclipse.org...
> ControlExample ?
> Best regards,
> Boby
> > > Hi,
widget.
than
> 7
> > > lines of text.
> > control
> > > int size = 100;
> > > shell.pack();
> > > shell.open();
> > > display.dispose ();
Previous Topic:Native Window ID using SWT/GTK/Linux
Next Topic:Programming Model of SWT.
Current Time: Sat Feb 24 18:45:42 GMT 2018
Powered by FUDForum. Page generated in 0.01902 seconds
